m2006-2 Linux Build Sweep Feedback
    Alan Cudmore
    alan.cudmore at gmail.com
    Sun Jun 21 13:45:12 UTC 2020
For the Pi2 SMP:
I started looking at this a while ago. If I remember correctly, Pi2
SMP worked on QEMU. I have an original Pi2 that it fails on (using
smp01.exe). I dont have a really good way to debug on the hardware, so
I was going down the path of using printk statements to figure out
where it was hanging. The console log below shows how far I was able
to get.
It looks like it's in _CPU_SMP_Processor_event_receive waiting for the
2nd CPU to change state.
If anyone has clues of where to look next, I can try a few changes out.
Alan
RTEMS RPi 2B 1.1 (1GB) [00a21041]
in _SMP_Handler_initialize
in _SMP_Handler_initialize, max processors = 4
in _SMP_Handler_initialize - calling _CPU_SMP_Initialize
in _CPU_SMP_Initialize
in _SMP_Handler_initialize - _SMP_Processor_maximum = 4
in _SMP_Handler_initialize - calling _SMP_Start_processors
In _SMP_Start_processors
In _SMP_Start_processors - index = 0
In _SMP_Start_processors - cpu_index = self, so started already
In _SMP_Start_processors - index = 1
In _SMP_Start_processors - calling _CPU_SMP_Start_processor
in _CPU_SMP_Start_processor : cpu_index = 1
in _CPU_SMP_Start_processor - call
_Per_CPU_State_wait_for_non_initial_state - bool started = 0
in Per_CPU_State_wait_for_non_initial_state index = 1, timeout = 0
 CPU state before = 0
in Per_CPU_State_wait_for_non_initial_state - about to call
_CPU_SMP_Processor_event_receive in while loop
in Per_CPU_State_wait_for_non_initial_state - after
 CPU state  after = 0
On Sun, Jun 21, 2020 at 7:09 AM Chris Johns <chrisj at rtems.org> wrote:
> On 21 Jun 2020, at 12:48 am, Joel Sherrill <joel at rtems.org> wrote:
> Hi
> The m2006-2 candidate passed more of the build sweep steps than any of the other candidates.
> Great. I will branch the repos tomorrow.
> Thank you for all your testing and reports. They are really helpful and important.
> The bsp builder sweep of all BSPs and many (1700+) configurations has the normal 6 GCC induced epiphany failures. All but one of the BSP bsets built. atsamv failed:
> https://lists.rtems.org/pipermail/build/2020-June/015864.html
> Looks like libbsd failed to build for that BSP with this:
> [1875/1925] Linking build/arm-rtems5-atsamv-default/epoch01.exe
> /home/joel/rtems-cron-5.0.0-m2006-2/rtems-source-builder-5.0.0-m2006-2/rtems/build/tmp/sb-1001-staging/bin/../lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld:linkcmds.base:326 cannot move location counter backwards (from 000000002047ab60 to 000000002045f000)
> collect2: error: ld returned 1 exit status
> /home/joel/rtems-cron-5.0.0-m2006-2/rtems-source-builder-5.0.0-m2006-2/rtems/build/tmp/sb-1001-staging/bin/../lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld:linkcmds.base:326 cannot move location counter backwards (from 000000002053f9a0 to 000000002045f000)
> Waf: Leaving directory `/home/joel/rtems-cron-5.0.0-m2006-2/rtems-source-builder-5.0.0-m2006-2/rtems/build/rtems-libbsd-d38dbbe18e5315bf69a7c3916d71ef3838d4c20d-x86_64-linux-gnu-1/rtems-libbsd-5.0.0-m2006-2/build/arm-rtems5-atsamv-default'
> Build failed
> No one may read this far but this failure and Jan's Pi2 testing failure appear to be the hurdles now.
> That is a shame. Fixes are welcome.
> Chris
> devel mailing list
> devel at rtems.org
