[PATCH] waf: Change the test configure check for libdebugger to it's lib
Gedare Bloom
gedare at rtems.org
Thu Mar 5 13:58:58 UTC 2020
On Thu, Mar 5, 2020 at 3:23 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Add support for a 'test-if-library'
> - Use rtems_waf's 'test_application()' fragment in the check_cc
> call
> Closes #3948
> builder.py | 30 +++++++++++++++++++++++++++---
> libbsd.py | 4 ++--
> waf_libbsd.py | 28 +++++++++++++++++++++-------
> 3 files changed, 50 insertions(+), 12 deletions(-)
> diff --git a/builder.py b/builder.py
> index 2921bab8..0eda461f 100755
> --- a/builder.py
> +++ b/builder.py
> @@ -505,15 +505,17 @@ class SourceFileIfHeaderComposer(SourceFileFragmentComposer):
> class TestFragementComposer(BuildSystemFragmentComposer):
> - def __init__(self, testName, fileFragments, runTest = True, netTest = False, extraLibs = []):
> + def __init__(self, testName, fileFragments, configTest = None, runTest = True, netTest = False, extraLibs = []):
I'm trying to pay more attention to the Python code. This method
definition is overlong.
> self.testName = testName
> self.fileFragments = fileFragments
> + self.configTest = configTest
> self.runTest = runTest
> self.netTest = netTest
> self.extraLibs = extraLibs
> def compose(self, path):
> - return ['tests', self.testName, ('default', None)], { 'files': self.fileFragments,
> + return ['tests', self.testName, ('default', None)], { 'configTest': self.configTest,
> + 'files': self.fileFragments,
> 'run': self.runTest,
> 'net': self.netTest,
> 'libs': self.extraLibs}
> @@ -524,7 +526,7 @@ class TestIfHeaderComposer(TestFragementComposer):
> if headers is not list:
> headers = [headers]
> self.headers = headers
> - super(TestIfHeaderComposer, self).__init__(testName, fileFragments,
> + super(TestIfHeaderComposer, self).__init__(testName, fileFragments, 'header',
> runTest = runTest, netTest = netTest,
> extraLibs = extraLibs)
> @@ -539,6 +541,27 @@ class TestIfHeaderComposer(TestFragementComposer):
> r[0][2] = (define_keys.strip(), self.headers)
> return r
> +class TestIfLibraryComposer(TestFragementComposer):
> + def __init__(self, testName, libraries, fileFragments, runTest = True, netTest = False, extraLibs = []):
> + if libraries is not list:
> + libraries = [libraries]
> + self.libraries = libraries
> + super(TestIfLibraryComposer, self).__init__(testName, fileFragments, 'library',
> + runTest = runTest, netTest = netTest,
> + extraLibs = extraLibs)
> + def compose(self, path):
> + r = TestFragementComposer.compose(self, path)
> + define_keys = ''
> + for l in self.libraries:
> + l = l.upper()
> + for c in '\/-.':
> + l = l.replace(c, '_')
> + define_keys += ' ' + l
> + r[0][2] = (define_keys.strip(), self.libraries)
> + return r
> class KVMSymbolsFragmentComposer(BuildSystemFragmentComposer):
> @@ -857,3 +880,4 @@ class ModuleManager(object):
> self.generator['source-if-header'] = SourceFileIfHeaderComposer
> self.generator['test-if-header'] = TestIfHeaderComposer
> + self.generator['test-if-library'] = TestIfLibraryComposer
> diff --git a/libbsd.py b/libbsd.py
> index 3823c03f..c2693e20 100644
> --- a/libbsd.py
> +++ b/libbsd.py
> @@ -5278,8 +5278,8 @@ class tests(builder.Module):
> self.addTest(mm.generator['test']('termios06', ['test_main',
> '../termios/test_termios_driver',
> '../termios/test_termios_utilities']))
> - self.addTest(mm.generator['test-if-header']('debugger01', 'rtems/rtems-debugger.h',
> - ['test_main'], runTest = False, netTest = True,
> + self.addTest(mm.generator['test-if-library']('debugger01', 'debugger',
> + ['test_main'], runTest = False, netTest = True,
> extraLibs = ['debugger']))
> self.addTest(mm.generator['test']('crypto01', ['test_main']))
> self.addTest(mm.generator['test']('ipsec01', ['test_main']))
> diff --git a/waf_libbsd.py b/waf_libbsd.py
> index 84f22b76..e6f3c21c 100644
> --- a/waf_libbsd.py
> +++ b/waf_libbsd.py
> @@ -109,7 +109,10 @@ class Builder(builder.ModuleManager):
> if config != 'default':
> if 'configure' not in data:
> data['configure'] = { }
> - data['configure'][config] = frag[0][2][1]
> + configTest = frag[1]['configTest']
> + if configTest not in data['configure']:
> + data['configure'][configTest] = { }
> + data['configure'][configTest][config] = frag[0][2][1]
> if type(frag[1]) is list:
> if config not in d[cpu]:
> d[cpu][config] = []
> @@ -149,12 +152,23 @@ class Builder(builder.ModuleManager):
> def bsp_configure(self, conf, arch_bsp):
> if 'configure' in self.data:
> - for cfg in self.data['configure']:
> - for h in self.data['configure'][cfg]:
> - conf.check(header_name = h,
> - features = "c",
> - includes = conf.env.IFLAGS,
> - mandatory = False)
> + for configTest in self.data['configure']:
> + for cfg in self.data['configure'][configTest]:
> + if configTest == 'header':
> + for h in self.data['configure'][configTest][cfg]:
> + conf.check(header_name = h,
> + features = "c",
> + includes = conf.env.IFLAGS,
> + mandatory = False)
> + elif configTest == 'library':
> + for l in self.data['configure'][configTest][cfg]:
> + conf.check_cc(lib = l,
> + fragment = rtems.test_application(),
> + execute = False,
> + else:
> + bld.fatal('invalid config test: %s' % (configTest))
> def build(self, bld):
> 2.23.0
> devel mailing list
> devel at rtems.org
