[PATCH 2/4] Convert optparse to argparse.
Gedare Bloom
gedare at rtems.org
Thu Mar 5 02:37:53 UTC 2020
Quick note sort copyright lines earlier years below later years.
On Wed, Mar 4, 2020, 4:09 PM Amar Takhar <amar at rtems.org> wrote:
> * Fix exceptions and print exception message.
> * Also add myself to copyright.
> misc/tools/mkimage.py | 42 ++++++++++++++++++++++--------------------
> 1 file changed, 22 insertions(+), 20 deletions(-)
> diff --git a/misc/tools/mkimage.py b/misc/tools/mkimage.py
> index 2b1524c..0845ee4 100755
> --- a/misc/tools/mkimage.py
> +++ b/misc/tools/mkimage.py
> @@ -3,6 +3,7 @@
> # A quickly bashed together replacement for u-boot's mkimage written in
> python
> # Copyright 2010 Craig Barker
> +# Copyright 2020 Amar Takhar <amar at rtems.org>
> # Redistribution and use in source and binary forms, with or without
> # modification, are permitted provided that the following conditions are
> met:
> @@ -27,7 +28,7 @@
> # POSSIBILITY OF SUCH DAMAGE.
> -from optparse import OptionParser
> +import argparse
> from struct import *
> import sys
> import os.path
> @@ -53,30 +54,31 @@ types = {'invalid':0, 'standalone':1, 'kernel':2,
> 'ramdisk':3, 'multi':4,
> comps = {'none':0, 'bzip2':2, 'gzip':1, 'lzma':3 }
> -usage = "usage: %prog [options] image"
> -parser = OptionParser(usage=usage)
> -parser.add_option("-A","--arch", dest="arch", default="powerpc",
> +parser = argparse.ArgumentParser()
> +parser.add_argument("-A","--arch", dest="arch", default="powerpc",
> help="set architecture to 'arch'", metavar="ARCH")
> -parser.add_option("-O","--os", dest="os", default="linux",
> +parser.add_argument("-O","--os", dest="os", default="linux",
> help="set operating system to 'os'", metavar="OS")
> -parser.add_option("-T","--type", dest="type", default="kernel",
> +parser.add_argument("-T","--type", dest="type", default="kernel",
> help="set image type to 'type'", metavar="TYPE")
> -parser.add_option("-C","--comp", dest="comp", default="gzip",
> +parser.add_argument("-C","--comp", dest="comp", default="gzip",
> help="set compression type 'comp'", metavar="COMP")
> -parser.add_option("-a","--addr", dest="addr", default="0",
> +parser.add_argument("-a","--addr", dest="addr", default="0",
> help="set load address to 'addr' (hex)", metavar="ADDR")
> -parser.add_option("-e","--ep", dest="ep", default="0",
> +parser.add_argument("-e","--ep", dest="ep", default="0",
> help="set entry point to 'ep' (hex)", metavar="EP")
> -parser.add_option("-n","--name", dest="name", default="",
> +parser.add_argument("-n","--name", dest="name", default="",
> help="set image name to 'name'", metavar="NAME")
> -parser.add_option("-d","--datafile", dest="datafile",
> - help="use image data from 'datafile'",
> metavar="DATAFILE")
> -parser.add_option("-x","--xip", action="store_true", dest="xip",
> default=False,
> +parser.add_argument("-d","--datafile", dest="datafile",
> + help="use image data from 'datafile'",
> metavar="DATAFILE", required=True)
> +parser.add_argument("-x","--xip", action="store_true", dest="xip",
> default=False,
> help="set XIP (execute in place)")
> +parser.add_argument("outputfile",
> + help="Output file.", metavar="OUTPUTFILE")
> -(options, args) = parser.parse_args()
> -if len(args) != 1: parser.print_help()
> +options = parser.parse_args()
> if options.arch not in archs:
> print "Invalid architecture specified, aborting"
> @@ -98,15 +100,15 @@ try:
> inputsize = os.path.getsize(options.datafile)
> inputfile = open(options.datafile, 'rb')
> -except IOError:
> - print "Invalid datafile specified, aborting"
> +except OSError as e:
> + print "Invalid datafile specified, aborting: %s" % e
> sys.exit(2)
> try:
> - outputfile = open(args[0],'wb')
> + outputfile = open(options.outputfile,'wb')
> -except IOError:
> - print "Error opening output file for writing, aborting"
> +except IOError as e:
> + print "Error opening output file for writing, aborting: %s" % e
> sys.exit(1)
> struct = Struct("!IIIIIIIBBBB"+str(IMG_NAME_LENGTH)+"s")
> 2.25.0
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200304/9a7fa44d/attachment.html>
