[PATCH 3/6] c-user: Canonicalize configuration section names
Sebastian Huber
Fri Mar 6 15:35:42 UTC 2020
Update #3836.
c-user/configuring_a_system.rst | 28 ++++++++++++++--------------
1 file changed, 14 insertions(+), 14 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index 1fb8742..08471b5 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -1344,8 +1344,8 @@ DESCRIPTION:
NOTES:
This object class can be configured in unlimited allocation mode.
-Classic API Initialization Tasks Table Configuration
+Classic API Initialization Task Configuration
The ``<rtems/confdefs.h>`` configuration system can automatically generate an
Initialization Tasks Table named ``Initialization_tasks`` with a single entry.
@@ -1825,8 +1825,8 @@ DESCRIPTION:
NOTES:
None.
-POSIX Initialization Threads Table Configuration
+POSIX Initialization Thread Configuration
POSIX Initialization Threads Table named ``POSIX_Initialization_threads`` with
@@ -1928,8 +1928,8 @@ NOTES:
Task/Thread Stack Memory Above Minimum` for more information about
``CONFIGURE_EXTRA_TASK_STACKS``.
-Configuring Custom Task Stack Allocation
+Task Stack Allocator Configuration
RTEMS allows the application or BSP to define its own allocation and
deallocation methods for task stacks. This can be used to place task stacks in
@@ -2038,8 +2038,8 @@ NOTES:
- ``CONFIGURE_TASK_STACK_DEALLOCATOR``
-Configuring Memory for Classic API Message Buffers
+Message Queue Buffer Configuration
This section describes the configuration parameters related to specifying the
amount of memory reserved for message queue message buffers. See
@@ -3945,8 +3945,8 @@ or a lack of processors on the system. The fatal source is
- ``SMP_FATAL_MULTITASKING_START_ON_UNASSIGNED_PROCESSOR`` - it is not allowed
to start multitasking on a processor with no scheduler assigned.
-Device Driver Table
+Device Driver Configuration
This section defines the configuration parameters related to the automatic
generation of a Device Driver Table. As ``<rtems/confdefs.h>`` only is aware
@@ -4633,8 +4633,8 @@ NOTES:
Multiprocessor System assuming the BSP provides the proper set of
supporting methods.
-PCI Library
+PCI Library Configuration
This section defines the system configuration parameters supported by
``rtems/confdefs.h`` related to configuring the PCI Library for RTEMS.
@@ -4685,8 +4685,8 @@ Note that selecting ``PCI_LIB_STATIC`` or ``PCI_LIB_PERIPHERAL`` but not
defining ``pci_hb`` will reuslt in link errors. Note also that in these modes
Plug & Play is not performed.
-Event Recording
+Event Recording Configuration
.. index:: CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
2.16.4
