Waf Build System Status in RTEMS?
Hesham Almatary
heshamelmatary at gmail.com
Wed Mar 4 12:51:13 UTC 2020
On Wed, 4 Mar 2020 at 08:55, Sebastian Huber
> On 25/02/2020 12:54, Sebastian Huber wrote:
> > On 25/02/2020 11:00, Hesham Almatary wrote:
> >> On Mon, 24 Feb 2020 at 22:50, Chris Johns<chrisj at rtems.org> wrote:
> >>> On 21/2/20 11:11 pm, Sebastian Huber wrote:
> >>>> On 21/02/2020 12:26, Hesham Almatary wrote:
> >>>>> On Fri, 21 Feb 2020 at 11:07, Sebastian Huber
> >>>>>> Hello Hesham,
> >>>>>> On 20/02/2020 16:40, Hesham Almatary wrote:
> >>>>>>> Hello,
> >>>>>>> Are there any progress updates to the Waf build system
> >>>>>>> integration in RTEMS?
> >>>>>>> I have pulled [1] and it seems like it hasn't got many updates since
> >>>>>>> December. I wonder what's still remaining/blocking to merge it,
> >>>>>>> or at
> >>>>>>> least push it as a development branch (without re-writing history)
> >>>>>>> that others, including me, can use it and submit patches against.
> >>>>>>> [1] git://git.rtems.org/sebh/rtems.git
> >>>>>> technically, the new build system is ready for integration into the
> >>>>>> master branch. I would need about one day to rebase and test it
> >>>>>> before
> >>>>>> the push. The integration is currently blocked since Chris and
> >>>>>> Joel had
> >>>>>> no time to look at it.
> >>>>> Thanks for your input, Sebastian. Is there a recommended branch I
> >>>>> should be based on? I noticed there's "build" and "build-next".
> >>>> The "build" branch contains the state of the first review. I updated
> >>>> "build-next" a couple of times to integrate the changes on the RTEMS
> >>>> master.
> >>>>> Do you intend to re-write git history in either?
> >>>> Yes, when I started with the build system work I didn't expect a
> >>>> more than two
> >>>> months review period.
> >>> I have discussed this merge with Joel. We have decided to release
> >>> RTEMS 5 before
> >>> we merge a new build system. A release with parallel build systems is
> >>> confusing
> >>> and distracting.
> >> That makes sense to me. I think we should both try to push for an
> >> RTEMS release soon, and make the waf/build
> >> branch more stable and/or in the view (e.g., push as an experimental
> >> branch) for developer to use until a release comes out. I understand
> >> another branch would incur more maintaibility efforts, but it will
> >> also help make the the new build system more usable.
> > I can do a forced update of the "build" branch with my latest version
> > based on rebase of the current master by the end of the week.
> > Afterwards, I can do merges from the master instead of forced pushes.
> > This should enable you to base your work on this branch. You can also
> > send me patches.
> > Before the new build system is integrated in the master, I will do a
> > final rebase to the master and squash commits.
> I did a forced push to the build branch today. It is based on the master
> branch commit:
> https://git.rtems.org/rtems/commit/?id=fa3005f6c1ddb99347acb70cbaecd155ed0356ed
> I will not do another forced push to the build branch in the future and
> instead do merges from the master to the build branch. I hope this helps
> to use it for experimental work. After the RTEMS 5 release when the new
> build system is ready to get integrated I will do a rebase and squash
> the commits before I push them to the master.
That will definitely make my life easier. Thanks, Sebastian!
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
Hesham
