Build FreeBSD: FAILED devel/qemu4 on x86_64-freebsd12.1 (glib-2.46.2-x86_64-freebsd12.1-1)
Sun Jun 21 13:29:59 UTC 2020
On Sun, Jun 21, 2020, 6:05 AM Chris Johns <chrisj at rtems.org> wrote:
> On 21 Jun 2020, at 2:15 pm, Joel Sherrill <joel at rtems.org> wrote:
> Build failure on FreeBSD
> Have you tripped over the revoke issue in a session somehow...
> https://bugs.python.org/issue32849
> I do not see this as a bug in the RSB or the qemu4 config
I probably did. When it finishes I will try it again
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200621/f8fed900/attachment.html>
