[PATCH] test for fegetround and fesetround
Gedare Bloom
gedare at rtems.org
Tue Mar 3 11:28:03 UTC 2020
On Mon, Mar 2, 2020 at 11:11 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> On Mon, Mar 2, 2020 at 9:38 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Tue, Feb 25, 2020 at 7:56 AM Eshan dhawan <eshandhawan51 at gmail.com> wrote:
>> > testsuites/psxtests/psxfenv01/init.c | 42 +++++++++++++++++++++++++++-
>> > 1 file changed, 41 insertions(+), 1 deletion(-)
>> > diff --git a/testsuites/psxtests/psxfenv01/init.c b/testsuites/psxtests/psxfenv01/init.c
>> > index 05f3cdc880..4339139c58 100644
>> > --- a/testsuites/psxtests/psxfenv01/init.c
>> > +++ b/testsuites/psxtests/psxfenv01/init.c
>> > @@ -106,7 +106,47 @@ rtems_task Init(rtems_task_argument ignored)
>> > printf("fesetexceptflag ==> 0x%x\n", r);
>> > rtems_test_assert(r == 0);
>> >Similarly, the ability to trigger coverity scan on a
> How to do that, could you guide me through
> thanks
I think this was a copy-paste error in my email client. Ignore it.
>> > + /*test for fegetround() and fesetround()*/
>> add white space around text
>> > + /*they have four main macros to be tested seperated by ifdef*/
>> typo: separated
>> > + /* since all the architectures dont support them */
>> typo: don't
>> grammer: "since not all architectures support them" would be better.
>> "all the architectures don't support them" means there is no support
>> at all.
>> > + /*the test cases gets and sets the rounding directions */
>> typo: case
>> > +#ifdef FE_TONEAREST
>> no blank line needed/wanted after #ifdef statements
>> > + r=fegetround();
>> whitespace needed around =. Please review
>> https://docs.rtems.org/branches/master/eng/coding.html
>> > + if(r)
>> whitespace needed, and brackets needed even for 1-line blocks.
>> > + printf("fegetround ==> 0x%x\n", r);
>> > + rtems_test_assert(r == FE_TONEAREST) ;
>> > +#endif
>> > +#ifdef FE_TOWARDZERO
>> The same errors from above repeat here and below. fix all.
>> > + r=fesetround(FE_TOWARDZERO);
>> > + if(r)
>> > + printf("fesetround ==> 0x%x\n", r);
>> > + rtems_test_assert(r == 0) ;
>> > + rtems_test_assert(fegetround() == FE_TOWARDZERO) ;
>> > +#endif
>> > +#ifdef FE_DOWNWARD
>> > + r=fesetround(FE_DOWNWARD);
>> > + if(r)
>> > + rtems_test_assert(fegetround() == FE_DOWNWARD) ;
>> > +#endif
>> > +#ifdef FE_UPWARD
>> > + r=fesetround(FE_UPWARD);
>> > + if(r)
>> > + rtems_test_assert(fegetround() == FE_UPWARD) ;
>> > +#endif
>> > + r=fesetround(FE_TONEAREST);
>> > + if(r)
>> > +#endif
>> > #ifdef FE_DIVBYZERO
>> > 2.17.1
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
