[PATCH] waf: Change the test configure check for libdebugger to it's lib
chrisj at rtems.org
chrisj at rtems.org
Thu Mar 5 10:23:15 UTC 2020
- Add support for a 'test-if-library'
- Use rtems_waf's 'test_application()' fragment in the check_cc
call
Closes #3948
builder.py | 30 +++++++++++++++++++++++++++---
libbsd.py | 4 ++--
waf_libbsd.py | 28 +++++++++++++++++++++-------
3 files changed, 50 insertions(+), 12 deletions(-)
diff --git a/builder.py b/builder.py
index 2921bab8..0eda461f 100755
--- a/builder.py
+++ b/builder.py
@@ -505,15 +505,17 @@ class SourceFileIfHeaderComposer(SourceFileFragmentComposer):
class TestFragementComposer(BuildSystemFragmentComposer):
- def __init__(self, testName, fileFragments, runTest = True, netTest = False, extraLibs = []):
+ def __init__(self, testName, fileFragments, configTest = None, runTest = True, netTest = False, extraLibs = []):
self.testName = testName
self.fileFragments = fileFragments
+ self.configTest = configTest
self.runTest = runTest
self.netTest = netTest
self.extraLibs = extraLibs
def compose(self, path):
- return ['tests', self.testName, ('default', None)], { 'files': self.fileFragments,
+ return ['tests', self.testName, ('default', None)], { 'configTest': self.configTest,
+ 'files': self.fileFragments,
'run': self.runTest,
'net': self.netTest,
'libs': self.extraLibs}
@@ -524,7 +526,7 @@ class TestIfHeaderComposer(TestFragementComposer):
if headers is not list:
headers = [headers]
self.headers = headers
- super(TestIfHeaderComposer, self).__init__(testName, fileFragments,
+ super(TestIfHeaderComposer, self).__init__(testName, fileFragments, 'header',
runTest = runTest, netTest = netTest,
extraLibs = extraLibs)
@@ -539,6 +541,27 @@ class TestIfHeaderComposer(TestFragementComposer):
r[0][2] = (define_keys.strip(), self.headers)
return r
+class TestIfLibraryComposer(TestFragementComposer):
+ def __init__(self, testName, libraries, fileFragments, runTest = True, netTest = False, extraLibs = []):
+ if libraries is not list:
+ libraries = [libraries]
+ self.libraries = libraries
+ super(TestIfLibraryComposer, self).__init__(testName, fileFragments, 'library',
+ runTest = runTest, netTest = netTest,
+ extraLibs = extraLibs)
+ def compose(self, path):
+ r = TestFragementComposer.compose(self, path)
+ define_keys = ''
+ for l in self.libraries:
+ l = l.upper()
+ for c in '\/-.':
+ l = l.replace(c, '_')
+ define_keys += ' ' + l
+ r[0][2] = (define_keys.strip(), self.libraries)
+ return r
class KVMSymbolsFragmentComposer(BuildSystemFragmentComposer):
@@ -857,3 +880,4 @@ class ModuleManager(object):
self.generator['source-if-header'] = SourceFileIfHeaderComposer
self.generator['test-if-header'] = TestIfHeaderComposer
+ self.generator['test-if-library'] = TestIfLibraryComposer
diff --git a/libbsd.py b/libbsd.py
index 3823c03f..c2693e20 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -5278,8 +5278,8 @@ class tests(builder.Module):
self.addTest(mm.generator['test']('termios06', ['test_main',
'../termios/test_termios_driver',
'../termios/test_termios_utilities']))
- self.addTest(mm.generator['test-if-header']('debugger01', 'rtems/rtems-debugger.h',
- ['test_main'], runTest = False, netTest = True,
+ self.addTest(mm.generator['test-if-library']('debugger01', 'debugger',
+ ['test_main'], runTest = False, netTest = True,
extraLibs = ['debugger']))
self.addTest(mm.generator['test']('crypto01', ['test_main']))
self.addTest(mm.generator['test']('ipsec01', ['test_main']))
diff --git a/waf_libbsd.py b/waf_libbsd.py
index 84f22b76..e6f3c21c 100644
--- a/waf_libbsd.py
+++ b/waf_libbsd.py
@@ -109,7 +109,10 @@ class Builder(builder.ModuleManager):
if config != 'default':
if 'configure' not in data:
data['configure'] = { }
- data['configure'][config] = frag[0][2][1]
+ configTest = frag[1]['configTest']
+ if configTest not in data['configure']:
+ data['configure'][configTest] = { }
+ data['configure'][configTest][config] = frag[0][2][1]
if type(frag[1]) is list:
if config not in d[cpu]:
d[cpu][config] = []
@@ -149,12 +152,23 @@ class Builder(builder.ModuleManager):
def bsp_configure(self, conf, arch_bsp):
if 'configure' in self.data:
- for cfg in self.data['configure']:
- for h in self.data['configure'][cfg]:
- conf.check(header_name = h,
- features = "c",
- includes = conf.env.IFLAGS,
- mandatory = False)
+ for configTest in self.data['configure']:
+ for cfg in self.data['configure'][configTest]:
+ if configTest == 'header':
+ for h in self.data['configure'][configTest][cfg]:
+ conf.check(header_name = h,
+ features = "c",
+ includes = conf.env.IFLAGS,
+ mandatory = False)
+ elif configTest == 'library':
+ for l in self.data['configure'][configTest][cfg]:
+ conf.check_cc(lib = l,
+ fragment = rtems.test_application(),
+ execute = False,
+ else:
+ bld.fatal('invalid config test: %s' % (configTest))
def build(self, bld):
2.23.0
