RTEMS 5 has branch
Sebastian Huber
Fri Jun 26 18:20:20 UTC 2020
On 26/06/2020 07:18, Chris Johns wrote:
> If a patch is pushed to any of the release repos that changes a
> version number there needs to be a patch for the engineering manual
> that documents the change. I would like to collection all the changes
> that need to be made post branching. I am currently working on
> updating the release procedure section to provide a suitable location
> for these additions.
Is there already a script to change the version? If not, should we add one?
One option would be to add it to the rtems-qual repository and use these
three items as the master data:
https://git.rtems.org/sebh/rtems.git/tree/spec/build/cpukit/optvermaj.yml?h=build
https://git.rtems.org/sebh/rtems.git/tree/spec/build/cpukit/optvermin.yml?h=build
https://git.rtems.org/sebh/rtems.git/tree/spec/build/cpukit/optverrev.yml?h=build
All the release repositories need to be added added as submodules (RSB,
rtems, rtems-docs) is already there.
