[PATCH v5] tests for fenv.h functions
Eshan dhawan
eshandhawan51 at gmail.com
Fri Mar 6 07:13:33 UTC 2020
testsuites/psxtests/psxfenv01/init.c | 91 ++++++++++++++++++++++------
1 file changed, 72 insertions(+), 19 deletions(-)
diff --git a/testsuites/psxtests/psxfenv01/init.c b/testsuites/psxtests/psxfenv01/init.c
index cdb0fa596e..82cf3a5fef 100644
--- a/testsuites/psxtests/psxfenv01/init.c
+++ b/testsuites/psxtests/psxfenv01/init.c
@@ -46,11 +46,12 @@
#include <rtems/test.h>
#include <tmacros.h>
+#include <float.h>
const char rtems_test_name[] = "PSXFENV 01";
/* forward declarations to avoid warnings */
-rtems_task Init(rtems_task_argument ignored);
+rtems_task Init( rtems_task_argument ignored );
/* Test Function Begins */
@@ -62,28 +63,31 @@ rtems_task Init(rtems_task_argument ignored)
* 'FE_ALL_EXCEPT' will be defined only when 'feclearexcept()',
- * 'fegetexceptflag()', 'feraiseexcept()', 'fesetexceptflag()' and
- * 'fetestexcept()' functions are supported by the architecture.
+ * fegetexceptflag() , feraiseexcept(), fesetexceptflag() and
+ * fetestexcept() functions are supported by the architecture.
* Hence their testcases can be wrapped under #ifdef and #endif.
#ifdef FE_ALL_EXCEPT /* floating-point exceptions */
puts( "fesetenv(FE_DFL_ENV)." );
- r = fesetenv(FE_DFL_ENV);
- if (r)
+ r = fesetenv ( FE_DFL_ENV );
+ if ( r ) {
printf("fesetenv ==> %d\n", r);
- rtems_test_assert( r == 0 );
+ rtems_test_assert ( r == 0 );
- /* Test 'feclearexcept()' and 'fetestexcept()' in one go. */
- puts( "feclearexcept(FE_ALL_EXCEPT)." );
- r = feclearexcept(FE_ALL_EXCEPT);
- if (r)
+ /* Test feclearexcept() and fetestexcept() in one go. */
+ puts( "feclearexcept(FE_ALL_EXCEPT)" );
+ r = feclearexcept ( FE_ALL_EXCEPT );
+ if ( r ) {
printf("feclearexcept ==> 0x%x\n", r);
- r = fetestexcept( FE_ALL_EXCEPT );
- if (r)
+ r = fetestexcept ( FE_ALL_EXCEPT );
+ if ( r ) {
printf("fetestexcept ==> 0x%x\n", r);
/* Test 'FE_DIVBYZERO' */
puts( "Divide by zero and confirm fetestexcept()" );
@@ -91,11 +95,60 @@ rtems_task Init(rtems_task_argument ignored)
b = 1.0;
c = b/a;
(void) c;
- fegetexceptflag(&excepts,FE_ALL_EXCEPT);
+ /* Test fegetexceptflag() and fesetexceptflag() */
+ r = fegetexceptflag ( &excepts ,FE_ALL_EXCEPT );
+ if ( r ) {
+ printf("fegetexceptflag ==> 0x%x\n", r);
+ r = fesetexceptflag ( &excepts ,FE_ALL_EXCEPT );
+ if ( r ) {
+ printf("fesetexceptflag ==> 0x%x\n", r);
+ /* Test for fegetround() and fesetround()
+ * They have four main macros to be tested separated by ifdef
+ * Since not all architectures support them
+ * The test case gets and sets the rounding directions */
+#ifdef FE_TONEAREST
+ rtems_test_assert ( fegetround() == FE_TONEAREST ) ;
+#endif
+#ifdef FE_TOWARDZERO
+ r = fesetround ( FE_TOWARDZERO ) ;
+ if( r ) {
+ printf("fesetround ==> 0x%x\n", r);
+ rtems_test_assert ( r == 0 ) ;
+ rtems_test_assert ( fegetround() == FE_TOWARDZERO ) ;
+#endif
+#ifdef FE_DOWNWARD
+ r = fesetround ( FE_DOWNWARD );
+ if(r){
+ rtems_test_assert ( fegetround() == FE_DOWNWARD ) ;
+#endif
+#ifdef FE_UPWARD
+ r = fesetround ( FE_UPWARD );
+ if( r ) {
+ rtems_test_assert ( fegetround() == FE_UPWARD ) ;
+#endif
+ r = fesetround ( FE_TONEAREST );
+ if ( r ) {
+#endif
#ifdef FE_DIVBYZERO
- r = feraiseexcept(FE_DIVBYZERO);
+ r = feraiseexcept ( FE_DIVBYZERO ) ;
rtems_test_assert( fetestexcept( FE_DIVBYZERO ) );
#endif
@@ -124,4 +177,4 @@ rtems_task Init(rtems_task_argument ignored)
#define CONFIGURE_INIT
#include <rtems/confdefs.h>
-/* end of file */
+/* end of file */
\ No newline at end of file
2.17.1
