Introducing myself and HelloWorld completion.
Denil Verghese denilcv3 at gmail.com
Wed Mar 4 01:01:30 UTC 2020
Hi,
> Great. Those are two quite distinct projects. The "Improve the SMP
> Scheduler" will require strong C programming skills. The "Release
> Notes Generator" would involve Python programming. Depending on which
> language you are stronger in, you might choose to pursue one of them.
How can I acquire the required skills to do projects like 'Improve the SMP
Scheduler'. If there is a way that I can learn and work on it, then I would
prefer it over the ' Release Notes Generator' project.
Meanwhile, I have entered to work with the later on GSoC Tracking page.
Thank you.
Denil Verghese
On Mon, Mar 2, 2020 at 10:50 PM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Denil,
> On Mon, Mar 2, 2020 at 10:07 AM Denil Verghese <denilcv3 at gmail.com> wrote:
> > Hi everyone,
> >      Myself Denil C Verghese, doing a degree in Bachelors of Technology.
> I'm here because of two reasons. Foremost, I would like to be part of this
> endeavor. Second, I want to be an intern as a part of GSoC.
> Welcome.
> > I have done the hello world program mentioned at the wiki page and I
> have attached the patch file with this mail. I not sure whether it is the
> correct output or not. For some reason, I can't load the simulator by
> executing 'tar sim' in gdb. Hence I used sis command with -gdb argument and
> used 'tar remote:1234' to run the simulator. Is this enough?
> Yes, this is good. Thank you. I received your screenshot proof.
> > Thanks to Jiri Gaisler for helping me out with the hello World program.
> > I would like to work on RTEMS Release Notes Generator or Improve the SMP
> scheduler with arbitrary processor affinity support. It would be great if
> someone could guide me in selecting the project.
> > I'm ready to resolve any mistakes that I may make. Hoping that I would
> get some guidance on how to be a part of this.
> > Thank You,
> > Denil C Verghese
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200304/a6f8bc2d/attachment.html>
