NEW BUILD SYSTEM: Cannot build rtems-libbsd
Christian Mauderer
oss at c-mauderer.de
Mon Jun 29 19:42:32 UTC 2020
Hello,
On 29/06/2020 21:39, Niteesh G. S. wrote:
> Hello,
> I tried compiling RTEMS-libBSD with RTEMS6 toolchain and the new build
> system
> but failed. I get errors when compiling RTEMS-libBSD
> The new build system is pulled from Sebastian's branch
> HEAD: e4c193ddc163d6adb1b003254af9cc6b5d174a6f
> RTEMS was configured with the following options:
> 1) ./waf bsp_defaults --rtems-bsps=arm/beagleboneblack > config.ini
> 2) Enabled posix since libBSD complained about it during configuration.
> 3) ./waf configure --prefix=$HOME/development/rtems/6
> 4) ./waf -j32
> 5) ./waf install
> RTEMS-libBSD was configured with the following options:
> 1) ./waf configure --prefix=$HOME/development/rtems/6
> --rtems-bsps=arm/beagleboneblack --buildset=buildset/minimal.ini
> --rtems-version=6
> 2) ./waf -j16
> I have attached the error log file.
> Thanks,
> Niteesh
I assume that for some reason the linker flags are not set correctly. It
seems that -ffunction-sections -fdata-sections isn't set. Sebastian: Is
there some adaption to libbsd necessary to work with the new build
system in RTEMS?
Best regards
Christian
