RTEMS Release Notes Generator - GSoC Project
Denil Verghese
denilcv3 at gmail.com
Fri Mar 6 14:48:57 UTC 2020
Hi,
To summarize,
I Will primarily focus on ticket https://devel.rtems.org/ticket/3314
(hopefully from where the
project paused https://github.com/dh0072/ReleaseNotesGenerator ) along with
suggested tasks
such as license compliance such as auditing license information, creating a
manifest for a
release, fixing current MD support, adding support for other file formats
like Plaintext, Parseable(I
don't which will be all useful suggestions welcomed )
Additionally, I could work on the remaining portion of
https://devel.rtems.org/ticket/3333 (Not sure the status of the code.).
Is the project be up to the requirements of a GSoC project? If not, what
can I do to improve the project?
On Fri, Mar 6, 2020 at 7:10 AM Gedare Bloom <gedare at rtems.org> wrote:
> You'll want to ask on the mailing list. There was also discussion recently
> about some other python based projects
> On Thu, Mar 5, 2020, 6:37 PM Denil Verghese <denilcv3 at gmail.com> wrote:
>> On Wed, 4 Mar, 2020, 10:07 PM Gedare Bloom, <gedare at rtems.org> wrote:
>>> On Wed, Mar 4, 2020 at 8:59 AM Denil Verghese <denilcv3 at gmail.com>
>>> wrote:
>>> > Thanks, I'll check it out.
>>> > On Wed, 4 Mar, 2020, 7:54 AM Chris Johns, <chrisj at rtems.org> wrote:
>>> >> On 4/3/20 1:04 pm, Denil Verghese wrote:
>>> >> > I've read the ticket page at https://devel.rtems.org/ticket/3314,
>>> but it was
>>> >> > last modified a couple of years ago. I would like to know if there
>>> are any
>>> >> > changes or information that are missing from the ticket.
>>> >> > I have intermediate knowledge on python, have a good grasp on both
>>> HTML and CSS
>>> >> > and basic level on XML.
>>> >> Thank you for the interest.
>>> >> I have updated the ticket. The existing work can be found in this
>>> repo ...
>>> >> There is working code to fetch the tickets from Trac. The next stage
>>> is to
>>> >> generate ReST output from the data that can built into HTML or PDF by
>>> Sphinx
>>> > I will complete the remaining task.Will the project good enough for
>>> GSoC or should I do some additional work?
>>> It doesn't quite sound like enough work. You will want to identify a
>>> set of tasks that you can work on either incrementally to continue
>>> improving the release notes generator. One idea could be around
>>> license compliance such as auditing license information and creating a
>>> manifest for a release, which might be useful
>> I could also work on ticket #3333 Automate Conversion of Newlib Markup to
>> Sphinx
>>> >> There is existing MarkDown support but it not right or suitable for
>>> use. I am
>>> >> not sure how usable that part of the code is.
>>> And evaluating/fixing the MD support or other possible output formats
>>> for release notes. (Plaintext? Structured/Parseable Document e.g.,
>>> XML?)
>>> As you write the proposal you may come up with some more ideas, and so
>>> might the potential mentors/community members.
>>> >> Chris
>>> > Since, I knows how to scrape web-pages could I use that to get
>>> comments associated with each ticket?
>>> > Denil Verghese
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200306/3bb5cc7d/attachment-0001.html>
