[PATCH] Added APA terms in glossary
Richi Dubey richidubey at gmail.com
Sun Jun 21 09:11:58 UTC 2020
 c-user/glossary.rst | 35 +++++++++++++++++++++++++++++++++++
 1 file changed, 35 insertions(+)
diff --git a/c-user/glossary.rst b/c-user/glossary.rst
index 86350a8..7442388 100644
--- a/c-user/glossary.rst
+++ b/c-user/glossary.rst
@@ -1,5 +1,6 @@
 .. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2020 Richi Dubey (richidubey at gmail.com)
 .. Copyright (C) 2017, 2019 embedded brains GmbH (http://www.embedded-brains.de)
 .. Copyright (C) 1988, 1998 On-Line Applications Research Corporation (OAR)
@@ -16,6 +17,15 @@ Glossary
         A term used to describe an object which has been created by an
         application.
+    APA
+        This term is an acronym for Arbitrary Processor Affinity.  APA
+        schedulers allow a thread to have an arbitrary affinity to a
+        processor set, rather than a restricted mapping to only one
+        processor of the set or the ability to run on all processors of
+        the set.
+        It has two variants, :term:`Weak APA` and :term:`Strong APA`.
     aperiodic task
         A task which must execute only at irregular intervals and has only a soft
         deadline.
@@ -777,6 +787,20 @@ Glossary
         :term:`return value` to indicate a successful operation or error
         conditions.
+    Strong APA
+        Strong APA is a specialization of :term:`APA`.
+        Schedulers which implement strong APA recursively search for a
+        processor in the :term:`thread`'s affinity set, whenever a thread
+        becomes ready for execution, followed by the processors in the
+        affinity set of threads that are assigned the processor in the
+        ready thread's affinity set. This is done to find a thread to
+        processor mapping that does not violate the priority ordering and
+        to provide a thread to processor mapping with a higher total
+        priority of the threads allocated a processor.
+        Similar analysis is done when a thread blocks.
+        See also :cite:`Cerqueira:2014:LPA`.
     suspend
         A term used to describe a task that is not competing for the CPU because it
         has had a ``rtems_task_suspend`` directive.
@@ -905,6 +929,17 @@ Glossary
         Message queues, regions, and semaphores have a wait queue associated with
         them.
+    Weak APA
+        Weak APA is a specialization of :term:`APA`.
+        It refers to Linux's push and pull implementation of APA model.
+        When a :term:`thread` becomes ready for execution, it is
+        allocated a processor if there is an idle processor, or if a
+        processor is executing a lower priority thread in its affinity
+        set. Unlike :term:`Strong APA`, no thread is migrated from its
+        processor to find a thread to processor mapping.
     YAML
         This term is an acronym for `YAML Ain't Markup Language <https://yaml.org/>`_.
2.17.1
