RTEMS 6
Mon Jun 29 05:21:22 UTC 2020
On 27/06/2020 23:34, Joel Sherrill wrote:
>     Should I prepare a GCC 10 based RTEMS 6 tool chain now? This will
>     require a couple of GCC machine option changes for powerpc and arm.
> Are you killing spe BSPs?
Yes and powerpc/virtex (not powerpc/virtex5):
https://devel.rtems.org/ticket/3550
https://devel.rtems.org/ticket/3951
>     Should we remove the obsolete architectures and BSPs before or
>     after the
>     build system integration?
> Epiphany is the only architecture I know that had taken to tier 4 and
> removal discussed. What else do you have in mind and why?
Only epiphany and powerpcspe.
https://devel.rtems.org/ticket/3941
Some cleanup of m32c:
https://devel.rtems.org/ticket/3613
