Documentation of Qualification Toolchain?
Thu Jun 25 05:26:36 UTC 2020
On 24/06/2020 02:48, Chris Johns wrote:
> On 19/6/20 11:38 pm, Sebastian Huber wrote:
>> the qualification toolchain in
>> https://git.rtems.org/sebh/rtems-qual.git/
>> needs a bit of documentation. For a start, I propose to add it to the
>> RTEMS Software Engineering manual.
> Does this mean adding references to that repo?
Yes, I already added a how-to section for the glossary of terms:
https://docs.rtems.org/branches/master/eng/req/howto.html
> I am not comfortable with the name of the repo and documenting a
> personal repo is something we should avoid.
Yes, the name is not great. I think your proposal to name it
rtems-central was a bit better. Another option is rtems-spec.
> I see the name rtems-qual.git as the project or outcome name that is
> currently undersay and not what it is. If a core developer does not
> need to use this repo to maintain RTEMS and that work can be qualified
> what role does it perform? If it is simpler and easier for a core
> developer to use this repo then this is not about qualification it is
> about development of RTEMS that can be qualified.
> I would like to understand the intended workflow for this repo. Is
> something we should promote as the developer workflow? If so we should
> consider embracing this. For example the glossary generation. Editing
> by hand the generated output does not make sense to me.
The stuff in this repository is already somewhat useful to maintain
RTEMS. You can generate the glossary of terms for individual documents
from a shared collection of terms. In the RTEMS Classic API Guide the
project-wide glossary is located, other documents only include the terms
they use in their glossary. All the application configuration options
are available as specification items:
https://docs.rtems.org/branches/master/eng/req/items.html#spectypeapplicationconfigurationoptionitemtype
All the sections about application configuration options in the RTEMS
Classic API Guide are generated from them. With a bit of work, we could
also generate pages for the Doxygen documentation. The tool chain
supports context-sensitive substitution. In the specification a
${uid:attribute/path} syntax is used. For example:
   * The ${../attr/multiprocessor-resource-sharing:/name} attribute
selects the
     MrsP locking protocol in SMP configurations, otherwise it selects the
     priority ceiling protocol.  For this locking protocol a priority
ceiling
     shall be specified in ``${.:/params[3]/name}``.  This priority is
used to set
     the priority ceiling in all scheduler instances.  This can be
changed later
     with the ${set-priority:/name} directive using the returned semaphore
     identifier.
In the Sphinx output this is transformed to:
     * The RTEMS_MULTIPROCESSOR_RESOURCE_SHARING attribute selects the MrsP
priority
       ceiling protocol.  For this locking protocol a priority ceiling
shall be
       specified in ``priority_ceiling``.  This priority is used to set the
       priority ceiling in all scheduler instances.  This can be changed
later
       with the :ref:`rtems_semaphore_set_priority()
       <InterfaceRtemsSemaphoreSetPriority>` directive using the returned
       semaphore identifier.
In the Doxygen output this is transformed to:
  * * The #RTEMS_MULTIPROCESSOR_RESOURCE_SHARING attribute selects the MrsP
  *   locking protocol in SMP configurations, otherwise it selects the
priority
  *   ceiling protocol.  For this locking protocol a priority ceiling
shall be
  *   specified in ``priority_ceiling``.  This priority is used to set the
  *   priority ceiling in all scheduler instances.  This can be changed
later
  *   with the rtems_semaphore_set_priority() directive using the returned
  *   semaphore identifier.
I work currently on a complete specification of the RTEMS Classic API.
The tool chain has also support for test plan and code generation. I
plan to specify the functionality of the RTEMS directives through so
called action requirements:
https://docs.rtems.org/branches/master/eng/req/items.html#spectypeactionrequirementitemtype
This can be used to generate table based test loops to check all states
of pre-conditions and post-conditions (see attached file).
> I have a concern about the long term maintenance of a git repo of git
> repos. I know of a project that have developed tools to handle
> something like this because it is hard to do manually. Maybe we should
> find out more about this.
Which long term maintenance issues do you see? Working with Git
submodules can be a bit annoying, however, the rate of change will not
be that high in this project.
Type: text/x-csrc
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200625/8dcc7fb5/attachment-0001.bin>
