[PATCH] Adding APA terms to glossary
Richi Dubey richidubey at gmail.com
Sun Jun 21 09:21:05 UTC 2020
Hi,
Thanks for another review and your patience. I've sent in a patch with the
suggested changes. Please let me know if it looks okay.
On Fri, Jun 19, 2020 at 4:46 PM Sebastian Huber <
> Hello Richi,
> thanks for the update, we are getting closer to the final version.
> On 19/06/2020 11:49, Richi Dubey wrote:
> >   c-user/glossary.rst | 31 +++++++++++++++++++++++++++++++
> >   1 file changed, 31 insertions(+)
> > diff --git a/c-user/glossary.rst b/c-user/glossary.rst
> > index 86350a8..691ba52 100644
> > --- a/c-user/glossary.rst
> > +++ b/c-user/glossary.rst
> > @@ -1,5 +1,6 @@
> >   .. SPDX-License-Identifier: CC-BY-SA-4.0
> > +.. Copyright (C) 2020 Richi Dubey (richidubey at gmail.com)
> >   .. Copyright (C) 2017, 2019 embedded brains GmbH (
> http://www.embedded-brains.de)
> >   .. Copyright (C) 1988, 1998 On-Line Applications Research Corporation
> (OAR)
> > @@ -16,6 +17,13 @@ Glossary
> >           A term used to describe an object which has been created by an
> >           application.
> > +    APA
> > +        This term is an acronym for Arbitrary Processor Affinity.
> > +        APA schedulers allow a thread to have an arbitrary affinity to
> > +        a processor set, rather than a restricted mapping to only one
> > +        processor of the set or the ability to run on all processors of
> > +        the set. It has two variants, :term:`Weak APA` and
> :term:`Strong APA`
> Looks good, except the missing dot to end the last sentence. Please try
> the vim "gq" to format the text.
> >       aperiodic task
> >           A task which must execute only at irregular intervals and has
> only a soft
> >           deadline.
> > @@ -777,6 +785,19 @@ Glossary
> >           :term:`return value` to indicate a successful operation or
> error
> >           conditions.
> > +    Strong APA
> > +        Strong APA is a specialization of :term:`APA`.
> > +        Whenever a :term:`thread` becomes ready for execution,
> schedulers which
> > +        implement strong APA recursively search for a processor in the
> thread's
> > +        affinity set, followed by the processors in the affinity set of
> threads
> > +        that are assigned the processor present in the ready thread's
> affinity set.
> > +        This is done to find a thread to processor mapping that does
> not violate the
> > +        priority ordering and to provide a schedule with a higher total
> priority of
> Sorry for being pedantic, but please keep in mind that RTEMS users
> interested in this stuff may not have read many scheduler papers. They
> may ask what "a schedule" is.
> > +        the threads scheduled.
> > +        Similar analysis is done when a thread finishes its execution.
> "finishes its execution" -> "blocks".
> > +        See also :cite:`Cerqueira:2014:LPA`.
> >       suspend
> >           A term used to describe a task that is not competing for the
> CPU because it
> >           has had a ``rtems_task_suspend`` directive.
> > @@ -905,6 +926,16 @@ Glossary
> >           Message queues, regions, and semaphores have a wait queue
> associated with
> >           them.
> > +    Weak APA
> > +        Weak APA is a specialization of :term:`APA`. This refers to
> Linux's push and
> > +        pull implementation of APA model. On the arrival of a thread,
> Please avoid this "arrival", use a phrase like "Whenever a
> :term:`thread` becomes ready for execution" like above.
> > the thread is
> > +        scheduled when a processor in its affinity set is idle or a
> processor in its
> > +        affinity set is executing a thread which is at a lower priority.
> > +        Unlike :term:`Strong APA`, no thread is migrated from its
> processor to find
> > +        a thread to processor mapping.
> >       YAML
> >           This term is an acronym for `YAML Ain't Markup Language <
> https://yaml.org/>`_.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200621/ec19fe09/attachment-0001.html>
