Improve Coverity Scan Integration: GSOC project details
Joel Sherrill
joel at rtems.org
Mon Mar 2 01:31:15 UTC 2020
On Sun, Mar 1, 2020, 1:02 PM suyash singh <suyashsingh234 at gmail.com> wrote:
> This is regarding the project I would like to work in
> https://devel.rtems.org/ticket/3710
> *FIRST POINT-*
> I was thinking about implementing Coverity or clang analyzer as an offline
> analyzer. Would it be a suitable idea to make a separate repo just for
> testing purposes?
> This "testing repository" will have the updated rtems code as well the
> analyzer in it. If possible this repo will be updated automatically from
> the main repo.
I would have to see how the clang analyser is run against the RTEMS source.
My expectation would be that ultimately something would be added to
rtems-tools to run the analysis process and generate reports.
The reports could then be locally generated or run on an rtems.org server
for publication.
I don't see needing a private RTEMS repository. This should be an
rtems-tools project and you would only have a personal copy of that for the
purposes of getting reviews. Usually patches just get submitted and you
don't need a public facing repo at all.
> *SECOND POINT-*
> Using Travis CI for github. I have seen Travis CI checking the build of
> pull requests in other repos.
> Also making a special coverity branch to trigger coverity scan
Amar should comment on this. RTEMS.org is using buildbot.
> *THIRD POINT-*
> Enabling and testing MISRA rules.
Do you know of a free tool that checks Misra C rules? There are closed
source products that do but I don't know of a FLOSS one.
Assuming you have identified a free software tool to do the analysis, the
impact and applicability of each rule to the RTEMS source base needs
evaluation. I know some of the rules we agree with but others we will not
want to adopt. For example, Misra defines a subset of C Library header
files you can include. RTEMS will violate that regularly and intentionally.
> *FOURTH POINT- *
> Reducing false positives.
> I have yet to figure out how to do this one.
> I noticed a pattern where value overwrite errors are given for unused
> values. There is email thread about it with subject "Coverity false
> positive pattern"
If the tool flags a pattern in code incorrectly, then it needs to be
reported to the tool owner.
If there is an intentional violation, then the code may have to be
annotated with an explanation. Also documenting the allowed types of
exceptions is a critical part of the software engineering side of this.
> *FIFTH POINT-*
> Solving reported issues by coverity.
This is always good and as recent traffic on the mailing list has shown is
often more difficult than at first glance.
It is good work and appreciated. Just can't be measured by number of lines
of code since you are usually fixing with a scalpel something subtle
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200301/9337dd02/attachment.html>
