Offset locations of registers in ARM context-switch code
Sat Jun 27 17:21:52 UTC 2020
On 27/06/2020 19:02, Utkarsh Rai wrote:
> The 'Context_Control' structure in score/.../arm/cpu.h has registers
> and attributes that need to be saved during context-switching.
> Some of these registers/attributes are conditionally compiled
> depending upon the mode in which the processor is running. The
> registers are saved by 'ldr' instruction by providing proper offset
> form the context-control base address. These offsets are dependent on
> the mode for which the compilation is done.
> For example, the 'is_executing' attribute has the following offset,
> depending on various modes.
> #ifdef RTEMS_SMP
>   #if defined(ARM_MULTILIB_VFP)
>     #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 112
>   #elif defined(ARM_MULTILIB_HAS_THREAD_ID_REGISTER)
>     #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 48
>   #else
>     #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 44
>   #endif
> #endif ''
> My question is, what are the modes for which different registers in
> the context control structure are compiled?
If you don't need new variants, then the defines you see in the header
file are the relevant ones.
