[PATCH] Bump RSB to the latest rtems-tools to get mkimage.py
Amar Takhar amar at rtems.org
Thu Mar 5 00:01:21 UTC 2020
 rtems/config/tools/rtems-tools-5-1.cfg | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/rtems/config/tools/rtems-tools-5-1.cfg b/rtems/config/tools/rtems-tools-5-1.cfg
index da22b4c..0c67901 100644
--- a/rtems/config/tools/rtems-tools-5-1.cfg
+++ b/rtems/config/tools/rtems-tools-5-1.cfg
@@ -10,14 +10,14 @@
  %define rtems_tools_source rtems-tools-%{rtems_tools_version}
  %define rtems_tools_ext xz
 %else
- %define rtems_tools_version 4a2f3e5a58978458aabb5098c2c9dd0cc6d25c68
+ %define rtems_tools_version 2444acb0ad35d9f6abd7cf0c1ed8e18a7546a4f6
  %define rtems_tools_ext bz2
 %endif
 %source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
 %hash   sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
-         273a517be396823bec1e9ff5faf52db5f39e4901d8f9bc9fa4724f883a3683ffe2e51004df00bf205b8461f662902d4f1043026bbd88bdd2e2badd0bb0dd8425
+         59ed8573b250356f0bb5ac3810f228426855bc916fb0ede1e8d2b67556267e062fcc92e0bbe5555d7967fdcd546d39d0ef220e5c681f4c5821d3db58b335b696
 # Optionally enable/disable building the RTEMS Tools via the command line.
2.25.0
