[PATCH 2/2] rtemstoolkit: Use multiprocessing.cpu_count()
Sebastian Huber
Thu Mar 5 09:35:05 UTC 2020
The previous implementation does not work on some Linux distributions,
e.g. Debian on sparc64. Use a standard function instead.
rtemstoolkit/linux.py | 16 ++--------------
1 file changed, 2 insertions(+), 14 deletions(-)
diff --git a/rtemstoolkit/linux.py b/rtemstoolkit/linux.py
index 1b55655..21f6f97 100644
--- a/rtemstoolkit/linux.py
+++ b/rtemstoolkit/linux.py
@@ -33,26 +33,14 @@
# RTEMS project's spec files.
+import multiprocessing
import os
import platform
-from rtemstoolkit import execute
from rtemstoolkit import path
def cpus():
- processors = '/bin/grep processor /proc/cpuinfo'
- e = execute.capture_execution()
- exit_code, proc, output = e.shell(processors)
- ncpus = 0
- if exit_code == 0:
- try:
- for l in output.split('\n'):
- count = l.split(':')[1].strip()
- if int(count) > ncpus:
- ncpus = int(count)
- except:
- pass
- return ncpus + 1
+ return multiprocessing.cpu_count()
def overrides():
uname = os.uname()
2.16.4
