rtems-boot-image tool: Raspberry Pi
Christian Mauderer
list at c-mauderer.de
Sun Mar 22 19:53:14 UTC 2020
Hello Niteesh,
thanks for the (private) remainder. This thread really stopped quite
some time ago. A lot of us are quite busy right now but that shouldn't
happen. If you don't get a response for some question: Please give it
about a week of time and then just ping the thread.
On 05/03/2020 11:06, G. S. Niteesh wrote:
> On Wed, Feb 26, 2020 at 8:39 AM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 22/2/20 1:45 am, G. S. Niteesh wrote:
> > Hi,
> > This is regarding adding RPi support to the boot image generation
> tool.
> > The boot process for Raspberry Pi is very unconventional. The GPU
> starts
> > first, initializes RAM, other hardware, loads the bootloaders and
> then starts
> > the ARM CPU.
> > The minimum files that are required to boot an RPi are
> > bootcode.bin, startx.elf, fixup.dat, kernel.img, config.txt
> > There are also other variants of startx.elf and fixup.dat.
> > Please have a look
> at https://www.raspberrypi.org/documentation/configuration/config-txt/boot.md
> > for information on the variants.
> > From what I have tried on my Rpi3 model b v1.2 the minimum files
> that are
> > required are start_x.elf, fixup_x.dat, bootcode.bin, kernel.img,
> config.txt
> > But for this to work, we must add start_x=1 to config.txt because
> by default
> > start.elf is loaded.
> Hello Chris,
> I would have look at how the tool maps to RPi to know if it needs
> more work :)
> Did you take a look at it?
Chris is most likely too busy with the release right now.
> In my opinion, there are two ways to do it.
> The first would be to modify the U-Boot bootloader object to have a
> files field
> to make sure the user provides all the necessary files(fixup.dat,
> startx.elf, config.txt).
> So after this change the rtems-boot.ini for RPI should look something
> like this
> [u-boot-raspberrypi]
> uses = u-boot-arm-raspberrypi
> first_stage = %{ubootdir}/bootcode.bin
> boot_device = mmc 0
> second_stage = uboot or startx
> files = [config.txt, fixup.dat etc]
> But also please keep in mind that if we want to support RPi4 then the
> first_stage
> will start4x.elf since bootcode.bin is now replaced by code in the
> EEPROM in RPi4 SOC.
As far as I understand that approach it more or less tells: To start a
raspberry you need U-Boot. U-Boot needs the fixup.dat, startx.elf and
config.txt to boot. But that sounds a bit wrong. On Raspberry U-Boot is
purely optional, isn't it? So from a high-level view it would be more a
- Raspberry needs fixup.dat, startx.elf and config.txt
- That can start either:
- an application or
- an U-Boot which can then start an application (or do other things)
> Another approach will be to create the default Raspberry Pi bootloader
> object. But having
> support for U-Boot is important since it will allow for automatic testing.
That approach sounds more correct. But I don't really know the
rtems-boot-image tool. That makes it a lot harder for me to tell whether
that approach works well. From that ignorant position I would say that
it would be nice to have a boot-image command that can be called with or
without a option (like --with-u-boot). Alternatively maybe two targets
would be possible. One raspiboot-u-boot-pi1 and one raspiboot-raw-pi1.
But your best bet might is to wait for Chris to get free again and
answer that question. He knows the boot image tool and can tell you a
lot better which concept works best.
Best regards
Christian
> Which one do you think is a better approach?
> Thank you.
> > So, what should be the values for the first and second stages in
> rtems-boot.ini
> > for Rpi?
> Would this be bootcode.bin?
> > And also wouldn't it be nice if we could add a files field, which
> will copy the
> > specified files to the image? This would save a lot of typing in
> case of RPi
> Do you have an example?
> Chris
> devel mailing list
> devel at rtems.org
