RTEMS 6
Fri Jun 26 18:11:36 UTC 2020
Hello,
in the rtems-release repository we have a rtems-notes-5.txt file. Should
I already add an rtems-notes-6.txt so that we can build up this file
already during the development cycle?
Should I prepare a GCC 10 based RTEMS 6 tool chain now? This will
require a couple of GCC machine option changes for powerpc and arm.
Should we remove the obsolete architectures and BSPs before or after the
build system integration?
