[PATCH] Bump RSB to the latest rtems-tools to get mkimage.py
Thu Mar 5 00:02:19 UTC 2020
I think this is OK.
I will bump the newlib hash as soon as my patch to newlib is merged.
--joel
On Wed, Mar 4, 2020 at 6:01 PM Amar Takhar <amar at rtems.org> wrote:
>  rtems/config/tools/rtems-tools-5-1.cfg | 4 ++--
>  1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/rtems/config/tools/rtems-tools-5-1.cfg
> b/rtems/config/tools/rtems-tools-5-1.cfg
> index da22b4c..0c67901 100644
> --- a/rtems/config/tools/rtems-tools-5-1.cfg
> +++ b/rtems/config/tools/rtems-tools-5-1.cfg
> @@ -10,14 +10,14 @@
>   %define rtems_tools_source rtems-tools-%{rtems_tools_version}
>   %define rtems_tools_ext xz
>  %else
> - %define rtems_tools_version 4a2f3e5a58978458aabb5098c2c9dd0cc6d25c68
> + %define rtems_tools_version 2444acb0ad35d9f6abd7cf0c1ed8e18a7546a4f6
>   %define rtems_tools_ext bz2
>  %endif
>  %source set rtems-tools
> https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
>  %hash   sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
>  273a517be396823bec1e9ff5faf52db5f39e4901d8f9bc9fa4724f883a3683ffe2e51004df00bf205b8461f662902d4f1043026bbd88bdd2e2badd0bb0dd8425
>  59ed8573b250356f0bb5ac3810f228426855bc916fb0ede1e8d2b67556267e062fcc92e0bbe5555d7967fdcd546d39d0ef220e5c681f4c5821d3db58b335b696
>  # Optionally enable/disable building the RTEMS Tools via the command line.
> 2.25.0
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200304/b6e2c514/attachment.html>
