[PATCH] Added APA terms in glossary
Richi Dubey richidubey at gmail.com
Sun Jun 21 09:19:33 UTC 2020
Hi,
Please ignore the first patch as the formatting in it looks a little
uneven. Thanks!
On Sun, Jun 21, 2020 at 2:48 PM Richi Dubey <richidubey at gmail.com> wrote:
>  c-user/glossary.rst | 34 ++++++++++++++++++++++++++++++++++
>  1 file changed, 34 insertions(+)
> diff --git a/c-user/glossary.rst b/c-user/glossary.rst
> index 86350a8..63a4728 100644
> --- a/c-user/glossary.rst
> +++ b/c-user/glossary.rst
> @@ -1,5 +1,6 @@
>  .. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2020 Richi Dubey (richidubey at gmail.com)
>  .. Copyright (C) 2017, 2019 embedded brains GmbH (
> http://www.embedded-brains.de)
>  .. Copyright (C) 1988, 1998 On-Line Applications Research Corporation
> (OAR)
> @@ -16,6 +17,14 @@ Glossary
>          A term used to describe an object which has been created by an
>          application.
> +    APA
> +        This term is an acronym for Arbitrary Processor Affinity.
> +        APA schedulers allow a thread to have an arbitrary affinity to a
> +        processor set, rather than a restricted mapping to only one
> processor
> +        of the set or the ability to run on all processors of the set.
> +        It has two variants, :term:`Weak APA` and :term:`Strong APA`.
>      aperiodic task
>          A task which must execute only at irregular intervals and has
> only a soft
>          deadline.
> @@ -777,6 +786,20 @@ Glossary
>          :term:`return value` to indicate a successful operation or error
>          conditions.
> +    Strong APA
> +        Strong APA is a specialization of :term:`APA`.
> +        Schedulers which implement strong APA recursively search for a
> +        processor in the :term:`thread`'s affinity set, whenever a thread
> +        becomes ready for execution, followed by the processors in the
> +        affinity set of threads that are assigned the processor in the
> +        ready thread's affinity set. This is done to find a thread to
> +        processor mapping that does not violate the priority ordering and
> +        to provide a thread to processor mapping with a higher total
> +        priority of the threads allocated a processor.
> +        Similar analysis is done when a thread blocks.
> +        See also :cite:`Cerqueira:2014:LPA`.
>      suspend
>          A term used to describe a task that is not competing for the CPU
> because it
>          has had a ``rtems_task_suspend`` directive.
> @@ -905,6 +928,17 @@ Glossary
>          Message queues, regions, and semaphores have a wait queue
> associated with
>          them.
> +    Weak APA
> +        Weak APA is a specialization of :term:`APA`.
> +        It refers to Linux's push and pull implementation of APA model.
> +        When a :term:`thread` becomes ready for execution, it is
> +        allocated a processor if there is an idle processor, or if a
> +        processor is executing a lower priority thread in its affinity
> +        set. Unlike :term:`Strong APA`, no thread is migrated from its
> +        processor to find a thread to processor mapping.
>      YAML
>          This term is an acronym for `YAML Ain't Markup Language <
> https://yaml.org/>`_.
> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200621/f8cd36ed/attachment.html>
