Offset locations of registers in ARM context-switch code
Utkarsh Rai
utkarsh.rai60 at gmail.com
Sat Jun 27 17:02:36 UTC 2020
Hello,
The 'Context_Control' structure in score/.../arm/cpu.h has registers and
attributes that need to be saved during context-switching.
Some of these registers/attributes are conditionally compiled depending
upon the mode in which the processor is running. The registers are saved by
'ldr' instruction by providing proper offset form the context-control base
address. These offsets are dependent on the mode for which the compilation
is done.
For example, the 'is_executing' attribute has the following offset,
depending on various modes.
#ifdef RTEMS_SMP
#if defined(ARM_MULTILIB_VFP)
#define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 112
#elif defined(ARM_MULTILIB_HAS_THREAD_ID_REGISTER)
#define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 48
#else
#define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 44
#endif
#endif ''
My question is, what are the modes for which different registers in the
context control structure are compiled?
This is important to me as I have added a protected stack attribute to the
structure and I need to define a similar offset for this depending upon the
cpu mode.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200627/7bf55811/attachment.html>
