[PATCH v5] tests for fenv.h functions
Gedare Bloom
gedare at rtems.org
Fri Mar 6 19:50:37 UTC 2020
Fix a few small things noted below and send -v6. Almost there.
On Fri, Mar 6, 2020 at 12:13 AM Eshan dhawan <eshandhawan51 at gmail.com> wrote:
> testsuites/psxtests/psxfenv01/init.c | 91 ++++++++++++++++++++++------
> 1 file changed, 72 insertions(+), 19 deletions(-)
> diff --git a/testsuites/psxtests/psxfenv01/init.c b/testsuites/psxtests/psxfenv01/init.c
> index cdb0fa596e..82cf3a5fef 100644
> --- a/testsuites/psxtests/psxfenv01/init.c
> +++ b/testsuites/psxtests/psxfenv01/init.c
> @@ -46,11 +46,12 @@
> #include <string.h>
> #include <rtems/test.h>
> #include <tmacros.h>
> +#include <float.h>
> const char rtems_test_name[] = "PSXFENV 01";
> /* forward declarations to avoid warnings */
> -rtems_task Init(rtems_task_argument ignored);
> +rtems_task Init( rtems_task_argument ignored );
> /* Test Function Begins */
> @@ -62,28 +63,31 @@ rtems_task Init(rtems_task_argument ignored)
> * 'FE_ALL_EXCEPT' will be defined only when 'feclearexcept()',
> - * 'fegetexceptflag()', 'feraiseexcept()', 'fesetexceptflag()' and
> - * 'fetestexcept()' functions are supported by the architecture.
> + * fegetexceptflag() , feraiseexcept(), fesetexceptflag() and
> + * fetestexcept() functions are supported by the architecture.
> * Hence their testcases can be wrapped under #ifdef and #endif.
> #ifdef FE_ALL_EXCEPT /* floating-point exceptions */
> puts( "fesetenv(FE_DFL_ENV)." );
> - r = fesetenv(FE_DFL_ENV);
> - if (r)
> + r = fesetenv ( FE_DFL_ENV );
> + if ( r ) {
> printf("fesetenv ==> %d\n", r);
> - rtems_test_assert( r == 0 );
> + rtems_test_assert ( r == 0 );
> - /* Test 'feclearexcept()' and 'fetestexcept()' in one go. */
> - puts( "feclearexcept(FE_ALL_EXCEPT)." );
> - r = feclearexcept(FE_ALL_EXCEPT);
> - if (r)
> + /* Test feclearexcept() and fetestexcept() in one go. */
> + puts( "feclearexcept(FE_ALL_EXCEPT)" );
> + r = feclearexcept ( FE_ALL_EXCEPT );
> + if ( r ) {
> printf("feclearexcept ==> 0x%x\n", r);
> - r = fetestexcept( FE_ALL_EXCEPT );
> - if (r)
> + r = fetestexcept ( FE_ALL_EXCEPT );
> + if ( r ) {
> printf("fetestexcept ==> 0x%x\n", r);
> /* Test 'FE_DIVBYZERO' */
> puts( "Divide by zero and confirm fetestexcept()" );
> @@ -91,11 +95,60 @@ rtems_task Init(rtems_task_argument ignored)
> b = 1.0;
> c = b/a;
> (void) c;
> - fegetexceptflag(&excepts,FE_ALL_EXCEPT);
> + /* Test fegetexceptflag() and fesetexceptflag() */
> + r = fegetexceptflag ( &excepts ,FE_ALL_EXCEPT );
space after comma, not before it; repeated below
> + if ( r ) {
> + printf("fegetexceptflag ==> 0x%x\n", r);
> + r = fesetexceptflag ( &excepts ,FE_ALL_EXCEPT );
> + if ( r ) {
> + printf("fesetexceptflag ==> 0x%x\n", r);
> + /* Test for fegetround() and fesetround()
> + * They have four main macros to be tested separated by ifdef
> + * Since not all architectures support them
> + * The test case gets and sets the rounding directions */
> +#ifdef FE_TONEAREST
> + rtems_test_assert ( fegetround() == FE_TONEAREST ) ;
> +#endif
> +#ifdef FE_TOWARDZERO
> + r = fesetround ( FE_TOWARDZERO ) ;
> + if( r ) {
space after if, repeated below.
> + printf("fesetround ==> 0x%x\n", r);
> + rtems_test_assert ( r == 0 ) ;
> + rtems_test_assert ( fegetround() == FE_TOWARDZERO ) ;
> +#endif
> +#ifdef FE_DOWNWARD
> + r = fesetround ( FE_DOWNWARD );
> + if(r){
> + rtems_test_assert ( fegetround() == FE_DOWNWARD ) ;
> +#endif
> +#ifdef FE_UPWARD
> + r = fesetround ( FE_UPWARD );
> + if( r ) {
> + rtems_test_assert ( fegetround() == FE_UPWARD ) ;
> +#endif
> + r = fesetround ( FE_TONEAREST );
> + if ( r ) {
> +#endif
> #ifdef FE_DIVBYZERO
> - r = feraiseexcept(FE_DIVBYZERO);
> + r = feraiseexcept ( FE_DIVBYZERO ) ;
> rtems_test_assert( fetestexcept( FE_DIVBYZERO ) );
> #endif
> @@ -124,4 +177,4 @@ rtems_task Init(rtems_task_argument ignored)
> #define CONFIGURE_INIT
> #include <rtems/confdefs.h>
> -/* end of file */
> +/* end of file */
why is there a change here?
> \ No newline at end of file
If there isn't a newline at the end of file comment, you can add 1.
> 2.17.1
> devel mailing list
> devel at rtems.org
