[5.0.0-m2006-2] Test compilation error in riscv bsps
Jan.Sommer at dlr.de
Mon Jun 22 07:11:04 UTC 2020
Hi,
I created the ticket here: https://devel.rtems.org/ticket/4011
Sorry for the bad formatting. I forgot to put the copied console output in a code block, but I can't find a way to edit the ticket description.
Best regards,
Jan
> -----Original Message-----
> From: Chris Johns [mailto:chrisj at rtems.org]
> Sent: Monday, June 22, 2020 8:39 AM
> To: Sommer, Jan; devel at rtems.org
> Subject: Re: [5.0.0-m2006-2] Test compilation error in riscv bsps
> On 22/6/20 2:11 am, Jan.Sommer at dlr.de wrote:
> > Hello,
> > I just tried to compile some riscv bsps with tests enabled and got a compile
> time error for the dl06 test.
> > I tried with griscv and rv32imac with the following configure:
> > ../rtems-5.0.0-m2006-2/configure --target=riscv-rtems5 --
> prefix../install/bsps --disable-networking --enable-tests --enable-
> rtemsbsp=griscv
> > I got the following error:
> > rtems-ld -r /localdata2/somm_ja/rtems/5-0-rc/build-riscv/riscv-
> rtems5/c/griscv \
> > -C riscv-rtems5-gcc -c "-march=rv32imafd -mabi=ilp32d" \
> > -O rap -b dl06.pre -e rtems_main -s \
> > -o dl06.rap dl06-o1.o dl06-o2.o -lm
> > error: rap::object: Section index '0' not found: dl06-o1.o
> Thank you for reporting this. I can reproduce it.
> Please raise a ticket and assign it to the 5.2 milestone.
> Thanks
> Chris
