[PATCH] waf: Change the test configure check for libdebugger to it's lib
Sebastian Huber
Thu Mar 5 14:31:00 UTC 2020
On 05/03/2020 14:58, Gedare Bloom wrote:
>> diff --git a/builder.py b/builder.py
>> index 2921bab8..0eda461f 100755
>> --- a/builder.py
>> +++ b/builder.py
>> @@ -505,15 +505,17 @@ class SourceFileIfHeaderComposer(SourceFileFragmentComposer):
>> class TestFragementComposer(BuildSystemFragmentComposer):
>> - def __init__(self, testName, fileFragments, runTest = True, netTest = False, extraLibs = []):
>> + def __init__(self, testName, fileFragments, configTest = None, runTest = True, netTest = False, extraLibs = []):
> I'm trying to pay more attention to the Python code. This method
> definition is overlong.
A GSoC project could be to refactor this stuff to use specification
items similar to the new build system. This could help to get the
import/export feature also in the RTEMS main repository.
It is not easy to understand the current code.
A full set of unit tests for the build system would be also nice. Maybe
also a specification of the build system with traceability.
We also have some open issues:
https://devel.rtems.org/ticket/3846
https://devel.rtems.org/ticket/3847
Performance profiling and improvements are also possible.
This should be enough to keep a student busy for a summer.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
