Fwd: Release snapshot 5.0.0-m2006-2 available
Heinz Junkes junkes at fhi-berlin.mpg.de
Sun Jun 21 13:54:08 UTC 2020
I forgot to send it to rtems-devel...
> Begin forwarded message:
> From: junkes <junkes at fhi-berlin.mpg.de>
> Subject: Re: Release snapshot 5.0.0-m2006-2 available
> Date: 21. June 2020 at 13:53:35 CEST
> To: Chris Johns <chrisj at rtems.org>
> Hello Chris,
> thanks for the release snapshot. It all looks very good already.
> I have tried it for xilinx_zynq_a9_qemu.
> configuration:
> $ ../../rtems/configure \
>> --prefix=$HOME/development/rtems/5 \
>> --enable-maintainer-mode \
>> --enable-posix \
>> --enable-cxx \
>> --target=arm-rtems5 \
>> --enable-rtemsbsp=xilinx_zynq_a9_qemu \
>> --enable-tests
> rtems-test --rtems-bsp=xilinx_zynq_a9_qemu --rtems-tools=$HOME/development/rtems/5 .
> returns the following errors:
> RTEMS Testing - Tester, 5.0.not_released
> Command Line: /Users/junkes/development/rtems/5/bin/rtems-test --rtems-bsp=xilinx_zynq_a9_qemu --rtems-tools=/Users/junkes/development/rtems/5 .
> Host: Darwin h.fritz.box 19.5.0 Darwin Kernel Version 19.5.0: Tue May 26 20:41:44 PDT 2020; root:xnu-6153.121.2~2/RELEASE_X86_64 x86_64
> Python: 3.7.3 (default, Apr 24 2020, 18:51:23) [Clang 11.0.3 (clang-1103.0.32.62)]
> Host: Darwin-19.5.0-x86_64-i386-64bit (Darwin h.fritz.box 19.5.0 Darwin Kernel Version 19.5.0: Tue May 26 20:41:44 PDT 2020; root:xnu-6153.121.2~2/RELEASE_X86_64 x86_64 i386)
> [  1/599] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: dhrystone.exe
> [  3/599] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: whetstone.exe
> [  2/599] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: linpack.exe
> [125/599] p:115 f:0   u:2   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: rbheap01.exe
> [129/599] p:119 f:0   u:2   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: sha.exe
> [126/599] p:118 f:0   u:2   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: record01.exe
> Result: failed     Time: 0:00:01.007355 record01.exe
> =>  run: qemu-system-arm -no-reboot -nographic -net none -serial null -serial mon:stdio -M xilinx-zynq-a9 -m 256M -kernel ./arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/libtests/record01.exe
> ] qemu-system-arm: warning: nic cadence_gem.0 has no peer
> ] qemu-system-arm: warning: nic cadence_gem.1 has no peer
> =>  test start: RECORD 1
> ] *** BEGIN OF TEST RECORD 1 ***
> ] *** TEST VERSION: 5.0.0-m2006-2
> ] *** TEST STATE: EXPECTED_PASS
> ] *** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API
> ] *** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB 5.0.0-m2006-2, Newlib 7947581)
> ] ../../../../../../../rtems/c/src/../../testsuites/libtests/record01/init.c: 633 hs == HEADER_LAST || items[0].event == hs_to_ev(hs)
> ] *** FATAL ***
> ] fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
> ] fatal code: 0 (0x00000000)
> ] RTEMS version: 5.0.0-m2006-2
> ] RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5.0.0-m2006-2, Newlib 7947581)
> ] executing thread ID: 0x08a010001
> ] executing thread name: UI1
> [127/599] p:118 f:0   u:2   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: record02.exe
> [130/599] p:120 f:1   u:2   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: shell01.exe
> [131/599] p:120 f:1   u:2   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: sparsedisk01.exe
> [168/599] p:155 f:1   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psx11.exe
> [169/599] p:156 f:1   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psx12.exe
> [170/599] p:157 f:1   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psx13.exe
> [171/599] p:157 f:2   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psx14.exe
> [173/599] p:160 f:2   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psx16.exe
> [172/599] p:160 f:2   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psx15.exe
> [174/599] p:160 f:2   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psxaio01.exe
> [176/599] p:163 f:2   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psxaio03.exe
> [175/599] p:163 f:2   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psxaio02.exe
> [177/599] p:163 f:2   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psxalarm01.exe
> [179/599] p:166 f:2   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psxautoinit02.exe
> [178/599] p:166 f:2   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psxautoinit01.exe
> [180/599] p:166 f:2   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psxbarrier01.exe
> [181/599] p:169 f:2   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psxcancel.exe
> [182/599] p:169 f:2   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psxcancel01.exe
> [183/599] p:169 f:2   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psxchroot01.exe
> [184/599] p:171 f:2   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psxclassic01.exe
> [186/599] p:172 f:2   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psxcleanup01.exe
> [185/599] p:172 f:2   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psxcleanup.exe
> [187/599] p:174 f:2   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psxcleanup02.exe
> [164/599] p:151 f:1   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psx07.exe
> [165/599] p:154 f:1   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psx08.exe
> [166/599] p:154 f:1   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psx09.exe
> [167/599] p:154 f:1   u:4   e:1   I:0   B:3   t:0   i:0   W:0   | arm/xilinx_zynq_a9_qemu: psx10.exe
> Result: failed     Time: 0:00:01.006078 psx12.exe
> =>  run: qemu-system-arm -no-reboot -nographic -net none -serial null -serial mon:stdio -M xilinx-zynq-a9 -m 256M -kernel ./arm-rtems5/c/xilinx_zynq_a9_qemu/testsuites/psxtests/psx12.exe
> =>  test start: PSX 12
> ] *** BEGIN OF TEST PSX 12 ***
> ] Init's ID is 0x0b010001
> ] Init: pthread_attr_init - SUCCESSFUL
> ] Init: pthread_create - EINVAL (invalid scheduling policy)
> ] Init: set scheduling parameter attributes for sporadic server
> ] Init: pthread_create - EINVAL (replenish < budget)
> ] Init: pthread_create - EINVAL (invalid sched_ss_low_priority)
> ] Init: pthread_create - SUCCESSFUL
> ] Sporadic Server: exitting
> ] [0] H 102ms
> ] [0] L 198ms
> ] ../../../../../../../rtems/c/src/../../testsuites/psxtests/psx12/init.c: 224 ctx->samples[ i ].low / SS_REPL_PERIOD_MS == i + 1
> ] *** FATAL ***
> ] executing thread ID: 0x08b010001
> Traceback (most recent call last):
>  File "/Users/junkes/development/rtems/5/share/rtems/tester/rt/cmd-test.py", line 42, in <module>
>    test.run(sys.argv[1:], command_path = base)
>  File "/Users/junkes/development/rtems/5/share/rtems/tester/rt/test.py", line 496, in run
>    job_trace)
>  File "/Users/junkes/development/rtems/5/share/rtems/tester/rt/test.py", line 195, in report_finished
>    reports.log(tst.executable, log_mode)
>  File "/Users/junkes/development/rtems/5/share/rtems/tester/rt/report.py", line 266, in log
>    log.output(output)
>  File "/Users/junkes/development/rtems/5/share/rtems/rtemstoolkit/log.py", line 112, in output
>    _output(text, log)
>  File "/Users/junkes/development/rtems/5/share/rtems/rtemstoolkit/log.py", line 93, in _output
>    default.output(text)
>  File "/Users/junkes/development/rtems/5/share/rtems/rtemstoolkit/log.py", line 193, in output
>    self.fhs[f].write(out)
> BlockingIOError: [Errno 35] write could not complete without blocking
> The test stops here.
> Gruss Heinz
> On 2020-06-17 07:27, Chris Johns wrote:
>> Hello,
>> I have made a 5.0.0-m2006-2 release snapshot available. The link is ...
>> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2006-2
>> The snapshot contains the recent PC BSP patches from Jan. I am still working in
>> the legacy printk initialisation or lack of it issue.
>> Please test and report what works and what does not.
>> Thanks
>> Chris
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200621/faabc9c0/attachment-0001.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200621/faabc9c0/attachment-0001.bin>
