[PATCH v2] Added APA terms in glossary
Tue Jun 30 07:05:00 UTC 2020
On 30/06/2020 08:10, Richi Dubey wrote:
> I've also sent in the patch for rtems-qual in another email. Please
> review them and let me know if everything looks ok.
Sorry for the delay, I checked it in with minor modifications. Please
format text blocks so that they use the minimum amount of vertical
space. You can use the vim "gq" visual command for this. Please make
sure that your patches have no white space at the end of a line.
Applying: Added APA terms in glossary
.git/rebase-apply/patch:25: trailing whitespace.
text:
.git/rebase-apply/patch:29: trailing whitespace.
   of the set or the ability to run on all processors of the set.
.git/rebase-apply/patch:30: trailing whitespace.
.git/rebase-apply/patch:48: trailing whitespace.
text:
.git/rebase-apply/patch:58: trailing whitespace.
warning: squelched 3 whitespace errors
warning: 8 lines add whitespace errors.
