[PATCH v2] Added APA terms in glossary
Richi Dubey
richidubey at gmail.com
Tue Jun 30 06:10:51 UTC 2020
Hi,
I've also sent in the patch for rtems-qual in another email. Please review
them and let me know if everything looks ok.
Thanks,
Richi.
On Tue, Jun 30, 2020 at 11:35 AM Richi Dubey <richidubey at gmail.com> wrote:
> c-user/glossary.rst | 34 ++++++++++++++++++++++++++++++++++
> 1 file changed, 34 insertions(+)
> diff --git a/c-user/glossary.rst b/c-user/glossary.rst
> index 86350a8..399fb8b 100644
> --- a/c-user/glossary.rst
> +++ b/c-user/glossary.rst
> @@ -1,5 +1,6 @@
> .. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2020 Richi Dubey (richidubey at gmail.com)
> .. Copyright (C) 2017, 2019 embedded brains GmbH (
> http://www.embedded-brains.de)
> .. Copyright (C) 1988, 1998 On-Line Applications Research Corporation
> (OAR)
> @@ -16,6 +17,14 @@ Glossary
> A term used to describe an object which has been created by an
> application.
> + APA
> + This term is an acronym for Arbitrary Processor Affinity.
> + APA schedulers allow a thread to have an arbitrary affinity to a
> + processor set, rather than a restricted mapping to only one
> + processor of the set or the ability to run on all processors of
> + the set.
> + It has two variants, :term:`Weak APA` and :term:`Strong APA`.
> aperiodic task
> A task which must execute only at irregular intervals and has
> only a soft
> deadline.
> @@ -777,6 +786,20 @@ Glossary
> :term:`return value` to indicate a successful operation or error
> conditions.
> + Strong APA
> + Strong APA is a specialization of :term:`APA`.
> + Schedulers which implement strong APA recursively searches for a
> + processor in the :term:`thread`'s affinity set, whenever a thread
> + becomes ready for execution, followed by the processors in the
> + affinity set of threads that are assigned the processor present
> + in the ready thread's affinity set. This is done to find a thread
> + to processor mapping that does not violate the priority ordering
> + and to provide a thread to processor mapping with a higher total
> + priority of the threads allocated a processor. Similar analysis
> + is done when a thread blocks.
> + See also :cite:`Cerqueira:2014:LPA`.
> suspend
> A term used to describe a task that is not competing for the CPU
> because it
> has had a ``rtems_task_suspend`` directive.
> @@ -905,6 +928,17 @@ Glossary
> Message queues, regions, and semaphores have a wait queue
> associated with
> them.
> + Weak APA
> + Weak APA is a specialization of :term:`APA`.
> + This refers to Linux's push and pull implementation of APA model.
> When
> + a :term:`thread` becomes ready for execution, it is allocated a
> + processor if there is an idle processor, or a processor executing
> a
> + lower priority thread in its affinity set. Unlike :term:`Strong
> APA`,
> + no thread is migrated from its processor to find a thread to
> processor
> + mapping.
> YAML
> This term is an acronym for `YAML Ain't Markup Language <
> https://yaml.org/>`_.
> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200630/d69c4693/attachment.html>
