Buildbot success in RTEMS on snapshot-test
Tue Jun 30 15:53:29 UTC 2020
On 30/06/2020 17:41, buildbot at rtems.org wrote:
> The Buildbot has detected a passing build on builder snapshot-test while building rtems.
> Full details are available at:
>      https://buildbot.rtems.org/#builders/4/builds/930
> Buildbot URL: https://buildbot.rtems.org/
> Worker for this Build: build-1
> Build Reason: <unknown>
> Blamelist: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Build succeeded!
> Sincerely,
>   -The Buildbot
I think the Buildbot needs to be updated to use the RTEMS 6 toolchain.
This will currently result in errors since I have to change some
compiler flags on arm and powerpc.
