AW: [PATCH v4 0/3] [rtems-libbsd] Fix compilation for amd64
Chris Johns
chrisj at rtems.org
Fri Mar 6 05:44:34 UTC 2020
On 2020-03-06 04:10, Jan.Sommer at dlr.de wrote:
> I am currently working on the backport of the i386 patch set for the 5-freebsd-12 branch (I don't see any use in backporting these amd64 patches).
Thank you.
> The question is, if I should use the path-mappings approach introduced with this patch set or keep the "if cpu == i386" which is the current state.
> My preference would be to keep it similar in both branches, but I would need to know if this patch set has a chance to be accepted.
I agree lets keep the build system side of things close so backport the
path mapping support. I think it will help when RTEMS 5 is released.
