RTEMS 6
Mon Jun 29 15:21:00 UTC 2020
On Sun, Jun 28, 2020 at 11:21 PM Sebastian Huber
> On 27/06/2020 23:34, Joel Sherrill wrote:
> >     Should I prepare a GCC 10 based RTEMS 6 tool chain now? This will
> >     require a couple of GCC machine option changes for powerpc and arm.
> > Are you killing spe BSPs?
> Yes and powerpc/virtex (not powerpc/virtex5):
> https://devel.rtems.org/ticket/3550
> https://devel.rtems.org/ticket/3951
> >     Should we remove the obsolete architectures and BSPs before or
> >     after the
> >     build system integration?
> > Epiphany is the only architecture I know that had taken to tier 4 and
> > removal discussed. What else do you have in mind and why?
> Only epiphany and powerpcspe.
> https://devel.rtems.org/ticket/3941
> Some cleanup of m32c:
> https://devel.rtems.org/ticket/3613
I also remember some discussion about superh.
> devel mailing list
> devel at rtems.org
