Introducing myself and HelloWorld completion.
Joel Sherrill
joel at rtems.org
Mon Mar 2 17:28:27 UTC 2020
On Mon, Mar 2, 2020 at 11:20 AM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Denil,
> On Mon, Mar 2, 2020 at 10:07 AM Denil Verghese <denilcv3 at gmail.com> wrote:
> > Hi everyone,
> > Myself Denil C Verghese, doing a degree in Bachelors of Technology.
> I'm here because of two reasons. Foremost, I would like to be part of this
> endeavor. Second, I want to be an intern as a part of GSoC.
> Welcome.
> > I have done the hello world program mentioned at the wiki page and I
> have attached the patch file with this mail. I not sure whether it is the
> correct output or not. For some reason, I can't load the simulator by
> executing 'tar sim' in gdb. Hence I used sis command with -gdb argument and
> used 'tar remote:1234' to run the simulator. Is this enough?
> Yes, this is good. Thank you. I received your screenshot proof.
Add yourself to https://devel.rtems.org/wiki/GSoC/2020
> > Thanks to Jiri Gaisler for helping me out with the hello World program.
Were there any documentation issues that need resolving for this?
sis has recently been split out of gdb and there are multiple places
that used sis as the example. It is hard to find them all.
> > I would like to work on RTEMS Release Notes Generator or Improve the SMP
> scheduler with arbitrary processor affinity support. It would be great if
> someone could guide me in selecting the project.
> Great. Those are two quite distinct projects. The "Improve the SMP
> Scheduler" will require strong C programming skills. The "Release
> Notes Generator" would involve Python programming. Depending on which
> language you are stronger in, you might choose to pursue one of them.
Sebastian should comment on the SMP Scheduler Improvements. I
have no idea what he has in mind.
The Release Notes Generator was started a couple of years ago.
Chris Johns knows what's left to make it production worthy.
Start threads on each topic to attract the right mentors attention. :)
> > I'm ready to resolve any mistakes that I may make. Hoping that I would
> get some guidance on how to be a part of this.
> > Thank You,
> > Denil C Verghese
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200302/9f73c53c/attachment.html>
