[PATCH 4/6] c-user: Sort configuration options alphabetically
Fri Mar 6 15:35:43 UTC 2020
Update #3836.
 c-user/configuring_a_system.rst | 1739 +++++++++++++++++++--------------------
 1 file changed, 867 insertions(+), 872 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index 08471b5..87da412 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -1060,15 +1060,15 @@ Classic API Configuration
 This section defines the Classic API related system configuration parameters
 supported by ``<rtems/confdefs.h>``.
-.. index:: CONFIGURE_MAXIMUM_TASKS
+.. index:: CONFIGURE_MAXIMUM_BARRIERS
-.. _CONFIGURE_MAXIMUM_TASKS:
+.. _CONFIGURE_MAXIMUM_BARRIERS:
-CONFIGURE_MAXIMUM_TASKS
+CONFIGURE_MAXIMUM_BARRIERS
 CONSTANT:
-    ``CONFIGURE_MAXIMUM_TASKS``
+    ``CONFIGURE_MAXIMUM_BARRIERS``
 DATA TYPE:
     Unsigned integer (``uint32_t``).
@@ -1077,42 +1077,24 @@ RANGE:
     Zero or positive.
 DEFAULT VALUE:
-    The default value is ``0``.
+    The default value is 0.
 DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_TASKS`` is the maximum number of Classic API Tasks that
-    can be concurrently active.
+    ``CONFIGURE_MAXIMUM_BARRIERS`` is the maximum number of Classic API
+    Barriers that can be concurrently active.
 NOTES:
     This object class can be configured in unlimited allocation mode.
-    The calculations for the required memory in the RTEMS Workspace for tasks
-    assume that each task has a minimum stack size and has floating point
-    support enabled.  The configuration parameter
-    ``CONFIGURE_EXTRA_TASK_STACKS`` is used to specify task stack requirements
-    *ABOVE* the minimum size required.  See :ref:`Reserve Task/Thread Stack
-    Memory Above Minimum` for more information about
-    ``CONFIGURE_EXTRA_TASK_STACKS``.
-    The maximum number of POSIX threads is specified by
-    :ref:`CONFIGURE_MAXIMUM_POSIX_THREADS <CONFIGURE_MAXIMUM_POSIX_THREADS>`.
-    A future enhancement to ``<rtems/confdefs.h>`` could be to eliminate the
-    assumption that all tasks have floating point enabled. This would require
-    the addition of a new configuration parameter to specify the number of
-    tasks which enable floating point support.
-.. COMMENT: XXX - Add xref to CONFIGURE_MAXIMUM_POSIX_THREADS.
-.. index:: CONFIGURE_MAXIMUM_TIMERS
+.. index:: CONFIGURE_MAXIMUM_MESSAGE_QUEUES
-.. _CONFIGURE_MAXIMUM_TIMERS:
+.. _CONFIGURE_MAXIMUM_MESSAGE_QUEUES:
-CONFIGURE_MAXIMUM_TIMERS
+CONFIGURE_MAXIMUM_MESSAGE_QUEUES
 CONSTANT:
-    ``CONFIGURE_MAXIMUM_TIMERS``
+    ``CONFIGURE_MAXIMUM_MESSAGE_QUEUES``
 DATA TYPE:
@@ -1124,21 +1106,23 @@ DEFAULT VALUE:
 DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_TIMERS`` is the maximum number of Classic API Timers
-    that can be concurrently active.
+    ``CONFIGURE_MAXIMUM_MESSAGE_QUEUES`` is the maximum number of Classic API
+    Message Queues that can be concurrently active.
 NOTES:
-    This object class can be configured in unlimited allocation mode.
+    This object class can be configured in unlimited allocation mode.  You have
+    to account for the memory used to store the messages of each message queue,
+    see :ref:`CONFIGURE_MESSAGE_BUFFER_MEMORY`.
-.. index:: CONFIGURE_MAXIMUM_SEMAPHORES
+.. index:: CONFIGURE_MAXIMUM_PARTITIONS
-.. _CONFIGURE_MAXIMUM_SEMAPHORES:
+.. _CONFIGURE_MAXIMUM_PARTITIONS:
-CONFIGURE_MAXIMUM_SEMAPHORES
+CONFIGURE_MAXIMUM_PARTITIONS
 CONSTANT:
-    ``CONFIGURE_MAXIMUM_SEMAPHORES``
+    ``CONFIGURE_MAXIMUM_PARTITIONS``
 DATA TYPE:
@@ -1150,25 +1134,21 @@ DEFAULT VALUE:
 DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_SEMAPHORES`` is the maximum number of Classic API
-    Semaphores that can be concurrently active.
+    ``CONFIGURE_MAXIMUM_PARTITIONS`` is the maximum number of Classic API
+    Partitions that can be concurrently active.
 NOTES:
-    In SMP configurations, the size of a Semaphore Control Block depends on the
-    scheduler count (see :ref:`ConfigurationSchedulerTable`).  The semaphores
-    using the :ref:`MrsP` need a ceiling priority per scheduler.
-.. index:: CONFIGURE_MAXIMUM_MESSAGE_QUEUES
+.. index:: CONFIGURE_MAXIMUM_PERIODS
-.. _CONFIGURE_MAXIMUM_MESSAGE_QUEUES:
+.. _CONFIGURE_MAXIMUM_PERIODS:
-CONFIGURE_MAXIMUM_MESSAGE_QUEUES
+CONFIGURE_MAXIMUM_PERIODS
 CONSTANT:
-    ``CONFIGURE_MAXIMUM_MESSAGE_QUEUES``
+    ``CONFIGURE_MAXIMUM_PERIODS``
 DATA TYPE:
@@ -1180,23 +1160,21 @@ DEFAULT VALUE:
 DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_MESSAGE_QUEUES`` is the maximum number of Classic API
-    Message Queues that can be concurrently active.
+    ``CONFIGURE_MAXIMUM_PERIODS`` is the maximum number of Classic API Periods
+    that can be concurrently active.
 NOTES:
-    This object class can be configured in unlimited allocation mode.  You have
-    to account for the memory used to store the messages of each message queue,
-    see :ref:`CONFIGURE_MESSAGE_BUFFER_MEMORY`.
-.. index:: CONFIGURE_MAXIMUM_BARRIERS
+.. index:: CONFIGURE_MAXIMUM_PORTS
-.. _CONFIGURE_MAXIMUM_BARRIERS:
+.. _CONFIGURE_MAXIMUM_PORTS:
-CONFIGURE_MAXIMUM_BARRIERS
+CONFIGURE_MAXIMUM_PORTS
 CONSTANT:
-    ``CONFIGURE_MAXIMUM_BARRIERS``
+    ``CONFIGURE_MAXIMUM_PORTS``
 DATA TYPE:
@@ -1208,21 +1186,21 @@ DEFAULT VALUE:
 DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_BARRIERS`` is the maximum number of Classic API
-    Barriers that can be concurrently active.
+    ``CONFIGURE_MAXIMUM_PORTS`` is the maximum number of Classic API Ports that
+    can be concurrently active.
 NOTES:
-.. index:: CONFIGURE_MAXIMUM_PERIODS
+.. index:: CONFIGURE_MAXIMUM_REGIONS
-.. _CONFIGURE_MAXIMUM_PERIODS:
+.. _CONFIGURE_MAXIMUM_REGIONS:
-CONFIGURE_MAXIMUM_PERIODS
+CONFIGURE_MAXIMUM_REGIONS
 CONSTANT:
-    ``CONFIGURE_MAXIMUM_PERIODS``
+    ``CONFIGURE_MAXIMUM_REGIONS``
 DATA TYPE:
@@ -1234,21 +1212,21 @@ DEFAULT VALUE:
 DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_PERIODS`` is the maximum number of Classic API Periods
+    ``CONFIGURE_MAXIMUM_REGIONS`` is the maximum number of Classic API Regions
 NOTES:
+    None.
-.. index:: CONFIGURE_MAXIMUM_PARTITIONS
+.. index:: CONFIGURE_MAXIMUM_SEMAPHORES
-.. _CONFIGURE_MAXIMUM_PARTITIONS:
+.. _CONFIGURE_MAXIMUM_SEMAPHORES:
-CONFIGURE_MAXIMUM_PARTITIONS
+CONFIGURE_MAXIMUM_SEMAPHORES
 CONSTANT:
-    ``CONFIGURE_MAXIMUM_PARTITIONS``
+    ``CONFIGURE_MAXIMUM_SEMAPHORES``
 DATA TYPE:
@@ -1260,21 +1238,25 @@ DEFAULT VALUE:
 DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_PARTITIONS`` is the maximum number of Classic API
-    Partitions that can be concurrently active.
+    ``CONFIGURE_MAXIMUM_SEMAPHORES`` is the maximum number of Classic API
+    Semaphores that can be concurrently active.
 NOTES:
-.. index:: CONFIGURE_MAXIMUM_REGIONS
+    In SMP configurations, the size of a Semaphore Control Block depends on the
+    scheduler count (see :ref:`ConfigurationSchedulerTable`).  The semaphores
+    using the :ref:`MrsP` need a ceiling priority per scheduler.
-.. _CONFIGURE_MAXIMUM_REGIONS:
+.. index:: CONFIGURE_MAXIMUM_TASKS
-CONFIGURE_MAXIMUM_REGIONS
+.. _CONFIGURE_MAXIMUM_TASKS:
+CONFIGURE_MAXIMUM_TASKS
 CONSTANT:
-    ``CONFIGURE_MAXIMUM_REGIONS``
+    ``CONFIGURE_MAXIMUM_TASKS``
 DATA TYPE:
@@ -1283,24 +1265,40 @@ RANGE:
     Zero or positive.
 DEFAULT VALUE:
-    The default value is 0.
+    The default value is ``0``.
 DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_REGIONS`` is the maximum number of Classic API Regions
+    ``CONFIGURE_MAXIMUM_TASKS`` is the maximum number of Classic API Tasks that
 NOTES:
-    None.
-.. index:: CONFIGURE_MAXIMUM_PORTS
+    The calculations for the required memory in the RTEMS Workspace for tasks
+    assume that each task has a minimum stack size and has floating point
+    support enabled.  The configuration parameter
+    ``CONFIGURE_EXTRA_TASK_STACKS`` is used to specify task stack requirements
+    *ABOVE* the minimum size required.  See :ref:`Reserve Task/Thread Stack
+    Memory Above Minimum` for more information about
+    ``CONFIGURE_EXTRA_TASK_STACKS``.
-.. _CONFIGURE_MAXIMUM_PORTS:
+    The maximum number of POSIX threads is specified by
+    :ref:`CONFIGURE_MAXIMUM_POSIX_THREADS <CONFIGURE_MAXIMUM_POSIX_THREADS>`.
-CONFIGURE_MAXIMUM_PORTS
+    A future enhancement to ``<rtems/confdefs.h>`` could be to eliminate the
+    assumption that all tasks have floating point enabled. This would require
+    the addition of a new configuration parameter to specify the number of
+    tasks which enable floating point support.
+.. index:: CONFIGURE_MAXIMUM_TIMERS
+.. _CONFIGURE_MAXIMUM_TIMERS:
+CONFIGURE_MAXIMUM_TIMERS
 CONSTANT:
-    ``CONFIGURE_MAXIMUM_PORTS``
+    ``CONFIGURE_MAXIMUM_TIMERS``
 DATA TYPE:
@@ -1312,8 +1310,8 @@ DEFAULT VALUE:
 DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_PORTS`` is the maximum number of Classic API Ports that
+    ``CONFIGURE_MAXIMUM_TIMERS`` is the maximum number of Classic API Timers
 NOTES:
@@ -1351,41 +1349,57 @@ The ``<rtems/confdefs.h>`` configuration system can automatically generate an
 Initialization Tasks Table named ``Initialization_tasks`` with a single entry.
 The following parameters control the generation of that table.
-.. index:: CONFIGURE_RTEMS_INIT_TASKS_TABLE
+.. index:: CONFIGURE_INIT_TASK_ARGUMENTS
-.. _CONFIGURE_RTEMS_INIT_TASKS_TABLE:
+.. _CONFIGURE_INIT_TASK_ARGUMENTS:
-CONFIGURE_RTEMS_INIT_TASKS_TABLE
+CONFIGURE_INIT_TASK_ARGUMENTS
 CONSTANT:
-    ``CONFIGURE_RTEMS_INIT_TASKS_TABLE``
+    ``CONFIGURE_INIT_TASK_ARGUMENTS``
 DATA TYPE:
-    Boolean feature macro.
+    RTEMS Task Argument (``rtems_task_argument``).
 RANGE:
-    Defined or undefined.
+    Complete range of the type.
 DEFAULT VALUE:
-    This is not defined by default.
 DESCRIPTION:
-    ``CONFIGURE_RTEMS_INIT_TASKS_TABLE`` is defined if the user wishes to use a
-    Classic RTEMS API Initialization Task Table. The table built by
-    ``<rtems/confdefs.h>`` specifies the parameters for a single task. This is
-    sufficient for applications which initialization the system from a single
-    task.
-    By default, this field is not defined as the user MUST select their own API
-    for initialization tasks.
+    ``CONFIGURE_INIT_TASK_ARGUMENTS`` is the task argument of the single
+    initialization task defined by the Classic API Initialization Tasks Table.
 NOTES:
-    The application may choose to use the initialization tasks or threads table
-    from another API.
+    None.
-    A compile time error will be generated if the user does not configure any
-    initialization tasks or threads.
+.. index:: CONFIGURE_INIT_TASK_ATTRIBUTES
+.. _CONFIGURE_INIT_TASK_ATTRIBUTES:
+CONFIGURE_INIT_TASK_ATTRIBUTES
+CONSTANT:
+    ``CONFIGURE_INIT_TASK_ATTRIBUTES``
+DATA TYPE:
+    RTEMS Attributes (``rtems_attribute``).
+RANGE:
+    Valid task attribute sets.
+DEFAULT VALUE:
+    The default value is ``RTEMS_DEFAULT_ATTRIBUTES``.
+DESCRIPTION:
+    ``CONFIGURE_INIT_TASK_ATTRIBUTES`` is the task attributes of the single
+NOTES:
+    None.
 .. index:: CONFIGURE_INIT_TASK_ENTRY_POINT
@@ -1415,60 +1429,58 @@ NOTES:
     The user must implement the function ``Init`` or the function name provided
     in this configuration parameter.
-.. index:: CONFIGURE_INIT_TASK_NAME
+.. index:: CONFIGURE_INIT_TASK_INITIAL_MODES
-.. _CONFIGURE_INIT_TASK_NAME:
+.. _CONFIGURE_INIT_TASK_INITIAL_MODES:
-CONFIGURE_INIT_TASK_NAME
+CONFIGURE_INIT_TASK_INITIAL_MODES
 CONSTANT:
-    ``CONFIGURE_INIT_TASK_NAME``
+    ``CONFIGURE_INIT_TASK_INITIAL_MODES``
 DATA TYPE:
-    RTEMS Name (``rtems_name``).
+    RTEMS Mode (``rtems_mode``).
 RANGE:
-    Any value.
+    Valid task mode sets.
 DEFAULT VALUE:
-    The default value is ``rtems_build_name( 'U', 'I', '1', ' ' )``.
+    The default value is ``RTEMS_NO_PREEMPT``.
 DESCRIPTION:
-    ``CONFIGURE_INIT_TASK_NAME`` is the name of the single initialization task
-    defined by the Classic API Initialization Tasks Table.
+    ``CONFIGURE_INIT_TASK_INITIAL_MODES`` is the initial execution mode of the
+    single initialization task defined by the Classic API Initialization Tasks
+    Table.
 NOTES:
     None.
-.. index:: CONFIGURE_INIT_TASK_STACK_SIZE
+.. index:: CONFIGURE_INIT_TASK_NAME
-.. _CONFIGURE_INIT_TASK_STACK_SIZE:
+.. _CONFIGURE_INIT_TASK_NAME:
-CONFIGURE_INIT_TASK_STACK_SIZE
+CONFIGURE_INIT_TASK_NAME
 CONSTANT:
-    ``CONFIGURE_INIT_TASK_STACK_SIZE``
+    ``CONFIGURE_INIT_TASK_NAME``
 DATA TYPE:
-    Unsigned integer (``size_t``).
+    RTEMS Name (``rtems_name``).
 RANGE:
-    Zero or positive.
+    Any value.
 DEFAULT VALUE:
-    The default value is RTEMS_MINIMUM_STACK_SIZE.
+    The default value is ``rtems_build_name( 'U', 'I', '1', ' ' )``.
 DESCRIPTION:
-    ``CONFIGURE_INIT_TASK_STACK_SIZE`` is the stack size of the single
-    initialization task defined by the Classic API Initialization Tasks Table.
+    ``CONFIGURE_INIT_TASK_NAME`` is the name of the single initialization task
+    defined by the Classic API Initialization Tasks Table.
 NOTES:
-    If the stack size specified is greater than the configured minimum, it must
-    be accounted for in ``CONFIGURE_EXTRA_TASK_STACKS``.  See :ref:`Reserve
-    Task/Thread Stack Memory Above Minimum` for more information about
+    None.
 .. index:: CONFIGURE_INIT_TASK_PRIORITY
@@ -1496,85 +1508,70 @@ DESCRIPTION:
 NOTES:
     None.
+.. index:: CONFIGURE_INIT_TASK_STACK_SIZE
-.. index:: CONFIGURE_INIT_TASK_ATTRIBUTES
-.. _CONFIGURE_INIT_TASK_ATTRIBUTES:
+.. _CONFIGURE_INIT_TASK_STACK_SIZE:
-CONFIGURE_INIT_TASK_ATTRIBUTES
+CONFIGURE_INIT_TASK_STACK_SIZE
 CONSTANT:
-    ``CONFIGURE_INIT_TASK_ATTRIBUTES``
+    ``CONFIGURE_INIT_TASK_STACK_SIZE``
 DATA TYPE:
-    RTEMS Attributes (``rtems_attribute``).
+    Unsigned integer (``size_t``).
 RANGE:
-    Valid task attribute sets.
+    Zero or positive.
 DEFAULT VALUE:
-    The default value is ``RTEMS_DEFAULT_ATTRIBUTES``.
+    The default value is RTEMS_MINIMUM_STACK_SIZE.
 DESCRIPTION:
-    ``CONFIGURE_INIT_TASK_ATTRIBUTES`` is the task attributes of the single
+    ``CONFIGURE_INIT_TASK_STACK_SIZE`` is the stack size of the single
 NOTES:
-    None.
+    If the stack size specified is greater than the configured minimum, it must
+    be accounted for in ``CONFIGURE_EXTRA_TASK_STACKS``.  See :ref:`Reserve
+    Task/Thread Stack Memory Above Minimum` for more information about
-.. index:: CONFIGURE_INIT_TASK_INITIAL_MODES
+.. index:: CONFIGURE_RTEMS_INIT_TASKS_TABLE
-.. _CONFIGURE_INIT_TASK_INITIAL_MODES:
+.. _CONFIGURE_RTEMS_INIT_TASKS_TABLE:
-CONFIGURE_INIT_TASK_INITIAL_MODES
+CONFIGURE_RTEMS_INIT_TASKS_TABLE
 CONSTANT:
-    ``CONFIGURE_INIT_TASK_INITIAL_MODES``
+    ``CONFIGURE_RTEMS_INIT_TASKS_TABLE``
 DATA TYPE:
-    RTEMS Mode (``rtems_mode``).
+    Boolean feature macro.
 RANGE:
-    Valid task mode sets.
+    Defined or undefined.
 DEFAULT VALUE:
-    The default value is ``RTEMS_NO_PREEMPT``.
+    This is not defined by default.
 DESCRIPTION:
-    ``CONFIGURE_INIT_TASK_INITIAL_MODES`` is the initial execution mode of the
-    single initialization task defined by the Classic API Initialization Tasks
-    Table.
-NOTES:
-    None.
-.. index:: CONFIGURE_INIT_TASK_ARGUMENTS
-.. _CONFIGURE_INIT_TASK_ARGUMENTS:
-CONFIGURE_INIT_TASK_ARGUMENTS
-CONSTANT:
-    ``CONFIGURE_INIT_TASK_ARGUMENTS``
-DATA TYPE:
-    RTEMS Task Argument (``rtems_task_argument``).
-RANGE:
-    Complete range of the type.
-DEFAULT VALUE:
+    ``CONFIGURE_RTEMS_INIT_TASKS_TABLE`` is defined if the user wishes to use a
+    Classic RTEMS API Initialization Task Table. The table built by
+    ``<rtems/confdefs.h>`` specifies the parameters for a single task. This is
+    sufficient for applications which initialization the system from a single
+    task.
-DESCRIPTION:
-    ``CONFIGURE_INIT_TASK_ARGUMENTS`` is the task argument of the single
+    By default, this field is not defined as the user MUST select their own API
+    for initialization tasks.
 NOTES:
-    None.
+    The application may choose to use the initialization tasks or threads table
+    from another API.
+    A compile time error will be generated if the user does not configure any
+    initialization tasks or threads.
 POSIX API Configuration
@@ -1832,44 +1829,6 @@ The ``<rtems/confdefs.h>`` configuration system can automatically generate a
 POSIX Initialization Threads Table named ``POSIX_Initialization_threads`` with
 a single entry.  The following parameters control the generation of that table.
-.. index:: CONFIGURE_POSIX_INIT_THREAD_TABLE
-.. _CONFIGURE_POSIX_INIT_THREAD_TABLE:
-CONFIGURE_POSIX_INIT_THREAD_TABLE
-CONSTANT:
-    ``CONFIGURE_POSIX_INIT_THREAD_TABLE``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-    This field is not defined by default, as the user MUST select their own API
-DESCRIPTION:
-    ``CONFIGURE_POSIX_INIT_THREAD_TABLE`` is defined if the user wishes to use
-    a POSIX API Initialization Threads Table.  The table built by
-    ``<rtems/confdefs.h>`` specifies the parameters for a single thread. This
-    is sufficient for applications which initialization the system from a
-    single task.
-NOTES:
-    from another API.
 .. index:: CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
 .. _CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT:
@@ -1928,6 +1887,44 @@ NOTES:
+.. index:: CONFIGURE_POSIX_INIT_THREAD_TABLE
+.. _CONFIGURE_POSIX_INIT_THREAD_TABLE:
+CONFIGURE_POSIX_INIT_THREAD_TABLE
+CONSTANT:
+    ``CONFIGURE_POSIX_INIT_THREAD_TABLE``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+    This field is not defined by default, as the user MUST select their own API
+DESCRIPTION:
+    ``CONFIGURE_POSIX_INIT_THREAD_TABLE`` is defined if the user wishes to use
+    a POSIX API Initialization Threads Table.  The table built by
+    ``<rtems/confdefs.h>`` specifies the parameters for a single thread. This
+    is sufficient for applications which initialization the system from a
+    single task.
+NOTES:
+    from another API.
 Task Stack Allocator Configuration
@@ -1936,30 +1933,30 @@ deallocation methods for task stacks. This can be used to place task stacks in
 special areas of memory or to utilize a Memory Management Unit so that stack
 overflows are detected in hardware.
-.. index:: CONFIGURE_TASK_STACK_ALLOCATOR_INIT
+.. index:: CONFIGURE_TASK_STACK_ALLOCATOR
+.. index:: task stack allocator
-.. _CONFIGURE_TASK_STACK_ALLOCATOR_INIT:
+.. _CONFIGURE_TASK_STACK_ALLOCATOR:
-CONFIGURE_TASK_STACK_ALLOCATOR_INIT
+CONFIGURE_TASK_STACK_ALLOCATOR
 CONSTANT:
-    ``CONFIGURE_TASK_STACK_ALLOCATOR_INIT``
+    ``CONFIGURE_TASK_STACK_ALLOCATOR``
 DATA TYPE:
     Function pointer.
 RANGE:
-    Undefined, NULL or valid function pointer.
+    Undefined or valid function pointer.
 DEFAULT VALUE:
-    The default value is NULL, which indicates that task stacks will be
-    allocated from the RTEMS Workspace.
+    The default value is ``_Workspace_Allocate``, which indicates that task
+    stacks will be allocated from the RTEMS Workspace.
 DESCRIPTION:
-    ``CONFIGURE_TASK_STACK_ALLOCATOR_INIT`` configures the initialization
-    method for an application or BSP specific task stack allocation
-    implementation.
+    ``CONFIGURE_TASK_STACK_ALLOCATOR`` may point to a user provided routine to
+    allocate task stacks.
 NOTES:
     A correctly configured system must configure the following to be consistent:
@@ -1970,30 +1967,30 @@ NOTES:
 - ``CONFIGURE_TASK_STACK_DEALLOCATOR``
-.. index:: task stack allocator
+.. index:: CONFIGURE_TASK_STACK_ALLOCATOR_INIT
-.. _CONFIGURE_TASK_STACK_ALLOCATOR:
+.. _CONFIGURE_TASK_STACK_ALLOCATOR_INIT:
+CONFIGURE_TASK_STACK_ALLOCATOR_INIT
 CONSTANT:
-    ``CONFIGURE_TASK_STACK_ALLOCATOR``
+    ``CONFIGURE_TASK_STACK_ALLOCATOR_INIT``
 DATA TYPE:
     Function pointer.
 RANGE:
-    Undefined or valid function pointer.
+    Undefined, NULL or valid function pointer.
 DEFAULT VALUE:
-    The default value is ``_Workspace_Allocate``, which indicates that task
-    stacks will be allocated from the RTEMS Workspace.
+    The default value is NULL, which indicates that task stacks will be
+    allocated from the RTEMS Workspace.
 DESCRIPTION:
-    ``CONFIGURE_TASK_STACK_ALLOCATOR`` may point to a user provided routine to
-    allocate task stacks.
+    ``CONFIGURE_TASK_STACK_ALLOCATOR_INIT`` configures the initialization
+    method for an application or BSP specific task stack allocation
+    implementation.
 NOTES:
@@ -2046,87 +2043,87 @@ amount of memory reserved for message queue message buffers.  See
 :ref:`CONFIGURE_MAXIMUM_MESSAGE_QUEUES` and
 :ref:`CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES`.
-.. index:: CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE
-.. index:: memory for a single message queue's buffers
+.. index:: CONFIGURE_MESSAGE_BUFFER_MEMORY
+.. index:: configure message queue buffer memory
-.. _CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE:
+.. _CONFIGURE_MESSAGE_BUFFER_MEMORY:
-CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE
+CONFIGURE_MESSAGE_BUFFER_MEMORY
 CONSTANT:
-    ``CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(max_messages, size_per)``
+    ``CONFIGURE_MESSAGE_BUFFER_MEMORY``
 DATA TYPE:
+    integer summation macro
 RANGE:
-    Positive.
+    undefined (zero) or calculation resulting in a positive integer
 DEFAULT VALUE:
-    The default value is None.
+    This is not defined by default, and zero (0) memory is reserved.
 DESCRIPTION:
-    This is a helper macro which is used to assist in computing the total
-    amount of memory required for message buffers.  Each message queue will
-    have its own configuration with maximum message size and maximum number of
-    pending messages.
+    This macro is set to the number of bytes the application requires to be
+    reserved for pending Classic API Message Queue buffers.
-    The interface for this macro is as follows:
+NOTES:
+    The following illustrates how the help macro
+    :ref:`CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE` can be used to assist in
+    calculating the message buffer memory required.  In this example, there are
+    two message queues used in this application.  The first message queue has
+    maximum of 24 pending messages with the message structure defined by the
+    type ``one_message_type``.  The other message queue has maximum of 500
+    pending messages with the message structure defined by the type
+    ``other_message_type``.
     .. code-block:: c
-        CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(max_messages, size_per)
-    Where ``max_messages`` is the maximum number of pending messages and
-    ``size_per`` is the size in bytes of the user message.
-NOTES:
-    This macro is only used in support of :ref:`CONFIGURE_MESSAGE_BUFFER_MEMORY`.
+        #define CONFIGURE_MESSAGE_BUFFER_MEMORY \
+                    (CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( \
+                         24, sizeof(one_message_type) \
+                     CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( \
+                         500, sizeof(other_message_type) \
-.. index:: CONFIGURE_MESSAGE_BUFFER_MEMORY
-.. index:: configure message queue buffer memory
+.. index:: CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE
+.. index:: memory for a single message queue's buffers
-.. _CONFIGURE_MESSAGE_BUFFER_MEMORY:
+.. _CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE:
-CONFIGURE_MESSAGE_BUFFER_MEMORY
+CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE
 CONSTANT:
-    ``CONFIGURE_MESSAGE_BUFFER_MEMORY``
+    ``CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(max_messages, size_per)``
 DATA TYPE:
-    integer summation macro
 RANGE:
-    undefined (zero) or calculation resulting in a positive integer
+    Positive.
 DEFAULT VALUE:
-    This is not defined by default, and zero (0) memory is reserved.
+    The default value is None.
 DESCRIPTION:
-    This macro is set to the number of bytes the application requires to be
-    reserved for pending Classic API Message Queue buffers.
+    This is a helper macro which is used to assist in computing the total
+    amount of memory required for message buffers.  Each message queue will
+    have its own configuration with maximum message size and maximum number of
+    pending messages.
-NOTES:
-    The following illustrates how the help macro
-    :ref:`CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE` can be used to assist in
-    calculating the message buffer memory required.  In this example, there are
-    two message queues used in this application.  The first message queue has
-    maximum of 24 pending messages with the message structure defined by the
-    type ``one_message_type``.  The other message queue has maximum of 500
-    pending messages with the message structure defined by the type
-    ``other_message_type``.
+    The interface for this macro is as follows:
     .. code-block:: c
-        #define CONFIGURE_MESSAGE_BUFFER_MEMORY \
-                    (CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( \
-                         24, sizeof(one_message_type) \
-                     CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( \
-                         500, sizeof(other_message_type) \
+        CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(max_messages, size_per)
+    Where ``max_messages`` is the maximum number of pending messages and
+    ``size_per`` is the size in bytes of the user message.
+NOTES:
+    This macro is only used in support of :ref:`CONFIGURE_MESSAGE_BUFFER_MEMORY`.
 Filesystem Configuration
@@ -2172,67 +2169,6 @@ configuration options:
 * :ref:`CONFIGURE_IMFS_ENABLE_MKFIFO`
-.. index:: CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
-.. _CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM:
-CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
-CONSTANT:
-    ``CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-    This is not defined by default. If no other root file system configuration
-    parameters are specified, the IMFS will be used as the root file system.
-DESCRIPTION:
-    This configuration parameter is defined if the application wishes to use
-    the device-only filesytem as the root file system.
-NOTES:
-    The device-only filesystem supports only device nodes and is smaller in
-    executable code size than the full IMFS and miniIMFS.
-    The devFS is comparable in functionality to the pseudo-filesystem name
-    space provided before RTEMS release 4.5.0.
-.. index:: CONFIGURE_MAXIMUM_DEVICES
-.. _CONFIGURE_MAXIMUM_DEVICES:
-CONFIGURE_MAXIMUM_DEVICES
-CONSTANT:
-    ``CONFIGURE_MAXIMUM_DEVICES``
-DATA TYPE:
-    Unsigned integer (``uint32_t``).
-RANGE:
-    Positive.
-DEFAULT VALUE:
-    If ``BSP_MAXIMUM_DEVICES`` is defined, then the default value is
-    ``BSP_MAXIMUM_DEVICES``, otherwise the default value is 4.
-DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_DEVICES`` is defined to the number of individual
-    devices that may be registered in the device file system (devFS).
-NOTES:
-    This option is specific to the device file system (devFS) and should not be
-    confused with the ``CONFIGURE_MAXIMUM_DRIVERS`` option.  This parameter
-    only impacts the devFS and thus is only used by ``<rtems/confdefs.h>`` when
-    ``CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM`` is specified.
 .. index:: CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
 .. _CONFIGURE_APPLICATION_DISABLE_FILESYSTEM:
@@ -2261,15 +2197,15 @@ DESCRIPTION:
 NOTES:
     None.
-.. index:: CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
+.. index:: CONFIGURE_IMFS_ENABLE_MKFIFO
-.. _CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM:
+.. _CONFIGURE_IMFS_ENABLE_MKFIFO:
-CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
+CONFIGURE_IMFS_ENABLE_MKFIFO
 CONSTANT:
-    ``CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM``
+    ``CONFIGURE_IMFS_ENABLE_MKFIFO``
 DATA TYPE:
@@ -2281,73 +2217,31 @@ DEFAULT VALUE:
 DESCRIPTION:
-    In case this configuration option is defined, then the following
-    configuration options will be defined as well
-    - ``CONFIGURE_IMFS_DISABLE_CHMOD``,
-    - ``CONFIGURE_IMFS_DISABLE_CHOWN``,
-    - ``CONFIGURE_IMFS_DISABLE_UTIME``,
-    - ``CONFIGURE_IMFS_DISABLE_LINK``,
-    - ``CONFIGURE_IMFS_DISABLE_SYMLINK``,
-    - ``CONFIGURE_IMFS_DISABLE_READLINK``,
-    - ``CONFIGURE_IMFS_DISABLE_RENAME``, and
-    - ``CONFIGURE_IMFS_DISABLE_UNMOUNT``.
+    In case this configuration option is defined, then the support to make FIFOs
+    is enabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
+.. index:: CONFIGURE_IMFS_DISABLE_CHMOD
-.. _CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK:
+.. _CONFIGURE_IMFS_DISABLE_CHMOD:
-CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
+CONFIGURE_IMFS_DISABLE_CHMOD
 CONSTANT:
-    ``CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK``
+    ``CONFIGURE_IMFS_DISABLE_CHMOD``
 DATA TYPE:
 RANGE:
-    Valid values for this configuration parameter are a power of two (2)
-    between 16 and 512 inclusive.  In other words, valid values are 16, 32, 64,
-    128, 256,and 512.
 DEFAULT VALUE:
-    The default IMFS block size is 128 bytes.
 DESCRIPTION:
-    This configuration parameter specifies the block size for in-memory files
-    managed by the IMFS. The configured block size has two impacts. The first
-    is the average amount of unused memory in the last block of each file. For
-    example, when the block size is 512, on average one-half of the last block
-    of each file will remain unused and the memory is wasted. In contrast, when
-    the block size is 16, the average unused memory per file is only 8
-    bytes. However, it requires more allocations for the same size file and
-    thus more overhead per block for the dynamic memory management.
-    Second, the block size has an impact on the maximum size file that can be
-    stored in the IMFS. With smaller block size, the maximum file size is
-    correspondingly smaller. The following shows the maximum file size possible
-    based on the configured block size:
-    - when the block size is 16 bytes, the maximum file size is 1,328 bytes.
-    - when the block size is 32 bytes, the maximum file size is 18,656 bytes.
-    - when the block size is 64 bytes, the maximum file size is 279,488 bytes.
-    - when the block size is 128 bytes, the maximum file size is 4,329,344 bytes.
-    - when the block size is 256 bytes, the maximum file size is 68,173,568 bytes.
-    - when the block size is 512 bytes, the maximum file size is 1,082,195,456
-      bytes.
+    In case this configuration option is defined, then the support to change
+    the mode is disabled in the root IMFS.
 .. index:: CONFIGURE_IMFS_DISABLE_CHOWN
@@ -2372,15 +2266,15 @@ DESCRIPTION:
     the owner is disabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_DISABLE_CHMOD
+.. index:: CONFIGURE_IMFS_DISABLE_LINK
-.. _CONFIGURE_IMFS_DISABLE_CHMOD:
+.. _CONFIGURE_IMFS_DISABLE_LINK:
-CONFIGURE_IMFS_DISABLE_CHMOD
+CONFIGURE_IMFS_DISABLE_LINK
 CONSTANT:
+    ``CONFIGURE_IMFS_DISABLE_LINK``
 DATA TYPE:
@@ -2392,18 +2286,18 @@ DEFAULT VALUE:
 DESCRIPTION:
-    In case this configuration option is defined, then the support to change
-    the mode is disabled in the root IMFS.
+    In case this configuration option is defined, then the support to create
+    hard links is disabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_DISABLE_UTIME
+.. index:: CONFIGURE_IMFS_DISABLE_MKNOD
-.. _CONFIGURE_IMFS_DISABLE_UTIME:
+.. _CONFIGURE_IMFS_DISABLE_MKNOD:
-CONFIGURE_IMFS_DISABLE_UTIME
+CONFIGURE_IMFS_DISABLE_MKNOD
 CONSTANT:
+    ``CONFIGURE_IMFS_DISABLE_MKNOD``
 DATA TYPE:
@@ -2415,18 +2309,18 @@ DEFAULT VALUE:
 DESCRIPTION:
-    times is disabled in the root IMFS.
+    directories, devices, regular files and FIFOs is disabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_DISABLE_LINK
+.. index:: CONFIGURE_IMFS_DISABLE_MKNOD_FILE
-.. _CONFIGURE_IMFS_DISABLE_LINK:
+.. _CONFIGURE_IMFS_DISABLE_MKNOD_FILE:
-CONFIGURE_IMFS_DISABLE_LINK
+CONFIGURE_IMFS_DISABLE_MKNOD_FILE
 CONSTANT:
+    ``CONFIGURE_IMFS_DISABLE_MKNOD_FILE``
 DATA TYPE:
@@ -2438,18 +2332,18 @@ DEFAULT VALUE:
 DESCRIPTION:
-    In case this configuration option is defined, then the support to create
-    hard links is disabled in the root IMFS.
+    regular files is disabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_DISABLE_SYMLINK
+.. index:: CONFIGURE_IMFS_DISABLE_MOUNT
-.. _CONFIGURE_IMFS_DISABLE_SYMLINK:
+.. _CONFIGURE_IMFS_DISABLE_MOUNT:
-CONFIGURE_IMFS_DISABLE_SYMLINK
+CONFIGURE_IMFS_DISABLE_MOUNT
 CONSTANT:
+    ``CONFIGURE_IMFS_DISABLE_MOUNT``
 DATA TYPE:
@@ -2461,15 +2355,39 @@ DEFAULT VALUE:
 DESCRIPTION:
-    symbolic links is disabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_DISABLE_READLINK
+    In case this configuration option is defined, then the support to mount
+    other file systems is disabled in the root IMFS.
-.. _CONFIGURE_IMFS_DISABLE_READLINK:
+.. index:: CONFIGURE_IMFS_DISABLE_READDIR
-CONFIGURE_IMFS_DISABLE_READLINK
+.. _CONFIGURE_IMFS_DISABLE_READDIR:
+CONFIGURE_IMFS_DISABLE_READDIR
+CONSTANT:
+    ``CONFIGURE_IMFS_DISABLE_READDIR``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    In case this configuration option is defined, then the support to read a
+    directory is disabled in the root IMFS.  It is still possible to open nodes
+    in a directory.
+.. index:: CONFIGURE_IMFS_DISABLE_READLINK
+.. _CONFIGURE_IMFS_DISABLE_READLINK:
+CONFIGURE_IMFS_DISABLE_READLINK
 CONSTANT:
@@ -2510,15 +2428,15 @@ DESCRIPTION:
     In case this configuration option is defined, then the support to rename
     nodes is disabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_DISABLE_READDIR
+.. index:: CONFIGURE_IMFS_DISABLE_RMNOD
-.. _CONFIGURE_IMFS_DISABLE_READDIR:
+.. _CONFIGURE_IMFS_DISABLE_RMNOD:
-CONFIGURE_IMFS_DISABLE_READDIR
+CONFIGURE_IMFS_DISABLE_RMNOD
 CONSTANT:
-    ``CONFIGURE_IMFS_DISABLE_READDIR``
+    ``CONFIGURE_IMFS_DISABLE_RMNOD``
 DATA TYPE:
@@ -2530,19 +2448,18 @@ DEFAULT VALUE:
 DESCRIPTION:
-    In case this configuration option is defined, then the support to read a
-    directory is disabled in the root IMFS.  It is still possible to open nodes
-    in a directory.
+    In case this configuration option is defined, then the support to remove
+    nodes is disabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_DISABLE_MOUNT
+.. index:: CONFIGURE_IMFS_DISABLE_SYMLINK
-.. _CONFIGURE_IMFS_DISABLE_MOUNT:
+.. _CONFIGURE_IMFS_DISABLE_SYMLINK:
-CONFIGURE_IMFS_DISABLE_MOUNT
+CONFIGURE_IMFS_DISABLE_SYMLINK
 CONSTANT:
-    ``CONFIGURE_IMFS_DISABLE_MOUNT``
+    ``CONFIGURE_IMFS_DISABLE_SYMLINK``
 DATA TYPE:
@@ -2554,8 +2471,8 @@ DEFAULT VALUE:
 DESCRIPTION:
-    In case this configuration option is defined, then the support to mount
-    other file systems is disabled in the root IMFS.
+    symbolic links is disabled in the root IMFS.
 .. index:: CONFIGURE_IMFS_DISABLE_UNMOUNT
@@ -2580,15 +2497,15 @@ DESCRIPTION:
     In case this configuration option is defined, then the support to unmount
-.. index:: CONFIGURE_IMFS_DISABLE_MKNOD
+.. index:: CONFIGURE_IMFS_DISABLE_UTIME
-.. _CONFIGURE_IMFS_DISABLE_MKNOD:
+.. _CONFIGURE_IMFS_DISABLE_UTIME:
-CONFIGURE_IMFS_DISABLE_MKNOD
+CONFIGURE_IMFS_DISABLE_UTIME
 CONSTANT:
-    ``CONFIGURE_IMFS_DISABLE_MKNOD``
+    ``CONFIGURE_IMFS_DISABLE_UTIME``
 DATA TYPE:
@@ -2600,41 +2517,97 @@ DEFAULT VALUE:
 DESCRIPTION:
-    In case this configuration option is defined, then the support to make
-    directories, devices, regular files and FIFOs is disabled in the root IMFS.
+    times is disabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_DISABLE_MKNOD_FILE
+.. index:: CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
-.. _CONFIGURE_IMFS_DISABLE_MKNOD_FILE:
+.. _CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK:
-CONFIGURE_IMFS_DISABLE_MKNOD_FILE
+CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
 CONSTANT:
-    ``CONFIGURE_IMFS_DISABLE_MKNOD_FILE``
+    ``CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK``
 DATA TYPE:
 RANGE:
+    Valid values for this configuration parameter are a power of two (2)
+    between 16 and 512 inclusive.  In other words, valid values are 16, 32, 64,
+    128, 256,and 512.
 DEFAULT VALUE:
+    The default IMFS block size is 128 bytes.
 DESCRIPTION:
-    regular files is disabled in the root IMFS.
+    This configuration parameter specifies the block size for in-memory files
+    managed by the IMFS. The configured block size has two impacts. The first
+    is the average amount of unused memory in the last block of each file. For
+    example, when the block size is 512, on average one-half of the last block
+    of each file will remain unused and the memory is wasted. In contrast, when
+    the block size is 16, the average unused memory per file is only 8
+    bytes. However, it requires more allocations for the same size file and
+    thus more overhead per block for the dynamic memory management.
-.. index:: CONFIGURE_IMFS_DISABLE_RMNOD
+    Second, the block size has an impact on the maximum size file that can be
+    stored in the IMFS. With smaller block size, the maximum file size is
+    correspondingly smaller. The following shows the maximum file size possible
+    based on the configured block size:
-.. _CONFIGURE_IMFS_DISABLE_RMNOD:
+    - when the block size is 16 bytes, the maximum file size is 1,328 bytes.
-CONFIGURE_IMFS_DISABLE_RMNOD
+    - when the block size is 32 bytes, the maximum file size is 18,656 bytes.
+    - when the block size is 64 bytes, the maximum file size is 279,488 bytes.
+    - when the block size is 128 bytes, the maximum file size is 4,329,344 bytes.
+    - when the block size is 256 bytes, the maximum file size is 68,173,568 bytes.
+    - when the block size is 512 bytes, the maximum file size is 1,082,195,456
+      bytes.
+.. index:: CONFIGURE_MAXIMUM_DEVICES
+.. _CONFIGURE_MAXIMUM_DEVICES:
+CONFIGURE_MAXIMUM_DEVICES
 CONSTANT:
-    ``CONFIGURE_IMFS_DISABLE_RMNOD``
+    ``CONFIGURE_MAXIMUM_DEVICES``
+DATA TYPE:
+    Unsigned integer (``uint32_t``).
+RANGE:
+    Positive.
+DEFAULT VALUE:
+    If ``BSP_MAXIMUM_DEVICES`` is defined, then the default value is
+    ``BSP_MAXIMUM_DEVICES``, otherwise the default value is 4.
+DESCRIPTION:
+    ``CONFIGURE_MAXIMUM_DEVICES`` is defined to the number of individual
+    devices that may be registered in the device file system (devFS).
+NOTES:
+    This option is specific to the device file system (devFS) and should not be
+    confused with the ``CONFIGURE_MAXIMUM_DRIVERS`` option.  This parameter
+    only impacts the devFS and thus is only used by ``<rtems/confdefs.h>`` when
+    ``CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM`` is specified.
+.. index:: CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
+.. _CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM:
+CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
+CONSTANT:
 DATA TYPE:
@@ -2643,21 +2616,29 @@ RANGE:
 DEFAULT VALUE:
+    This is not defined by default. If no other root file system configuration
+    parameters are specified, the IMFS will be used as the root file system.
 DESCRIPTION:
-    In case this configuration option is defined, then the support to remove
-    nodes is disabled in the root IMFS.
+    This configuration parameter is defined if the application wishes to use
+    the device-only filesytem as the root file system.
-.. index:: CONFIGURE_IMFS_ENABLE_MKFIFO
+NOTES:
+    The device-only filesystem supports only device nodes and is smaller in
+    executable code size than the full IMFS and miniIMFS.
-.. _CONFIGURE_IMFS_ENABLE_MKFIFO:
+    The devFS is comparable in functionality to the pseudo-filesystem name
+    space provided before RTEMS release 4.5.0.
-CONFIGURE_IMFS_ENABLE_MKFIFO
+.. index:: CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
+.. _CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM:
+CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
 CONSTANT:
-    ``CONFIGURE_IMFS_ENABLE_MKFIFO``
+    ``CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM``
 DATA TYPE:
@@ -2669,8 +2650,24 @@ DEFAULT VALUE:
 DESCRIPTION:
-    In case this configuration option is defined, then the support to make FIFOs
-    is enabled in the root IMFS.
+    In case this configuration option is defined, then the following
+    configuration options will be defined as well
+    - ``CONFIGURE_IMFS_DISABLE_CHMOD``,
+    - ``CONFIGURE_IMFS_DISABLE_CHOWN``,
+    - ``CONFIGURE_IMFS_DISABLE_UTIME``,
+    - ``CONFIGURE_IMFS_DISABLE_LINK``,
+    - ``CONFIGURE_IMFS_DISABLE_SYMLINK``,
+    - ``CONFIGURE_IMFS_DISABLE_READLINK``,
+    - ``CONFIGURE_IMFS_DISABLE_RENAME``, and
+    - ``CONFIGURE_IMFS_DISABLE_UNMOUNT``.
 Block Device Cache Configuration
@@ -2730,65 +2727,65 @@ DESCRIPTION:
 NOTES:
     None.
-.. index:: CONFIGURE_BDBUF_BUFFER_MIN_SIZE
+.. index:: CONFIGURE_BDBUF_BUFFER_MAX_SIZE
-.. _CONFIGURE_BDBUF_BUFFER_MIN_SIZE:
+.. _CONFIGURE_BDBUF_BUFFER_MAX_SIZE:
-CONFIGURE_BDBUF_BUFFER_MIN_SIZE
+CONFIGURE_BDBUF_BUFFER_MAX_SIZE
 CONSTANT:
-    ``CONFIGURE_BDBUF_BUFFER_MIN_SIZE``
+    ``CONFIGURE_BDBUF_BUFFER_MAX_SIZE``
 DATA TYPE:
 RANGE:
-    Positive.
+    It must be positive and an integral multiple of the buffer minimum size.
 DEFAULT VALUE:
-    The default value is 512 bytes.
+    The default value is 4096 bytes.
 DESCRIPTION:
-    Defines the minimum size of a buffer in bytes.
+    Defines the maximum size of a buffer in bytes.
 NOTES:
     None.
-.. index:: CONFIGURE_BDBUF_BUFFER_MAX_SIZE
+.. index:: CONFIGURE_BDBUF_BUFFER_MIN_SIZE
-.. _CONFIGURE_BDBUF_BUFFER_MAX_SIZE:
+.. _CONFIGURE_BDBUF_BUFFER_MIN_SIZE:
-CONFIGURE_BDBUF_BUFFER_MAX_SIZE
+CONFIGURE_BDBUF_BUFFER_MIN_SIZE
 CONSTANT:
-    ``CONFIGURE_BDBUF_BUFFER_MAX_SIZE``
+    ``CONFIGURE_BDBUF_BUFFER_MIN_SIZE``
 DATA TYPE:
 RANGE:
-    It must be positive and an integral multiple of the buffer minimum size.
+    Positive.
 DEFAULT VALUE:
-    The default value is 4096 bytes.
+    The default value is 512 bytes.
 DESCRIPTION:
-    Defines the maximum size of a buffer in bytes.
+    Defines the minimum size of a buffer in bytes.
 NOTES:
     None.
-.. index:: CONFIGURE_SWAPOUT_SWAP_PERIOD
+.. index:: CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS
-.. _CONFIGURE_SWAPOUT_SWAP_PERIOD:
+.. _CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS:
-CONFIGURE_SWAPOUT_SWAP_PERIOD
+CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS
 CONSTANT:
-    ``CONFIGURE_SWAPOUT_SWAP_PERIOD``
+    ``CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS``
 DATA TYPE:
@@ -2797,23 +2794,25 @@ RANGE:
     Positive.
 DEFAULT VALUE:
-    The default value is 250 milliseconds.
 DESCRIPTION:
-    Defines the swapout task swap period in milliseconds.
+    Defines the maximum blocks per read-ahead request.
 NOTES:
-    None.
+    A value of 0 disables the read-ahead task (default).  The read-ahead task
+    will issue speculative read transfers if a sequential access pattern is
+    detected.  This can improve the performance on some systems.
-.. index:: CONFIGURE_SWAPOUT_BLOCK_HOLD
+.. index:: CONFIGURE_BDBUF_MAX_WRITE_BLOCKS
-.. _CONFIGURE_SWAPOUT_BLOCK_HOLD:
+.. _CONFIGURE_BDBUF_MAX_WRITE_BLOCKS:
-CONFIGURE_SWAPOUT_BLOCK_HOLD
+CONFIGURE_BDBUF_MAX_WRITE_BLOCKS
 CONSTANT:
-    ``CONFIGURE_SWAPOUT_BLOCK_HOLD``
+    ``CONFIGURE_BDBUF_MAX_WRITE_BLOCKS``
 DATA TYPE:
@@ -2822,23 +2821,23 @@ RANGE:
     Positive.
 DEFAULT VALUE:
-    The default value is 1000 milliseconds.
+    The default value is 16.
 DESCRIPTION:
-    Defines the swapout task maximum block hold time in milliseconds.
+    Defines the maximum blocks per write request.
 NOTES:
     None.
-.. index:: CONFIGURE_SWAPOUT_TASK_PRIORITY
+.. index:: CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
-.. _CONFIGURE_SWAPOUT_TASK_PRIORITY:
+.. _CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY:
-CONFIGURE_SWAPOUT_TASK_PRIORITY
+CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
 CONSTANT:
-    ``CONFIGURE_SWAPOUT_TASK_PRIORITY``
+    ``CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY``
 DATA TYPE:
     Task priority (``rtems_task_priority``).
@@ -2850,47 +2849,45 @@ DEFAULT VALUE:
     The default value is 15.
 DESCRIPTION:
-    Defines the swapout task priority.
+    Defines the read-ahead task priority.
 NOTES:
     None.
-.. index:: CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS
+.. index:: CONFIGURE_BDBUF_TASK_STACK_SIZE
-.. _CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS:
+.. _CONFIGURE_BDBUF_TASK_STACK_SIZE:
-CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS
+CONFIGURE_BDBUF_TASK_STACK_SIZE
 CONSTANT:
-    ``CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS``
+    ``CONFIGURE_BDBUF_TASK_STACK_SIZE``
 DATA TYPE:
 RANGE:
-    Positive.
+    Zero or positive.
 DEFAULT VALUE:
 DESCRIPTION:
-    Defines the maximum blocks per read-ahead request.
+    Defines the task stack size of the Block Device Cache tasks in bytes.
 NOTES:
-    A value of 0 disables the read-ahead task (default).  The read-ahead task
-    will issue speculative read transfers if a sequential access pattern is
-    detected.  This can improve the performance on some systems.
+    None.
-.. index:: CONFIGURE_BDBUF_MAX_WRITE_BLOCKS
+.. index:: CONFIGURE_SWAPOUT_BLOCK_HOLD
-.. _CONFIGURE_BDBUF_MAX_WRITE_BLOCKS:
+.. _CONFIGURE_SWAPOUT_BLOCK_HOLD:
-CONFIGURE_BDBUF_MAX_WRITE_BLOCKS
+CONFIGURE_SWAPOUT_BLOCK_HOLD
 CONSTANT:
-    ``CONFIGURE_BDBUF_MAX_WRITE_BLOCKS``
+    ``CONFIGURE_SWAPOUT_BLOCK_HOLD``
 DATA TYPE:
@@ -2899,48 +2896,48 @@ RANGE:
     Positive.
 DEFAULT VALUE:
-    The default value is 16.
+    The default value is 1000 milliseconds.
 DESCRIPTION:
-    Defines the maximum blocks per write request.
+    Defines the swapout task maximum block hold time in milliseconds.
 NOTES:
     None.
-.. index:: CONFIGURE_BDBUF_TASK_STACK_SIZE
+.. index:: CONFIGURE_SWAPOUT_SWAP_PERIOD
-.. _CONFIGURE_BDBUF_TASK_STACK_SIZE:
+.. _CONFIGURE_SWAPOUT_SWAP_PERIOD:
-CONFIGURE_BDBUF_TASK_STACK_SIZE
+CONFIGURE_SWAPOUT_SWAP_PERIOD
 CONSTANT:
-    ``CONFIGURE_BDBUF_TASK_STACK_SIZE``
+    ``CONFIGURE_SWAPOUT_SWAP_PERIOD``
 DATA TYPE:
 RANGE:
-    Zero or positive.
+    Positive.
 DEFAULT VALUE:
+    The default value is 250 milliseconds.
 DESCRIPTION:
-    Defines the task stack size of the Block Device Cache tasks in bytes.
+    Defines the swapout task swap period in milliseconds.
 NOTES:
     None.
-.. index:: CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
+.. index:: CONFIGURE_SWAPOUT_TASK_PRIORITY
-.. _CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY:
+.. _CONFIGURE_SWAPOUT_TASK_PRIORITY:
-CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
+CONFIGURE_SWAPOUT_TASK_PRIORITY
 CONSTANT:
-    ``CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY``
+    ``CONFIGURE_SWAPOUT_TASK_PRIORITY``
 DATA TYPE:
@@ -2952,57 +2949,57 @@ DEFAULT VALUE:
 DESCRIPTION:
-    Defines the read-ahead task priority.
+    Defines the swapout task priority.
 NOTES:
     None.
-.. index:: CONFIGURE_SWAPOUT_WORKER_TASKS
+.. index:: CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY
-.. _CONFIGURE_SWAPOUT_WORKER_TASKS:
+.. _CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY:
-CONFIGURE_SWAPOUT_WORKER_TASKS
+CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY
 CONSTANT:
-    ``CONFIGURE_SWAPOUT_WORKER_TASKS``
+    ``CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY``
 DATA TYPE:
+    Task priority (``rtems_task_priority``).
 RANGE:
-    Zero or positive.
+    Valid task priority.
 DEFAULT VALUE:
+    The default value is 15.
 DESCRIPTION:
-    Defines the swapout worker task count.
+    Defines the swapout worker task priority.
 NOTES:
     None.
-.. index:: CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY
+.. index:: CONFIGURE_SWAPOUT_WORKER_TASKS
-.. _CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY:
+.. _CONFIGURE_SWAPOUT_WORKER_TASKS:
-CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY
+CONFIGURE_SWAPOUT_WORKER_TASKS
 CONSTANT:
-    ``CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY``
+    ``CONFIGURE_SWAPOUT_WORKER_TASKS``
 DATA TYPE:
-    Task priority (``rtems_task_priority``).
 RANGE:
-    Valid task priority.
+    Zero or positive.
 DEFAULT VALUE:
-    The default value is 15.
 DESCRIPTION:
-    Defines the swapout worker task priority.
+    Defines the swapout worker task count.
 NOTES:
     None.
@@ -3284,32 +3281,6 @@ DESCRIPTION:
 NOTES:
     None.
-.. index:: CONFIGURE_IDLE_TASK_STACK_SIZE
-.. _CONFIGURE_IDLE_TASK_STACK_SIZE:
-CONFIGURE_IDLE_TASK_STACK_SIZE
-CONSTANT:
-    ``CONFIGURE_IDLE_TASK_STACK_SIZE``
-DATA TYPE:
-RANGE:
-    Undefined or positive.
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_IDLE_TASK_STACK_SIZE`` is set to the desired stack size for the
-    IDLE task.
-NOTES:
-    None.
 .. index:: CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
 .. _CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION:
@@ -3344,6 +3315,32 @@ NOTES:
     The IDLE task must run at the lowest priority of all tasks in the system.
+.. index:: CONFIGURE_IDLE_TASK_STACK_SIZE
+.. _CONFIGURE_IDLE_TASK_STACK_SIZE:
+CONFIGURE_IDLE_TASK_STACK_SIZE
+CONSTANT:
+    ``CONFIGURE_IDLE_TASK_STACK_SIZE``
+DATA TYPE:
+RANGE:
+    Undefined or positive.
+DEFAULT VALUE:
+DESCRIPTION:
+    ``CONFIGURE_IDLE_TASK_STACK_SIZE`` is set to the desired stack size for the
+    IDLE task.
+NOTES:
+    None.
 General Scheduler Configuration
@@ -3955,38 +3952,95 @@ suitable for simple applications with no custom device drivers.
 Note that network device drivers are not configured in the Device Driver Table.
-.. index:: CONFIGURE_MAXIMUM_DRIVERS
+.. index:: CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
-.. _CONFIGURE_MAXIMUM_DRIVERS:
+.. _CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER:
-CONFIGURE_MAXIMUM_DRIVERS
+CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
 CONSTANT:
+    ``CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER``
-    ``CONFIGURE_MAXIMUM_DRIVERS``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    ``CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER`` is defined when the
+    application does *NOT* want the Clock Device Driver and is *NOT* using the
+    Timer Driver.  The inclusion or exclusion of the Clock Driver must be
+    explicit in user applications.
+NOTES:
+    This configuration parameter is intended to prevent the common user error
+    of using the Hello World example as the baseline for an application and
+    leaving out a clock tick source.
+.. index:: CONFIGURE_APPLICATION_EXTRA_DRIVERS
+.. _CONFIGURE_APPLICATION_EXTRA_DRIVERS:
+CONFIGURE_APPLICATION_EXTRA_DRIVERS
+CONSTANT:
+    ``CONFIGURE_APPLICATION_EXTRA_DRIVERS``
 DATA TYPE:
+    device driver entry structures
 RANGE:
-    Zero or positive.
+    Undefined or set of device driver entry structures
 DEFAULT VALUE:
-    This is computed by default, and is set to the number of device drivers
-    configured using the ``CONFIGURE_APPLICATIONS_NEEDS_XXX_DRIVER``
-    configuration parameters.
 DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_DRIVERS`` is defined as the number of device drivers
-    per node.
+    ``CONFIGURE_APPLICATION_EXTRA_DRIVERS`` is defined if the application has
+    device drivers it needs to include in the Device Driver Table.  This should
+    be defined to the set of device driver entries that will be placed in the
+    table at the *END* of the Device Driver Table.
 NOTES:
-    If the application will dynamically install device drivers, then this
-    configuration parameter must be larger than the number of statically
-    configured device drivers. Drivers configured using the
-    ``CONFIGURE_APPLICATIONS_NEEDS_XXX_DRIVER`` configuration parameters are
-    statically installed.
+    None.
+.. index:: CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+.. _CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER:
+CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+CONSTANT:
+    ``CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    ``CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER`` is defined if the application
+    wishes to include the Clock Device Driver.
+NOTES:
+    This device driver is responsible for providing a regular interrupt which
+    invokes a clock tick directive.
+    If neither the Clock Driver not Benchmark Timer is enabled and the
+    configuration parameter
+    ``CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER`` is not defined, then a
+    compile time error will occur.
 .. index:: CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
@@ -4029,6 +4083,92 @@ NOTES:
     configuration options are mutually exclusive.
+.. index:: CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
+.. _CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER:
+CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
+CONSTANT:
+    ``CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    ``CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER`` is defined if the
+    application wishes to include the BSP's Frame Buffer Device Driver.
+NOTES:
+    Most BSPs do not include support for a Frame Buffer Device Driver. This is
+    because many boards do not include the required hardware.
+    If this is defined and the BSP does not have this device driver, then the
+    user will get a link time error for an undefined symbol.
+.. index:: CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
+.. index:: /dev/null
+.. _CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER:
+CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
+CONSTANT:
+    ``CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    This configuration variable is specified to enable ``/dev/null`` device driver.
+NOTES:
+    This device driver is supported by all BSPs.
+.. index:: CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
+.. _CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER:
+CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
+CONSTANT:
+    ``CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    ``CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER`` is defined if the application
+    wishes to include the Real-Time Clock Driver.
+NOTES:
+    Most BSPs do not include support for a real-time clock. This is because
+    many boards do not include the required hardware.
 .. index:: CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
 .. _CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER:
@@ -4128,15 +4268,15 @@ NOTES:
-.. index:: CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+.. index:: CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
-.. _CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER:
+.. _CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER:
-CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
 CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER``
+    ``CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER``
 DATA TYPE:
@@ -4148,117 +4288,22 @@ DEFAULT VALUE:
 DESCRIPTION:
-    ``CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER`` is defined if the application
-    wishes to include the Clock Device Driver.
+    ``CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER`` is defined if the application
+    wishes to include the Stub Device Driver.
 NOTES:
-    This device driver is responsible for providing a regular interrupt which
-    invokes a clock tick directive.
-    If neither the Clock Driver not Benchmark Timer is enabled and the
-    ``CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER`` is not defined, then a
-    compile time error will occur.
+    This device driver simply provides entry points that return successful and
+    is primarily a test fixture. It is supported by all BSPs.
 .. index:: CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
 .. _CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER:
-CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER`` is defined if the application
-    wishes to include the Timer Driver.  This device driver is used to
-    benchmark execution times by the RTEMS Timing Test Suites.
-NOTES:
-.. index:: CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
-.. _CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER:
-CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
-CONSTANT:
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER`` is defined when the
-    application does *NOT* want the Clock Device Driver and is *NOT* using the
-    Timer Driver.  The inclusion or exclusion of the Clock Driver must be
-    explicit in user applications.
-NOTES:
-    This configuration parameter is intended to prevent the common user error
-    of using the Hello World example as the baseline for an application and
-    leaving out a clock tick source.
-.. index:: CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
-.. _CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER:
-CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
-CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER`` is defined if the application
-    wishes to include the Real-Time Clock Driver.
-NOTES:
-    Most BSPs do not include support for a real-time clock. This is because
-    many boards do not include the required hardware.
-    If this is defined and the BSP does not have this device driver, then the
-    user will get a link time error for an undefined symbol.
-.. index:: CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
-.. _CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER:
-CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
 CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER``
+    ``CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER``
 DATA TYPE:
@@ -4270,25 +4315,25 @@ DEFAULT VALUE:
 DESCRIPTION:
-    ``CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER`` is defined if the
-    application wishes to include the Watchdog Driver.
+    ``CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER`` is defined if the application
+    wishes to include the Timer Driver.  This device driver is used to
+    benchmark execution times by the RTEMS Timing Test Suites.
 NOTES:
-    Most BSPs do not include support for a watchdog device driver. This is
-    because many boards do not include the required hardware.
-.. index:: CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
+.. index:: CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
-.. _CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER:
+.. _CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER:
-CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
+CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
 CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER``
+    ``CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER``
 DATA TYPE:
@@ -4300,25 +4345,26 @@ DEFAULT VALUE:
 DESCRIPTION:
-    ``CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER`` is defined if the
-    application wishes to include the BSP's Frame Buffer Device Driver.
+    ``CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER`` is defined if the
+    application wishes to include the Watchdog Driver.
 NOTES:
-    Most BSPs do not include support for a Frame Buffer Device Driver. This is
+    Most BSPs do not include support for a watchdog device driver. This is
-.. index:: CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
+.. index:: CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
+.. index:: /dev/zero
-.. _CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER:
+.. _CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER:
-CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
+CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
 CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER``
+    ``CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER``
 DATA TYPE:
@@ -4330,12 +4376,10 @@ DEFAULT VALUE:
 DESCRIPTION:
-    ``CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER`` is defined if the application
-    wishes to include the Stub Device Driver.
+    This configuration variable is specified to enable ``/dev/zero`` device driver.
 NOTES:
-    This device driver simply provides entry points that return successful and
-    is primarily a test fixture. It is supported by all BSPs.
 .. index:: CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
@@ -4370,87 +4414,38 @@ NOTES:
     with VMEBus. The VMEBus Controller initialization is performed by a device
     driver configured via this configuration parameter.
-.. COMMENT: XXX Add example
-.. index:: CONFIGURE_APPLICATION_EXTRA_DRIVERS
-.. _CONFIGURE_APPLICATION_EXTRA_DRIVERS:
-CONFIGURE_APPLICATION_EXTRA_DRIVERS
-CONSTANT:
-    ``CONFIGURE_APPLICATION_EXTRA_DRIVERS``
-DATA TYPE:
-    device driver entry structures
-RANGE:
-    Undefined or set of device driver entry structures
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_APPLICATION_EXTRA_DRIVERS`` is defined if the application has
-    device drivers it needs to include in the Device Driver Table.  This should
-    be defined to the set of device driver entries that will be placed in the
-    table at the *END* of the Device Driver Table.
-NOTES:
-    None.
-.. index:: CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
-.. index:: /dev/null
+.. index:: CONFIGURE_MAXIMUM_DRIVERS
-.. _CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER:
+.. _CONFIGURE_MAXIMUM_DRIVERS:
-CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
+CONFIGURE_MAXIMUM_DRIVERS
 CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    This configuration variable is specified to enable ``/dev/null`` device driver.
-NOTES:
-    This device driver is supported by all BSPs.
-.. index:: CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
-.. index:: /dev/zero
-.. _CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER:
-CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
-CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER``
+    ``CONFIGURE_MAXIMUM_DRIVERS``
 DATA TYPE:
 RANGE:
+    Zero or positive.
 DEFAULT VALUE:
+    This is computed by default, and is set to the number of device drivers
+    configured using the ``CONFIGURE_APPLICATIONS_NEEDS_XXX_DRIVER``
+    configuration parameters.
 DESCRIPTION:
-    This configuration variable is specified to enable ``/dev/zero`` device driver.
+    ``CONFIGURE_MAXIMUM_DRIVERS`` is defined as the number of device drivers
+    per node.
 NOTES:
+    If the application will dynamically install device drivers, then this
+    configuration parameter must be larger than the number of statically
+    configured device drivers. Drivers configured using the
+    ``CONFIGURE_APPLICATIONS_NEEDS_XXX_DRIVER`` configuration parameters are
+    statically installed.
 Multiprocessing Configuration
@@ -4492,15 +4487,15 @@ NOTES:
     This has no impact unless RTEMS was built with the
     ``--enable-multiprocessing`` build configuration option.
-.. index:: CONFIGURE_MP_NODE_NUMBER
+.. index:: CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
-.. _CONFIGURE_MP_NODE_NUMBER:
+.. _CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS:
-CONFIGURE_MP_NODE_NUMBER
+CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
 CONSTANT:
-    ``CONFIGURE_MP_NODE_NUMBER``
+    ``CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS``
 DATA TYPE:
@@ -4509,18 +4504,15 @@ RANGE:
     Positive.
 DEFAULT VALUE:
-    The default value is ``NODE_NUMBER``, which is assumed to be set by the
-    compilation environment.
+    The default value is 32.
 DESCRIPTION:
-    ``CONFIGURE_MP_NODE_NUMBER`` is the node number of this node in a
-    multiprocessor system.
+    ``CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS`` is the maximum number of
+    concurrently active global objects in a multiprocessor system.
 NOTES:
-    In the RTEMS Multiprocessing Test Suite, the node number is derived from
-    the Makefile variable ``NODE_NUMBER``. The same code is compiled with the
-    ``NODE_NUMBER`` set to different values. The test programs behave
-    differently based upon their node number.
+    This value corresponds to the total number of objects which can be created
+    with the ``RTEMS_GLOBAL`` attribute.
 .. index:: CONFIGURE_MP_MAXIMUM_NODES
@@ -4548,33 +4540,6 @@ DESCRIPTION:
 NOTES:
     None.
-.. index:: CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
-.. _CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS:
-CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
-CONSTANT:
-    ``CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS``
-DATA TYPE:
-RANGE:
-    Positive.
-DEFAULT VALUE:
-    The default value is 32.
-DESCRIPTION:
-    ``CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS`` is the maximum number of
-    concurrently active global objects in a multiprocessor system.
-NOTES:
-    This value corresponds to the total number of objects which can be created
-    with the ``RTEMS_GLOBAL`` attribute.
 .. index:: CONFIGURE_MP_MAXIMUM_PROXIES
 .. _CONFIGURE_MP_MAXIMUM_PROXIES:
@@ -4633,6 +4598,36 @@ NOTES:
     Multiprocessor System assuming the BSP provides the proper set of
     supporting methods.
+.. index:: CONFIGURE_MP_NODE_NUMBER
+.. _CONFIGURE_MP_NODE_NUMBER:
+CONFIGURE_MP_NODE_NUMBER
+CONSTANT:
+    ``CONFIGURE_MP_NODE_NUMBER``
+DATA TYPE:
+RANGE:
+    Positive.
+DEFAULT VALUE:
+    The default value is ``NODE_NUMBER``, which is assumed to be set by the
+    compilation environment.
+DESCRIPTION:
+    ``CONFIGURE_MP_NODE_NUMBER`` is the node number of this node in a
+    multiprocessor system.
+NOTES:
+    In the RTEMS Multiprocessing Test Suite, the node number is derived from
+    the Makefile variable ``NODE_NUMBER``. The same code is compiled with the
+    ``NODE_NUMBER`` set to different values. The test programs behave
+    differently based upon their node number.
 PCI Library Configuration
@@ -4688,60 +4683,60 @@ Plug & Play is not performed.
 Event Recording Configuration
-.. index:: CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
+.. index:: CONFIGURE_RECORD_EXTENSIONS_ENABLED
-.. _CONFIGURE_RECORD_PER_PROCESSOR_ITEMS:
+.. _CONFIGURE_RECORD_EXTENSIONS_ENABLED:
-CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
+CONFIGURE_RECORD_EXTENSIONS_ENABLED
 CONSTANT:
-    ``CONFIGURE_RECORD_PER_PROCESSOR_ITEMS``
+    ``CONFIGURE_RECORD_EXTENSIONS_ENABLED``
 DATA TYPE:
-    Unsigned integer (``unsigned int``).
 RANGE:
-    A power of two greater than or equal to 16.
 DEFAULT VALUE:
 DESCRIPTION:
-    If defined, then a record item buffer of the specified item count is
-    statically allocated for each configured processor
-    (:ref:`CONFIGURE_MAXIMUM_PROCESSORS <CONFIGURE_MAXIMUM_PROCESSORS>`).
+    If defined and :ref:`CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
+    <CONFIGURE_RECORD_PER_PROCESSOR_ITEMS>` is also defined properly, then the
+    record extensions are enabled.
 NOTES:
-    None.
+    The record extensions capture thread create, start, restart, delete,
+    switch, begin, exitted and terminate events.
-.. index:: CONFIGURE_RECORD_EXTENSIONS_ENABLED
+.. index:: CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
-.. _CONFIGURE_RECORD_EXTENSIONS_ENABLED:
+.. _CONFIGURE_RECORD_PER_PROCESSOR_ITEMS:
-CONFIGURE_RECORD_EXTENSIONS_ENABLED
+CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
 CONSTANT:
-    ``CONFIGURE_RECORD_EXTENSIONS_ENABLED``
+    ``CONFIGURE_RECORD_PER_PROCESSOR_ITEMS``
 DATA TYPE:
+    Unsigned integer (``unsigned int``).
 RANGE:
+    A power of two greater than or equal to 16.
 DEFAULT VALUE:
 DESCRIPTION:
-    If defined and :ref:`CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
-    <CONFIGURE_RECORD_PER_PROCESSOR_ITEMS>` is also defined properly, then the
-    record extensions are enabled.
+    If defined, then a record item buffer of the specified item count is
+    statically allocated for each configured processor
+    (:ref:`CONFIGURE_MAXIMUM_PROCESSORS <CONFIGURE_MAXIMUM_PROCESSORS>`).
 NOTES:
-    The record extensions capture thread create, start, restart, delete,
-    switch, begin, exitted and terminate events.
+    None.
 .. _ConfigAda:
2.16.4
