[PATCH 1/2] rtemstoolkit: Support more Linux distributions
Thu Mar 5 09:51:15 UTC 2020
All OK to push (with the subject correction).
Thanks
On 2020-03-05 20:35, Sebastian Huber wrote:
> The platform.dist() function is not always available.
>   rtemstoolkit/linux.py | 3 ++-
>   1 file changed, 2 insertions(+), 1 deletion(-)
> diff --git a/rtemstoolkit/linux.py b/rtemstoolkit/linux.py
> index 7e45409..1b55655 100644
> --- a/rtemstoolkit/linux.py
> +++ b/rtemstoolkit/linux.py
> @@ -83,8 +83,9 @@ def overrides():
>       try:
>           distro = platform.dist()[0]
>           distro_ver = float(platform.dist()[1])
> -    except ValueError:
> +    except (AttributeError, ValueError):
>           # Non LSB distro found, use failover"
> +        distro = ''
>           pass
>       # Non LSB - fail over to issue
