[5.0.0-m2006-2] Test compilation error in riscv bsps
Jan.Sommer at dlr.de
Sun Jun 21 16:11:25 UTC 2020
Hello,
I just tried to compile some riscv bsps with tests enabled and got a compile time error for the dl06 test.
I tried with griscv and rv32imac with the following configure:
../rtems-5.0.0-m2006-2/configure --target=riscv-rtems5 --prefix../install/bsps --disable-networking --enable-tests --enable-rtemsbsp=griscv
I got the following error:
rtems-ld -r /localdata2/somm_ja/rtems/5-0-rc/build-riscv/riscv-rtems5/c/griscv \
-C riscv-rtems5-gcc -c "-march=rv32imafd -mabi=ilp32d" \
-O rap -b dl06.pre -e rtems_main -s \
-o dl06.rap dl06-o1.o dl06-o2.o -lm
error: rap::object: Section index '0' not found: dl06-o1.o
Makefile:8479: recipe for target 'dl06.rap' failed
make[5]: *** [dl06.rap] Error 10
make[5]: Leaving directory '/localdata2/somm_ja/rtems/5-0-rc/build-riscv/riscv-rtems5/c/griscv/testsuites/libtests'
Makefile:663: recipe for target 'libtests' failed
make[4]: *** [libtests] Error 2
make[4]: Leaving directory '/localdata2/somm_ja/rtems/5-0-rc/build-riscv/riscv-rtems5/c/griscv/testsuites'
Makefile:1222: recipe for target 'testsuites' failed
make[3]: *** [testsuites] Error 2
make[3]: Leaving directory '/localdata2/somm_ja/rtems/5-0-rc/build-riscv/riscv-rtems5/c/griscv'
Makefile:716: recipe for target 'all-recursive' failed
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory '/localdata2/somm_ja/rtems/5-0-rc/build-riscv/riscv-rtems5/c/griscv'
Makefile:289: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/localdata2/somm_ja/rtems/5-0-rc/build-riscv/riscv-rtems5/c'
Makefile:410: recipe for target 'all-recursive' failed
make: *** [all-recursive] Error 1
make all 112,71s user 27,01s system 102% cpu 2:16,13 total
It is the first time I tried anything with riscv, so I might have done something wrong.
Best regards,
Jan
Deutsches Zentrum für Luft- und Raumfahrt e. V. (DLR)
German Aerospace Center
Simulation and Software Technology | Software for Space Systems and Interactive Visualization | Lilienthalplatz 7 | 38108 Braunschweig | Germany
Jan Sommer
Telephone +49 531 295-2494 | Telefax 0531 295-2767 | jan.sommer at dlr.de
DLR.de/SC
