[PATCH] Added APA terms in glossary
Gedare Bloom
gedare at rtems.org
Mon Jun 22 14:39:25 UTC 2020
Hi Richi,
Please use version numbers on your patches starting with -v2 for the
first resubmission after a review. I can't tell what is the most
recent version.
https://docs.rtems.org/branches/master/eng/vc-users.html#creating-a-patch
GB
On Sun, Jun 21, 2020 at 3:20 AM Richi Dubey <richidubey at gmail.com> wrote:
> Hi,
> Please ignore the first patch as the formatting in it looks a little uneven. Thanks!
> On Sun, Jun 21, 2020 at 2:48 PM Richi Dubey <richidubey at gmail.com> wrote:
>> c-user/glossary.rst | 34 ++++++++++++++++++++++++++++++++++
>> 1 file changed, 34 insertions(+)
>> diff --git a/c-user/glossary.rst b/c-user/glossary.rst
>> index 86350a8..63a4728 100644
>> --- a/c-user/glossary.rst
>> +++ b/c-user/glossary.rst
>> @@ -1,5 +1,6 @@
>> .. SPDX-License-Identifier: CC-BY-SA-4.0
>> +.. Copyright (C) 2020 Richi Dubey (richidubey at gmail.com)
>> .. Copyright (C) 2017, 2019 embedded brains GmbH (http://www.embedded-brains.de)
>> .. Copyright (C) 1988, 1998 On-Line Applications Research Corporation (OAR)
>> @@ -16,6 +17,14 @@ Glossary
>> A term used to describe an object which has been created by an
>> application.
>> + APA
>> + This term is an acronym for Arbitrary Processor Affinity.
>> + APA schedulers allow a thread to have an arbitrary affinity to a
>> + processor set, rather than a restricted mapping to only one processor
>> + of the set or the ability to run on all processors of the set.
>> + It has two variants, :term:`Weak APA` and :term:`Strong APA`.
>> aperiodic task
>> A task which must execute only at irregular intervals and has only a soft
>> deadline.
>> @@ -777,6 +786,20 @@ Glossary
>> :term:`return value` to indicate a successful operation or error
>> conditions.
>> + Strong APA
>> + Strong APA is a specialization of :term:`APA`.
>> + Schedulers which implement strong APA recursively search for a
>> + processor in the :term:`thread`'s affinity set, whenever a thread
>> + becomes ready for execution, followed by the processors in the
>> + affinity set of threads that are assigned the processor in the
>> + ready thread's affinity set. This is done to find a thread to
>> + processor mapping that does not violate the priority ordering and
>> + to provide a thread to processor mapping with a higher total
>> + priority of the threads allocated a processor.
>> + Similar analysis is done when a thread blocks.
>> + See also :cite:`Cerqueira:2014:LPA`.
>> suspend
>> A term used to describe a task that is not competing for the CPU because it
>> has had a ``rtems_task_suspend`` directive.
>> @@ -905,6 +928,17 @@ Glossary
>> Message queues, regions, and semaphores have a wait queue associated with
>> them.
>> + Weak APA
>> + Weak APA is a specialization of :term:`APA`.
>> + It refers to Linux's push and pull implementation of APA model.
>> + When a :term:`thread` becomes ready for execution, it is
>> + allocated a processor if there is an idle processor, or if a
>> + processor is executing a lower priority thread in its affinity
>> + set. Unlike :term:`Strong APA`, no thread is migrated from its
>> + processor to find a thread to processor mapping.
>> YAML
>> This term is an acronym for `YAML Ain't Markup Language <https://yaml.org/>`_.
>> 2.17.1
> devel mailing list
> devel at rtems.org
