Waf Build System Status in RTEMS?
Sebastian Huber
Wed Mar 4 08:55:06 UTC 2020
On 25/02/2020 12:54, Sebastian Huber wrote:
> On 25/02/2020 11:00, Hesham Almatary wrote:
>> On Mon, 24 Feb 2020 at 22:50, Chris Johns<chrisj at rtems.org> wrote:
>>> On 21/2/20 11:11 pm, Sebastian Huber wrote:
>>>> On 21/02/2020 12:26, Hesham Almatary wrote:
>>>>> On Fri, 21 Feb 2020 at 11:07, Sebastian Huber
>>>>> <sebastian.huber at embedded-brains.de> wrote:
>>>>>> Hello Hesham,
>>>>>> On 20/02/2020 16:40, Hesham Almatary wrote:
>>>>>>> Hello,
>>>>>>> Are there any progress updates to the Waf build system
>>>>>>> integration in RTEMS?
>>>>>>> I have pulled [1] and it seems like it hasn't got many updates since
>>>>>>> December. I wonder what's still remaining/blocking to merge it,
>>>>>>> or at
>>>>>>> least push it as a development branch (without re-writing history)
>>>>>>> that others, including me, can use it and submit patches against.
>>>>>>> [1] git://git.rtems.org/sebh/rtems.git
>>>>>> technically, the new build system is ready for integration into the
>>>>>> master branch. I would need about one day to rebase and test it
>>>>>> before
>>>>>> the push. The integration is currently blocked since Chris and
>>>>>> Joel had
>>>>>> no time to look at it.
>>>>> Thanks for your input, Sebastian. Is there a recommended branch I
>>>>> should be based on? I noticed there's "build" and "build-next".
>>>> The "build" branch contains the state of the first review. I updated
>>>> "build-next" a couple of times to integrate the changes on the RTEMS
>>>> master.
>>>>> Do you intend to re-write git history in either?
>>>> Yes, when I started with the build system work I didn't expect a
>>>> more than two
>>>> months review period.
>>> I have discussed this merge with Joel. We have decided to release
>>> RTEMS 5 before
>>> we merge a new build system. A release with parallel build systems is
>>> confusing
>>> and distracting.
>> That makes sense to me. I think we should both try to push for an
>> RTEMS release soon, and make the waf/build
>> branch more stable and/or in the view (e.g., push as an experimental
>> branch) for developer to use until a release comes out. I understand
>> another branch would incur more maintaibility efforts, but it will
>> also help make the the new build system more usable.
> I can do a forced update of the "build" branch with my latest version
> based on rebase of the current master by the end of the week.
> Afterwards, I can do merges from the master instead of forced pushes.
> This should enable you to base your work on this branch. You can also
> send me patches.
> Before the new build system is integrated in the master, I will do a
> final rebase to the master and squash commits.
I did a forced push to the build branch today. It is based on the master
branch commit:
https://git.rtems.org/rtems/commit/?id=fa3005f6c1ddb99347acb70cbaecd155ed0356ed
I will not do another forced push to the build branch in the future and
instead do merges from the master to the build branch. I hope this helps
to use it for experimental work. After the RTEMS 5 release when the new
build system is ready to get integrated I will do a rebase and squash
the commits before I push them to the master.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
