NEW BUILD SYSTEM: Cannot build rtems-libbsd
Niteesh G. S.
niteesh.gs at gmail.com
Mon Jun 29 19:39:48 UTC 2020
Hello,
I tried compiling RTEMS-libBSD with RTEMS6 toolchain and the new build
system
but failed. I get errors when compiling RTEMS-libBSD
The new build system is pulled from Sebastian's branch
HEAD: e4c193ddc163d6adb1b003254af9cc6b5d174a6f
RTEMS was configured with the following options:
1) ./waf bsp_defaults --rtems-bsps=arm/beagleboneblack > config.ini
2) Enabled posix since libBSD complained about it during configuration.
3) ./waf configure --prefix=$HOME/development/rtems/6
4) ./waf -j32
5) ./waf install
RTEMS-libBSD was configured with the following options:
1) ./waf configure --prefix=$HOME/development/rtems/6
--rtems-bsps=arm/beagleboneblack --buildset=buildset/minimal.ini
--rtems-version=6
2) ./waf -j16
I have attached the error log file.
Thanks,
Niteesh
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200630/0580b6a0/attachment-0001.html>
Waf: Entering directory `/home/niteesh/development/rtems/rtems-libbsd/build/arm-rtems6-beagleboneblack-minimal'
[1060/1184] Linking build/arm-rtems6-beagleboneblack-minimal/arphole.exe
[1064/1184] Linking build/arm-rtems6-beagleboneblack-minimal/cdev01.exe
[1065/1184] Linking build/arm-rtems6-beagleboneblack-minimal/commands01.exe
[1067/1184] Linking build/arm-rtems6-beagleboneblack-minimal/condvar01.exe
[1069/1184] Linking build/arm-rtems6-beagleboneblack-minimal/crypto01.exe
[1071/1184] Linking build/arm-rtems6-beagleboneblack-minimal/dhcpcd01.exe
[1073/1184] Linking build/arm-rtems6-beagleboneblack-minimal/dhcpcd02.exe
[1082/1184] Linking build/arm-rtems6-beagleboneblack-minimal/epoch01.exe
[1085/1184] Linking build/arm-rtems6-beagleboneblack-minimal/evdev01.exe
[1087/1184] Linking build/arm-rtems6-beagleboneblack-minimal/foobarclient.exe
[1088/1184] Linking build/arm-rtems6-beagleboneblack-minimal/foobarserver.exe
[1090/1184] Linking build/arm-rtems6-beagleboneblack-minimal/ftpd01.exe
[1107/1184] Linking build/arm-rtems6-beagleboneblack-minimal/ftpd02.exe
[1144/1184] Linking build/arm-rtems6-beagleboneblack-minimal/init01.exe
[1145/1184] Linking build/arm-rtems6-beagleboneblack-minimal/ipsec01.exe
[1146/1184] Linking build/arm-rtems6-beagleboneblack-minimal/lagg01.exe
[1147/1184] Linking build/arm-rtems6-beagleboneblack-minimal/log01.exe
[1148/1184] Linking build/arm-rtems6-beagleboneblack-minimal/loopback01.exe
[1149/1184] Linking build/arm-rtems6-beagleboneblack-minimal/media01.exe
[1150/1184] Linking build/arm-rtems6-beagleboneblack-minimal/mutex01.exe
[1151/1184] Linking build/arm-rtems6-beagleboneblack-minimal/netshell01.exe
[1152/1184] Linking build/arm-rtems6-beagleboneblack-minimal/nfs01.exe
[1153/1184] Linking build/arm-rtems6-beagleboneblack-minimal/openssl01.exe
[1154/1184] Linking build/arm-rtems6-beagleboneblack-minimal/openssl02.exe
[1155/1184] Linking build/arm-rtems6-beagleboneblack-minimal/pf01.exe
[1156/1184] Linking build/arm-rtems6-beagleboneblack-minimal/pf02.exe
[1157/1184] Linking build/arm-rtems6-beagleboneblack-minimal/ping01.exe
[1158/1184] Linking build/arm-rtems6-beagleboneblack-minimal/ppp01.exe
[1159/1184] Linking build/arm-rtems6-beagleboneblack-minimal/program01.exe
[1160/1184] Linking build/arm-rtems6-beagleboneblack-minimal/rcconf01.exe
[1161/1184] Linking build/arm-rtems6-beagleboneblack-minimal/rcconf02.exe
[1162/1184] Linking build/arm-rtems6-beagleboneblack-minimal/rwlock01.exe
/home/niteesh/development/rtems/6/lib/gcc/arm-rtems6/10.0.1/../../../../arm-rtems6/bin/ld: ./libbsd.a(uipc_mbuf.c.16.o): in function `m_unmappedtouio':
/home/niteesh/development/rtems/rtems-libbsd/build/arm-rtems6-beagleboneblack-minimal/../../freebsd/sys/kern/uipc_mbuf.c:1813: undefined reference to `PHYS_TO_VM_PAGE'
/home/niteesh/development/rtems/6/lib/gcc/arm-rtems6/10.0.1/../../../../arm-rtems6/bin/ld: /home/niteesh/development/rtems/rtems-libbsd/build/arm-rtems6-beagleboneblack-minimal/../../freebsd/sys/kern/uipc_mbuf.c:1814: undefined reference to `uiomove_fromphys'
collect2: error: ld returned 1 exit status
/home/niteesh/development/rtems/6/lib/gcc/arm-rtems6/10.0.1/../../../../arm-rtems6/bin/ld: testsuite/arphole/test_main.c.45.o: in function `.LANCHOR0':
/home/niteesh/development/rtems/rtems-libbsd/build/arm-rtems6-beagleboneblack-minimal/../../rtemsbsd/include/machine/rtems-bsd-config.h:238: undefined reference to `_bsd_ip6_mroutemodule_sys_init'
/home/niteesh/development/rtems/6/lib/gcc/arm-rtems6/10.0.1/../../../../arm-rtems6/bin/ld: testsuite/dhcpcd01/test_main.c.50.o: in function `.LANCHOR0':
/home/niteesh/development/rtems/6/lib/gcc/arm-rtems6/10.0.1/../../../../arm-rtems6/bin/ld: testsuite/lagg01/test_main.c.60.o: in function `.LANCHOR0':
/home/niteesh/development/rtems/6/lib/gcc/arm-rtems6/10.0.1/../../../../arm-rtems6/bin/ld: testsuite/ping01/test_main.c.71.o: in function `.LANCHOR0':
/home/niteesh/development/rtems/6/lib/gcc/arm-rtems6/10.0.1/../../../../arm-rtems6/bin/ld: testsuite/pf01/test_main.c.69.o: in function `.LANCHOR0':
/home/niteesh/development/rtems/6/lib/gcc/arm-rtems6/10.0.1/../../../../arm-rtems6/bin/ld: testsuite/dhcpcd02/test_main.c.51.o: in function `.LANCHOR0':
/home/niteesh/development/rtems/6/lib/gcc/arm-rtems6/10.0.1/../../../../arm-rtems6/bin/ld: ./libbsd.a(rtems-bsd-init-dhcp.c.16.o):/home/niteesh/development/rtems/rtems-libbsd/build/arm-rtems6-beagleboneblack-minimal/../../rtemsbsd/include/machine/rtems-bsd-config.h:238: undefined reference to `_bsd_ip6_mroutemodule_sys_init'
/home/niteesh/development/rtems/6/lib/gcc/arm-rtems6/10.0.1/../../../../arm-rtems6/bin/ld: testsuite/media01/test_main.c.63.o: in function `.LANCHOR0':
/home/niteesh/development/rtems/6/lib/gcc/arm-rtems6/10.0.1/../../../../arm-rtems6/bin/ld: testsuite/ftpd01/test_main.c.56.o: in function `.LANCHOR0':
/home/niteesh/development/rtems/6/lib/gcc/arm-rtems6/10.0.1/../../../../arm-rtems6/bin/ld: testsuite/pf02/test_main.c.70.o: in function `.LANCHOR0':
/home/niteesh/development/rtems/6/lib/gcc/arm-rtems6/10.0.1/../../../../arm-rtems6/bin/ld: testsuite/nfs01/test_main.c.66.o: in function `.LANCHOR0':
/home/niteesh/development/rtems/6/lib/gcc/arm-rtems6/10.0.1/../../../../arm-rtems6/bin/ld: testsuite/ppp01/test_main.c.72.o: in function `.LANCHOR0':
/home/niteesh/development/rtems/6/lib/gcc/arm-rtems6/10.0.1/../../../../arm-rtems6/bin/ld: testsuite/foobarclient/test_main.c.54.o: in function `.LANCHOR0':
/home/niteesh/development/rtems/6/lib/gcc/arm-rtems6/10.0.1/../../../../arm-rtems6/bin/ld: testsuite/foobarserver/test_main.c.55.o: in function `.LANCHOR0':
Waf: Leaving directory `/home/niteesh/development/rtems/rtems-libbsd/build/arm-rtems6-beagleboneblack-minimal'
Build failed
-> task in 'condvar01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'cdev01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'crypto01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'ipsec01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'log01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'mutex01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'openssl01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'init01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'commands01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'arphole.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'epoch01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'loopback01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'openssl02.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'program01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'rwlock01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'dhcpcd01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'rcconf01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'ftpd02.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'netshell01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'lagg01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'ping01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'pf01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'dhcpcd02.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'evdev01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'media01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'ftpd01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'pf02.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'nfs01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'ppp01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'rcconf02.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'foobarclient.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'foobarserver.exe' failed with exit status 1 (run with -v to display more information)
