[PATCH 00/10] Update mDNSResponder to Apple v878.270.2
Sebastian Huber
Fri Jun 19 11:02:14 UTC 2020
This patch set applies to the master and 5-freebsd-12 branches of
libbsd.
Sebastian Huber (10):
mDNSResponder: Back to mDNSResponder-878.30.4
mDNSResponder: Update to v878.50.17
mDNSResponder: Update to v878.70.2
mDNSResponder: Update to v878.200.35
mDNSResponder: Update to v878.230.2
mDNSResponder: Update to v878.240.1
mDNSResponder: Update to v878.250.4
mDNSResponder: Update to v878.260.1
mDNSResponder: Update to v878.270.2
mDNSResponder: Port to RTEMS
mDNSResponder/Clients/dns-sd.c | 107 +-
mDNSResponder/Clients/dnssdutil.c | 20309 +++++++++++++---
mDNSResponder/Makefile | 6 +-
mDNSResponder/mDNSCore/DNSCommon.c | 389 +-
mDNSResponder/mDNSCore/DNSCommon.h | 13 +-
mDNSResponder/mDNSCore/dnssec.c | 2 +-
mDNSResponder/mDNSCore/mDNS.c | 523 +-
mDNSResponder/mDNSCore/mDNSDebug.h | 7 +-
mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h | 85 +-
mDNSResponder/mDNSCore/uDNS.c | 209 +-
mDNSResponder/mDNSCore/uDNS.h | 2 +
.../mDNSMacOSX/BATS/mDNSResponder.plist | 627 +
.../mDNSMacOSX/BonjourTop/source/BonjourTop.1 | 156 +-
mDNSResponder/mDNSMacOSX/D2D.c | 49 +-
mDNSResponder/mDNSMacOSX/DNS64.c | 34 +-
mDNSResponder/mDNSMacOSX/DNS64.h | 4 +-
.../mDNSMacOSX/DNSServiceDiscovery.c | 10 +-
.../mDNSMacOSX/DNSServiceDiscovery.h | 15 +-
mDNSResponder/mDNSMacOSX/LegacyNATTraversal.c | 3 +-
.../com.apple.mDNSResponder.plist | 14 +
.../com.apple.mDNSResponder.plist | 16 +
mDNSResponder/mDNSMacOSX/Metrics.h | 2 +-
mDNSResponder/mDNSMacOSX/Metrics.m | 29 +-
.../Private/com.apple.mDNSResponder.plist | 19 -
.../mDNSMacOSX/Scripts/bonjour-mcast-diagnose | 380 +
.../Scripts/bonjour-start-mdns-tcpdump | 56 +
...com.apple.mDNSResponder.mdns-tcpdump.plist | 21 +
mDNSResponder/mDNSMacOSX/daemon.c | 27 +-
.../mDNSMacOSX/dnssdutil-entitlements.plist | 12 +
mDNSResponder/mDNSMacOSX/helper-stubs.c | 18 +-
mDNSResponder/mDNSMacOSX/helper.c | 15 +-
mDNSResponder/mDNSMacOSX/mDNSMacOSX.c | 720 +-
mDNSResponder/mDNSMacOSX/mDNSMacOSX.h | 11 +-
mDNSResponder/mDNSMacOSX/mDNSResponder.sb | 4 +-
.../mDNSResponder.xcodeproj/project.pbxproj | 193 +-
.../mDNSMacOSX/uDNSPathEvalulation.c | 8 +-
mDNSResponder/mDNSPosix/ProxyResponder.c | 2 +-
mDNSResponder/mDNSPosix/Responder.c | 2 +-
mDNSResponder/mDNSPosix/mDNSPosix.c | 5 +-
mDNSResponder/mDNSPosix/mDNSUNP.c | 60 +-
mDNSResponder/mDNSPosix/mDNSUNP.h | 8 +-
mDNSResponder/mDNSResponder.sln | 21 +
mDNSResponder/mDNSShared/CommonServices.h | 6 +-
mDNSResponder/mDNSShared/dns_sd.h | 62 +-
mDNSResponder/mDNSShared/dns_sd_private.h | 8 +-
mDNSResponder/mDNSShared/dnsextd.c | 4 +-
mDNSResponder/mDNSShared/dnsextd.conf | 10 +-
mDNSResponder/mDNSShared/dnssd_clientlib.c | 16 +-
mDNSResponder/mDNSShared/dnssd_clientshim.c | 1 +
mDNSResponder/mDNSShared/dnssd_clientstub.c | 1 -
mDNSResponder/mDNSShared/mDNSDebug.c | 3 +-
mDNSResponder/mDNSShared/uds_daemon.c | 116 +-
.../mDNSWindows/BonjourQuickLooks.sln | 162 +-
.../BonjourQuickLooksInstaller.wixproj | 170 +-
mDNSResponder/mDNSWindows/mDNSWin32.c | 2 +-
mDNSResponder/unittests/CNameRecordTests.c | 3 +-
mDNSResponder/unittests/mDNSCoreReceiveTest.c | 18 +-
mDNSResponder/unittests/mdns_ut.c | 9 -
mDNSResponder/unittests/uds_daemon_ut.c | 2 +-
mDNSResponder/unittests/unittest_common.h | 2 -
testsuite/foobarserver/test_main.c | 2 +-
61 files changed, 19922 insertions(+), 4868 deletions(-)
create mode 100644 mDNSResponder/mDNSMacOSX/BATS/mDNSResponder.plist
create mode 100644 mDNSResponder/mDNSMacOSX/LoggingProfiles/AppleInternal/com.apple.mDNSResponder.plist
create mode 100644 mDNSResponder/mDNSMacOSX/LoggingProfiles/com.apple.mDNSResponder.plist
delete mode 100644 mDNSResponder/mDNSMacOSX/Private/com.apple.mDNSResponder.plist
create mode 100755 mDNSResponder/mDNSMacOSX/Scripts/bonjour-mcast-diagnose
create mode 100755 mDNSResponder/mDNSMacOSX/Scripts/bonjour-start-mdns-tcpdump
create mode 100644 mDNSResponder/mDNSMacOSX/Scripts/com.apple.mDNSResponder.mdns-tcpdump.plist
create mode 100644 mDNSResponder/mDNSMacOSX/dnssdutil-entitlements.plist
2.26.2
