[PATCH 2/4] Convert optparse to argparse.
Amar Takhar
amar at rtems.org
Wed Mar 4 23:09:40 UTC 2020
* Fix exceptions and print exception message.
* Also add myself to copyright.
misc/tools/mkimage.py | 42 ++++++++++++++++++++++--------------------
1 file changed, 22 insertions(+), 20 deletions(-)
diff --git a/misc/tools/mkimage.py b/misc/tools/mkimage.py
index 2b1524c..0845ee4 100755
--- a/misc/tools/mkimage.py
+++ b/misc/tools/mkimage.py
@@ -3,6 +3,7 @@
# A quickly bashed together replacement for u-boot's mkimage written in python
# Copyright 2010 Craig Barker
+# Copyright 2020 Amar Takhar <amar at rtems.org>
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are met:
@@ -27,7 +28,7 @@
# POSSIBILITY OF SUCH DAMAGE.
-from optparse import OptionParser
+import argparse
from struct import *
import sys
import os.path
@@ -53,30 +54,31 @@ types = {'invalid':0, 'standalone':1, 'kernel':2, 'ramdisk':3, 'multi':4,
comps = {'none':0, 'bzip2':2, 'gzip':1, 'lzma':3 }
-usage = "usage: %prog [options] image"
-parser = OptionParser(usage=usage)
-parser.add_option("-A","--arch", dest="arch", default="powerpc",
+parser = argparse.ArgumentParser()
+parser.add_argument("-A","--arch", dest="arch", default="powerpc",
help="set architecture to 'arch'", metavar="ARCH")
-parser.add_option("-O","--os", dest="os", default="linux",
+parser.add_argument("-O","--os", dest="os", default="linux",
help="set operating system to 'os'", metavar="OS")
-parser.add_option("-T","--type", dest="type", default="kernel",
+parser.add_argument("-T","--type", dest="type", default="kernel",
help="set image type to 'type'", metavar="TYPE")
-parser.add_option("-C","--comp", dest="comp", default="gzip",
+parser.add_argument("-C","--comp", dest="comp", default="gzip",
help="set compression type 'comp'", metavar="COMP")
-parser.add_option("-a","--addr", dest="addr", default="0",
+parser.add_argument("-a","--addr", dest="addr", default="0",
help="set load address to 'addr' (hex)", metavar="ADDR")
-parser.add_option("-e","--ep", dest="ep", default="0",
+parser.add_argument("-e","--ep", dest="ep", default="0",
help="set entry point to 'ep' (hex)", metavar="EP")
-parser.add_option("-n","--name", dest="name", default="",
+parser.add_argument("-n","--name", dest="name", default="",
help="set image name to 'name'", metavar="NAME")
-parser.add_option("-d","--datafile", dest="datafile",
- help="use image data from 'datafile'", metavar="DATAFILE")
-parser.add_option("-x","--xip", action="store_true", dest="xip", default=False,
+parser.add_argument("-d","--datafile", dest="datafile",
+ help="use image data from 'datafile'", metavar="DATAFILE", required=True)
+parser.add_argument("-x","--xip", action="store_true", dest="xip", default=False,
help="set XIP (execute in place)")
+parser.add_argument("outputfile",
+ help="Output file.", metavar="OUTPUTFILE")
-(options, args) = parser.parse_args()
-if len(args) != 1: parser.print_help()
+options = parser.parse_args()
if options.arch not in archs:
print "Invalid architecture specified, aborting"
@@ -98,15 +100,15 @@ try:
inputsize = os.path.getsize(options.datafile)
inputfile = open(options.datafile, 'rb')
-except IOError:
- print "Invalid datafile specified, aborting"
+except OSError as e:
+ print "Invalid datafile specified, aborting: %s" % e
sys.exit(2)
try:
- outputfile = open(args[0],'wb')
+ outputfile = open(options.outputfile,'wb')
-except IOError:
- print "Error opening output file for writing, aborting"
+except IOError as e:
+ print "Error opening output file for writing, aborting: %s" % e
sys.exit(1)
struct = Struct("!IIIIIIIBBBB"+str(IMG_NAME_LENGTH)+"s")
2.25.0
