[PATCH 1/4] Remove EOL whitespace.
Wed Mar 4 23:33:03 UTC 2020
I am ok for these to be pushed. Thank you for adding this command. It is a big
help for hosts that are not Linux.
Please consider a change to update the RSB's tool commit reference and checksum
as approved. The file is ...
https://git.rtems.org/rtems-source-builder/tree/rtems/config/tools/rtems-tools-5-1.cfg
On 5/3/20 10:09 am, Amar Takhar wrote:
>  misc/tools/mkimage.py | 42 +++++++++++++++++++++---------------------
>  1 file changed, 21 insertions(+), 21 deletions(-)
> diff --git a/misc/tools/mkimage.py b/misc/tools/mkimage.py
> index 39a12a0..2b1524c 100755
> --- a/misc/tools/mkimage.py
> +++ b/misc/tools/mkimage.py
> @@ -2,28 +2,28 @@
>  # A quickly bashed together replacement for u-boot's mkimage written in python
> -# Copyright 2010 Craig Barker
> +# Copyright 2010 Craig Barker
> -# Redistribution and use in source and binary forms, with or without
> +# Redistribution and use in source and binary forms, with or without
>  # modification, are permitted provided that the following conditions are met:
> -# 1. Redistributions of source code must retain the above copyright notice,
> +# 1. Redistributions of source code must retain the above copyright notice,
>  #    this list of conditions and the following disclaimer.
>  # 2. Redistributions in binary form must reproduce the above copyright notice,
>  #    this list of conditions and the following disclaimer in the documentation
>  #    and/or other materials provided with the distribution.
> -# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> -# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> -# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> -# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> -# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> -# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> -# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> -# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> -# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> -# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>  # POSSIBILITY OF SUCH DAMAGE.
> @@ -55,7 +55,7 @@ comps = {'none':0, 'bzip2':2, 'gzip':1, 'lzma':3 }
>  usage = "usage: %prog [options] image"
>  parser = OptionParser(usage=usage)
> -parser.add_option("-A","--arch", dest="arch", default="powerpc",
> +parser.add_option("-A","--arch", dest="arch", default="powerpc",
>                    help="set architecture to 'arch'", metavar="ARCH")
>  parser.add_option("-O","--os", dest="os", default="linux",
>                    help="set operating system to 'os'", metavar="OS")
> @@ -78,21 +78,21 @@ parser.add_option("-x","--xip", action="store_true", dest="xip", default=False,
>  if len(args) != 1: parser.print_help()
> -if options.arch not in archs:
> +if options.arch not in archs:
>          print "Invalid architecture specified, aborting"
>          sys.exit(2)
>  if options.os not in oss:
>          print "Invalid operating system specified, aborting"
> -        sys.exit(2)
> +        sys.exit(2)
>  if options.comp not in comps:
>          print "Invalid compression specified, aborting"
> -        sys.exit(2)
> +        sys.exit(2)
>  if options.type not in types:
>          print "Invalid image type specified, aborting"
> -        sys.exit(2)
> +        sys.exit(2)
>  try:
>          inputsize = os.path.getsize(options.datafile)
> @@ -123,9 +123,9 @@ while True:
>  inputcrc = inputcrc & 0xffffffff
> -structdata = struct.pack(MAGIC, 0, int(time.time()), inputsize,
> -                int(options.addr,16), int(options.ep,16), inputcrc,
> -                oss[options.os], archs[options.arch], types[options.type],
> +structdata = struct.pack(MAGIC, 0, int(time.time()), inputsize,
> +                int(options.addr,16), int(options.ep,16), inputcrc,
> +                oss[options.os], archs[options.arch], types[options.type],
>                  comps[options.comp], options.name)
>  headercrc = binascii.crc32(structdata) & 0xFFFFFFFF
