AW: [PATCH v4 0/3] [rtems-libbsd] Fix compilation for amd64
Jan.Sommer at dlr.de
Thu Mar 5 17:10:21 UTC 2020
Hello,
I am currently working on the backport of the i386 patch set for the 5-freebsd-12 branch (I don't see any use in backporting these amd64 patches).
The question is, if I should use the path-mappings approach introduced with this patch set or keep the "if cpu == i386" which is the current state.
My preference would be to keep it similar in both branches, but I would need to know if this patch set has a chance to be accepted.
Cheers,
Jan
> -----Ursprüngliche Nachricht-----
> Von: devel [mailto:devel-bounces at rtems.org] Im Auftrag von
> Gesendet: Mittwoch, 26. Februar 2020 09:29
> An: devel at rtems.org
> Betreff: AW: [PATCH v4 0/3] [rtems-libbsd] Fix compilation for amd64
> Are there any further comments regarding these patches?
> Is the solution with the "path-mappings" acceptable or do you prefer something
> different?
> Beste regards,
> Jan
> > Von: Sommer, Jan
> > Gesendet: Dienstag, 18. Februar 2020 11:22
> > Cc: Sommer, Jan
> > Betreff: [PATCH v4 0/3] [rtems-libbsd] Fix compilation for amd64
> > Similar to the previous patchset for i386 this one enables compilation for the
> > amd64 BSP with the following limitations:
> > - dev_nic_e1000 needs to be off
> > - debugger01.exe does not link because the amd64 bsp has no libdebugger
> > support
> > I tried to use the lessons learned from the last patch set.
> > It does not seem to affect arm, sparc and i386 compilation.
> > Made a mistake and started to send with v3, so I will increment from
> > there to keep consecutive numbers.
> > Version 4:
> > - Added a path-mapping mechanism to waf_libbsd.py and libbsd.py
> > - Removed the "if cpu == " switches from waf_libbsd.py
> > Best regards,
> > Jan
> > Jan Sommer (3):
> > amd64: Add missing files from FreeBSD
> > amd64: Add to build
> > amd64: Port to RTEMS
> > freebsd/sys/amd64/amd64/in_cksum.c | 245 ++++
> > freebsd/sys/amd64/include/machine/_bus.h | 48 +
> > freebsd/sys/amd64/include/machine/cpufunc.h | 1053
> > freebsd/sys/amd64/include/machine/efi.h | 78 ++
> > freebsd/sys/amd64/include/machine/in_cksum.h | 86 ++
> > freebsd/sys/amd64/include/machine/md_var.h | 90 ++
> > .../sys/amd64/include/machine/specialreg.h | 6 +
> > freebsd/sys/sys/efi.h | 198 ++++
> > libbsd.py | 25 +
> > rtemsbsd/amd64/include/machine/clock.h | 2 +
> > waf_libbsd.py | 13 +-
> > 11 files changed, 1842 insertions(+), 2 deletions(-)
> > create mode 100644 freebsd/sys/amd64/amd64/in_cksum.c
> > create mode 100644 freebsd/sys/amd64/include/machine/_bus.h
> > create mode 100644 freebsd/sys/amd64/include/machine/cpufunc.h
> > create mode 100644 freebsd/sys/amd64/include/machine/efi.h
> > create mode 100644 freebsd/sys/amd64/include/machine/in_cksum.h
> > create mode 100644 freebsd/sys/amd64/include/machine/md_var.h
> > create mode 100644 freebsd/sys/amd64/include/machine/specialreg.h
> > create mode 100644 freebsd/sys/sys/efi.h
> > create mode 100644 rtemsbsd/amd64/include/machine/clock.h
> > 2.17.1
> devel mailing list
> devel at rtems.org
