[PATCH] posix: Only check shm_unlink obj_err if necessary
Gedare Bloom
gedare at rtems.org
Mon Jun 29 17:31:56 UTC 2020
This looks fine for someone to push to master, along with the other one for 5.1
On Tue, Jan 28, 2020 at 11:37 AM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> In the nominal case checked by spsysinit01, obj_err is unmodified if
> _POSIX_Shm_Get_by_name returns non-NULL. In the case of shm_unlink, this
> means an uninitialized value is passed into the switch and it appears
> this test was passing by virtue of the stack having the right value on
> it in most cases. This now checks obj_err only if _POSIX_Shm_Get_by_name
> returns NULL.
> cpukit/posix/src/shmunlink.c | 45 ++++++++++++++++++------------------
> 1 file changed, 23 insertions(+), 22 deletions(-)
> diff --git a/cpukit/posix/src/shmunlink.c b/cpukit/posix/src/shmunlink.c
> index 00d743ac80..39c2ba0d87 100644
> --- a/cpukit/posix/src/shmunlink.c
> +++ b/cpukit/posix/src/shmunlink.c
> @@ -29,28 +29,29 @@ int shm_unlink( const char *name )
> _Objects_Allocator_lock();
> shm = _POSIX_Shm_Get_by_name( name, 0, &obj_err );
> - switch ( obj_err ) {
> - case OBJECTS_GET_BY_NAME_INVALID_NAME:
> - err = ENOENT;
> - break;
> - case OBJECTS_GET_BY_NAME_NAME_TOO_LONG:
> - err = ENAMETOOLONG;
> - break;
> - case OBJECTS_GET_BY_NAME_NO_OBJECT:
> - default:
> - _Objects_Namespace_remove_string(
> - &_POSIX_Shm_Information,
> - &shm->Object
> - if ( shm->reference_count == 0 ) {
> - /* Only remove the shm object if no references exist to it. Otherwise,
> - * the shm object will be freed later in _POSIX_Shm_Attempt_delete */
> - _POSIX_Shm_Free( shm );
> - break;
> + if ( shm ) {
> + _Objects_Namespace_remove_string(
> + &_POSIX_Shm_Information,
> + &shm->Object
> + if ( shm->reference_count == 0 ) {
> + /* Only remove the shm object if no references exist to it. Otherwise,
> + * the shm object will be freed later in _POSIX_Shm_Attempt_delete */
> + _POSIX_Shm_Free( shm );
> + } else {
> + switch ( obj_err ) {
> + case OBJECTS_GET_BY_NAME_NAME_TOO_LONG:
> + err = ENAMETOOLONG;
> + break;
> + case OBJECTS_GET_BY_NAME_INVALID_NAME:
> + case OBJECTS_GET_BY_NAME_NO_OBJECT:
> + default:
> + err = ENOENT;
> + break;
> _Objects_Allocator_unlock();
> 2.20.1
> devel mailing list
> devel at rtems.org
