m2006-2 Linux Build Sweep Feedback
Sat Jun 20 14:48:11 UTC 2020
Hi
The m2006-2 candidate passed more of the build sweep steps than any of the
other candidates. The bsp builder sweep of all BSPs and many (1700+)
configurations has the normal 6 GCC induced epiphany failures. All but one
of the BSP bsets built. atsamv failed:
https://lists.rtems.org/pipermail/build/2020-June/015864.html
Looks like libbsd failed to build for that BSP with this:
[1875/1925] Linking build/arm-rtems5-atsamv-default/epoch01.exe
/home/joel/rtems-cron-5.0.0-m2006-2/rtems-source-builder-5.0.0-m2006-2/rtems/build/tmp/sb-1001-staging/bin/../lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld:linkcmds.base:326
cannot move location counter backwards (from 000000002047ab60 to
000000002045f000)
collect2: error: ld returned 1 exit status
cannot move location counter backwards (from 000000002053f9a0 to
000000002045f000)
000000002045f000)
Waf: Leaving directory
`/home/joel/rtems-cron-5.0.0-m2006-2/rtems-source-builder-5.0.0-m2006-2/rtems/build/rtems-libbsd-d38dbbe18e5315bf69a7c3916d71ef3838d4c20d-x86_64-linux-gnu-1/rtems-libbsd-5.0.0-m2006-2/build/arm-rtems5-atsamv-default'
Build failed
No one may read this far but this failure and Jan's Pi2 testing failure
appear to be the hurdles now.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200620/17de1236/attachment.html>
