[5.0.0-m2006-2] Test compilation error in riscv bsps
Chris Johns
chrisj at rtems.org
Mon Jun 22 06:38:45 UTC 2020
On 22/6/20 2:11 am, Jan.Sommer at dlr.de wrote:
> Hello,
> I just tried to compile some riscv bsps with tests enabled and got a compile time error for the dl06 test.
> I tried with griscv and rv32imac with the following configure:
> ../rtems-5.0.0-m2006-2/configure --target=riscv-rtems5 --prefix../install/bsps --disable-networking --enable-tests --enable-rtemsbsp=griscv
> I got the following error:
> rtems-ld -r /localdata2/somm_ja/rtems/5-0-rc/build-riscv/riscv-rtems5/c/griscv \
> -C riscv-rtems5-gcc -c "-march=rv32imafd -mabi=ilp32d" \
> -O rap -b dl06.pre -e rtems_main -s \
> -o dl06.rap dl06-o1.o dl06-o2.o -lm
> error: rap::object: Section index '0' not found: dl06-o1.o
Thank you for reporting this. I can reproduce it.
Please raise a ticket and assign it to the 5.2 milestone.
Thanks
