[PATCH] score: Clarify CPU_USE_LIBC_INIT_FINI_ARRAY option
Tue Jun 30 15:06:01 UTC 2020
thanks, good clarification
On Tue, Jun 30, 2020 at 1:52 AM Sebastian Huber
> Update #4018.
>  cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h | 7 ++++---
>  1 file changed, 4 insertions(+), 3 deletions(-)
> diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
> index 84125aa16b..50313bbd61 100644
> --- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
> @@ -250,9 +250,10 @@ extern "C" {
>  #define CPU_MAXIMUM_PROCESSORS 32
> - * The following define determines whether or not this CPU port will use
> - * libc global constructors and destructors instead of _init/_fini functions
> - * depending on .ctors and .dtors linker sections.
> + * The following define determines whether or not this CPU port will use the C
> + * library support to run the global constructors and destructors on
> + * architectures that use .init_array and .fini_array sections.  If defined to
> + * FALSE, then the _init() and _fini() functions will be used.
>  #define CPU_USE_LIBC_INIT_FINI_ARRAY TRUE
> 2.26.2
> devel mailing list
> devel at rtems.org
